Technical Drivetrain Adaptation Tribal Knowledge Thread
Discussion in 'The Hokey Ass Message Board' started by treb11, Jan 15, 2020.
  1. rusty valley
    rusty valley
    in the 80's i put a volvo trans on the back of a datsun 240z motor. to do this i layed the bell housings flat on the work bench, shimmed up to height with plywood, then clamped a sawzall into the vise and rotated the bell to make the cut. once i had both bells cut, i bolted them in place, straddled over the top and wiggled them around until it felt like it was centered in line with the pilot bearing, and my friend with the fancy tig welder tacked it while i held it in place. crude as it was, i drove it many thousands of miles, and my friend still drives it today. sometimes a little luck helps too
  2. Can you PM me any details and pictures you may have?
  3. Rusty O'Toole
    Rusty O'Toole
    I knew an old timer who made several trans adapters in the fifties. His technique was simple, he would stand the engine on its nose, set the clutch and trans in place, push the trans all the way to the left, mark it, all the way to the right, mark it, all the way forward and all the way back. Then center it by eye to the scribe marks and mark the center of the bolt holes with a punch. Drill the holes on his drill press and there you are.
    Sometimes it was possible to redrill the bellhousing, sometimes he cut a plate of steel or aluminum.
  4. treb11
    treb11
  5. treb11
    treb11
  6. Beanscoot
    Beanscoot
    "info on T5 adapters, a good condensation of the huge amount of info in the T5 thread:"
    etc.
    "Now, this IS NOT to be ANOTHER T5 thread, there is already a great lengthy thread here,plus others. So don't bother with that."
    I'm confused.
    Vic Walter and Tman like this.
  7. treb11
    treb11
    It's a pointer to the T5 threads so this one does not get cluttered up with repeats of information already on those threads. I mean for this thread to have information about other engine/trans combinations. And I deleted the post that confused you so much. Happy?
  8. treb11
    treb11
  9. treb11
    treb11
    loudbang and Beanscoot like this.
  10. treb11
    treb11
  11. treb11
    treb11
  12. Black Panther
    Black Panther
    from SoCal
  13. Black Panther
    Black Panther
    from SoCal
  14. treb11
    treb11
  15. Black Panther
    Black Panther
    from SoCal
    Some earlier Trans Dapt numbers..
  16. Black Panther
    Black Panther
    from SoCal
  17. treb11
    treb11
    Jag 6 to T-5 via early Ford V8 housing:
  18. treb11
    treb11
    how to make an adapter plate, ignore the late model aspect and focus on the principles:
    How To Make a Custom Gearbox Adapter Plate - 2AZFE to TL70 - Project Wonder AE86 #5
    Kreepea_1, Tim and loudbang like this.
  19. treb11
    treb11
    350 T GM automatic transmission to a 1950’s Packard flathead straight eight-cylinder engine:
    Kreepea_1 and chriseakin like this.
  20. Beanscoot
    Beanscoot
    I just watched the first of those adapter videos, the guy was pretty clever and I was impressed that he mentioned checking it at the end with a dial indicator.
    Plus it has a relaxing, soothing sound track.
  21. treb11
    treb11
  22. treb11
    treb11
  23. wheeldog57
    wheeldog57
    Rocky, what flywheel and clutch were you using? I would like to do this also
  24. Rocky
    Rocky
    Classified Editor
    Never got that far. When I found the damaged cylinder wall I stopped collecting parts for it. I believe an aftermarket company makes a flywheel for the 500 but not sure who it is.
    loudbang and wheeldog57 like this.
  25. Tim
    Tim
    from KCMO
    Great thread idea
  26. gimpyshotrods
    gimpyshotrods
    wheeldog57 and loudbang like this.
  27. treb11
    treb11
  28. brokedownbiker
    brokedownbiker
    I've always wondered why there wasn't something like around somewhere. In the
    Harley world there was a booklet published back in the 70's and 80's called, strangely enough, "What Fits What" . It had pretty comprehensive info on mixing and matching H-D parts from the 30's thru the early 80's.
    I know an automotive version would be WAY bigger due to the vast array of parts, options, and models, and year ranges but really, people spend years writing about a specific car I'd think the knowledge would be worth a lot of money if it was gathered together in a single source (or a series for that matter).
  29. jakespeed63
    jakespeed63
    Ross Racing adapter
    1976 Cadillac TH400 to 1964 Oldsmobile 394
    Yes it required shaving the bell-housing, so not a bolt in affair
    Uses front pump bolts to secure adapter to trans[​IMG]
    gimpyshotrods, Chucky and loudbang like this.
