Technical Best “shorty” shocks?
Discussion in 'The Hokey Ass Message Board' started by chiro, Jul 28, 2020.
  1. chiro
    chiro
    I need a set of “shortys” for the front of my Model A. Dropped axle, lower mounting bungs welded to face of the axle a la Bishop/Tardel book. Traditional F1 style upper mounts. The shocks I have now are not short enough. They must be for those bungs that bolt to bottom of axle so I need shorter ones. I’ve seen them from so-cal and speedway. Who experience with either or knows of another vendor and have positive reviews.
    TIA,
    Andy
    lothiandon1940 likes this.
  2. Mr48chev
    You can search though the Monroe shock list (about the easiest to find on line and most complete) and once you find a shock that fits your needs you search that shock number and very often other brands that have the same size shock will show up.
    I'd say "Best" is the particular brand you like.
    This explains how to tell what ends you need plus it has the catalog https://www.shockwarehouse.com/news/pdf/monroe_mount_codes.pdf
    Also their page may be far simpler to use to find the shock than the Monroe PFD.
    https://www.shockwarehouse.com/news/monroe_measurements.cfm
    This is the Monroe shock chart pfd that I have used for years but that shock warehouse page is far easier to use. I have used the printed version of this one since the 70's.
    This is the link to the Size chart http://www.monroe.com/downloads/install-instructions-guides/MonroeMountingLengthSpecifications.pdf
    Just Gary, Hnstray and lothiandon1940 like this.
  3. lothiandon1940
    lothiandon1940
    Check with Pete and Jakes as well.
  4. Dino 64
    Dino 64
    from Virginia
  5. Aaron D.
    Aaron D.
  6. Better watch out ordering anything from Speedway or Amazon. According to the HAMB they sell nothing but Chinese ****....
  7. pprather
    pprather
    If you can find a Bilstein shock that fits your application you won't be sorry they cost more. They are worth it if you are actually going to drive your rod more than a thousand miles a year.
    The P&J shocks I had were marked Gabriel. They lasted about 20k miles. Not long enough for me to recommend them.
    Phil
  8. Malcolm
    Malcolm
    from Nebraska
    I'm also a big fan of Bilstein shocks. I have nearly 50k miles on the set on my roadster and they're still going strong. Much better than the So-Cal shocks I started with.
  9. Light years better than anything out there.
  10. Malcolm
    Malcolm
    from Nebraska
    da34guy and Tman like this.
  11. sdroadster
    sdroadster
    If your cheap like me, you can use 50 Plymouth front shocks. Look in the Monroe book on line.
  12. That's another good one to know
    Sent from my SM-J337V using The H.A.M.B. mobile app
  13. krylon32
    krylon32
    from Nebraska
    Check with Ride Tech. They seem to have the hot setup in hot rod shocks today although they may not have the right length?
  14. deathrowdave
    deathrowdave
    from NKy
    My car has buggy springs front and rear , I used Monroe , I’m not sure , there is enough , suspension movement to warrant a high dollar shock to be installed . This isn’t a road rally type suspension .
  15. da34guy
    da34guy
    X 4 or 5 or 6 BILSTEIN.
    gimpyshotrods, LBCD, Malcolm and 2 others like this.
  16. Elcohaulic
    Elcohaulic
    Koni has the the sizes posted on there site..
  17. continentaljohn
    continentaljohn
    I like and use the Bilstein and Pete and Jakes shortys.
    LBCD, Malcolm and lothiandon1940 like this.
  18. I am running that setup. Used the Pete and Jakes shortys. 12DD1194-D6A3-49C6-8AD8-8B696E86B54C.jpeg
  19. banjorear
    banjorear
    This. $18 per @ Rock Auto. Made in the USA as well
  20. 31Apickup
    31Apickup
    The 50 Plymouth shock is Monroe 5752, most likely too long if your mount is on the axle and not below. I’m running them on the front of my Model A.
  21. sdroadster
    sdroadster
    Banjo Rear is right. 50 Plymouth's at Rock auto. 12.75 extended, 8.6 compressed, 5/8 eyelet on both ends. They also have an old school dust shield. $18 bucks for the good ones.. I have used these shocks on everything over the years.
    A Boner and Jet96 like this.
  22. -Brent-
    -Brent-
    Post up the length you need, both extended and collapsed.
  23. Elcohaulic
    Elcohaulic
    Shocks have come a long way. Since they look the same, no reason not to use very high quality shocks. The car will handle like a dream with good shocks.. I would call Mark Sevetske at SC&C and see what they have..
  24. ydopen
    ydopen
    2E75AFB6-BB74-4DBF-963E-903965BEDDD0.jpeg Pete & Jakes shorty
  25. Lloyd's paint & glass
    What I've learned in the past 30 years, is that there is different grades of Chinese made parts, good and bad, just like American made parts ;) someone posted on my build thread just the other day about "made in the USA with Chinese steel" I ordered new AC Delco ball joints for my car, "made in China" right on the box. I guess that no matter where you buy it from, it's just a roll of the dice.....
    A Boner and 0NE BAD 51 MERC like this.
  26. dmdeaton
    dmdeaton
    Hard to tell from the pic, but what do your headlight mounts look like? are they combined with the shock mounts?
    I am having issues trying to sort out my headlight mounts. I have them on the top of shock towers now and they vibrate like hell. No room to mount separate with the way I have my shock mounts.
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you don't mind fabricating , get pinto/ must II , cut the bayonet top off , weld on a shock eye(piece of tubing will work) something you can find a bushing for & there ya' go , short shocks , low bucks ( Ive got $26 in mine) they've lasted 20 years so far.....
  28. pprather
    pprather
  29. seadog
    seadog
    Another vote for Bilstein.
    Malcolm and gimpyshotrods like this.
  30. iafraser39
    iafraser39
    from Warmland
    I used T bucket shocks on my model A front. The ride hieght is 9-1/2 inches.
    I have gone through 2 sets already as there is not enough movement and they
    bottom out. At ride height there is only 1-1/2 inches of compression.
    I think other folks have had this same problem. Any advice here.
