History SUPER STOCK A/FX & Match race photos
Discussion in 'The Hokey Ass Message Board' started by loudbang, Mar 22, 2018.
  1. flatheadgary
    flatheadgary
    from boron,ca
    one bad 51 merc. it had a automatic trans.
    31hotrodguy and loudbang like this.
  2. It looks like a picture from Connecicut Drag-way. Bill Lawton / Tasca Ford were frequent compe***ers there.
  3. loveoftiki
    loveoftiki
    from Livonia,Mi
    Deuces, 31hotrodguy and loudbang like this.
  4. 31hotrodguy
    31hotrodguy
  5. the automatics blew up in just as spectacular fashion. i had a 727 come apart on the starting line while driving the jakes speed equipment awb car. if you should ever see the car look at the dash and the p***enger side inner lower fender. the dash got happered out and the fender patched after shrapnel exited both areas. the tci trans shields brackets were sheared off. when the car came back to the pits the driveshaft was removed and the trans or what was left fell on the ground. no bolts needed to be removed. beswick got burned bad in a auto trans fire.
    Stogy, 0NE BAD 51 MERC, enloe and 2 others like this.
  6. 31hotrodguy
    31hotrodguy
    enloe, Deuces and loudbang like this.
  7. saltflats
    saltflats
    from Missouri
    slowmotion, Stogy, scott27 and 5 others like this.
  8. wrenchbender
    wrenchbender
    Hey James have you seen his new car it’s a 63 tempest wagon and it’s awesome so be careful what you wish for lol
  9. loudbang
  10. 1320 Fan
    1320 Fan
    Looks like tire measure & trim time. Probably into the late rounds.
  11. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Gary , Automatic or manual, rotating m*** either between your legs or as in Brian's case along side can be a game changer in a split second. Seen it happen numerous times over the last 49 years on the track and on the street. Ever launch a front joint on a potent 440 Mopar street machine without a front drive shaft hoop because you didn't think you needed one cause it was a STREET machine! Believe me that can be short changer in itself let alone something like that Jeep! lol Larry
    loudbang and 427 sleeper like this.
  12. 427 sleeper
    427 sleeper
    I've been on that ride... You want to run but you can't! You need an extra pair of shorts, a shovel, a squeegee, and a water hose to clean up the mess!!! Not fun, but definately memorable! :eek::eek::eek:
    loudbang and 31hotrodguy like this.
  13. loudbang
    Dixie Twister (bigger photo)
  14. loudbang
  15. Duck's Goat
    Duck's Goat
    That's a Doug Nash/S-K/Warrior tunnel ram. Those three different brands were all the same intake but owned by the respective names different years and branded as such. I hope to use this one on my '61 Catalina one day,
  16. gt350hr
    gt350hr
    from So Cal
  17. loudbang
    posted by hemidav in the vintage thread
    Interesting hood scoop. Front suspension very close to scrub line.
    Elcohaulic, echo ed, Stogy and 3 others like this.
  18. Unique Rustorations
    Unique Rustorations
    What’s on the track LB?
  19. loudbang
    Good old Rosin burn out.
  20. axle
    axle
    from Drag City
    This is a wonderful thread, but how has it survived when it is technically not allowed on the Hamb?
    impala4speed likes this.
  21. Technically your wrong because fx and super stock started way before 1965. You might want to do a little research before you make a comment like that. You dont want to go around making a *** of yourself over a technicality
  22. loudbang
    AH do you see any newer than 65 cars posted? :confused:
    Stogy, racer-x, slowmotion and 4 others like this.
  23. loudbang
  24. loudbang
  25. 31hotrodguy
    31hotrodguy
    Stogy and loudbang like this.
  26. 31hotrodguy
    31hotrodguy
    Why would it not be allowed on the H.A.M.B.?
  27. loudbang
  28. loudbang
    Oliver ****nasty Ramstrom's garage
  29. loudbang
  30. loudbang
