Projects And So It Begins
Discussion in 'Traditional Hot Rods' started by Piewagn, Jul 14, 2019.
  1. Piewagn
    Piewagn
    Like a gift.....dropped right into my lap! I thought, what the hell....before I fall asleep, let me check ebay one more time...... and BAM....there it was! I'm ******** stoked! 80 friggin' bucks! Woo Hoooooo!!
    Rock Auto saved me over 100 bucks on the bearings and races.....they even had the double race for the pinion for 20+ bucks! Psyched!!
  2. Piewagn
    Piewagn
    Ok....I’ve got 2 carriers. One is more worn and the bearings basically aren’t a press fit anymore, they’ve been replaced so many times or from just plain hackery, that I can knock them on with a mallet! The other shows minimal signs of wear, but is pitted from rust because it was left in the elements. I’m leaning towards the pitted one because of wear and bearing retention. What do you guys think? Any input would be greatly appreciated.....thanks fellas!
    First 3 is the worn one....
    Second 3 is the pitted one....( inner axle and spider gear surfaces are virtually unworn )
    IMG_2421.JPG IMG_2420.JPG IMG_2423.JPG IMG_2413.JPG IMG_2424.JPG IMG_2417.JPG
  3. Dick Stevens
    Dick Stevens
    I would use the worn one with Loc***e bearing retainer and it could be knurled which will make it press fit again.
  4. Piewagn
    Piewagn
    I thought about the retaining compound, but my concern is the ******ed bearing land not allowing proper ring gear lash. I should've got pics of the inside where the spiders and the back of the axle gears ride. They're a bit wallered out and I'm also concerned with axle end play.....I'll take some measurements. We DO have some heavy duty retaining compound too....
    I've got some decisions to make..... Thanks for the input ****!!
  5. Piewagn
    Piewagn
    Better pics of the ring and pinion I scored.....the Hotrod Gods were smiling upon me for that moment in time.....knowing my strapped budget, they put an $80 price tag on it too!! [emoji16][emoji16] I’m a happy camper!! Adjustments.JPG Adjustments.JPG
    brEad, Dick Stevens and loudbang like this.
  6. Piewagn
    Piewagn
    Cleaning things up and gathering the best parts out of the 3 differentials I had. Good axle housings already clearanced for the hydraulic backing plates and wheel cyls! My bearings came today from Rock Auto! The one double race that’s priced at 60+ bucks at the Ford parts suppliers was priced at $22 from RA! Like I said, the hotrods gods smiled upon me when I was feeling a little down.... IMG_2431.JPG IMG_2432.JPG IMG_2433.JPG
  7. Piewagn
    Piewagn
    The axles I chose came out nice, these should work just fine! Picked my torque tube from the 3 I had and getting that ready for seal and bearing....have a real nice speedo housing and gear as well. Ring and pinion is supposed to be here tomorrow, then I can get rolling putting this thing together and hanging it for the last time.....hopefully!! Thanks for stickin’ around fellas, you all give me motivation to keep rollin’! IMG_2440.JPG IMG_2441.JPG IMG_2442.JPG IMG_2443.JPG
    loudbang and simplestone like this.
  8. Piewagn
    Piewagn
    Ring and pinion came today.....pinion looks great....the ring gear has ONE tooth that’s worn/pitted. The boss, just today, has offered to pay for what I need to get this differential done; that includes a new ring and pinion! I told him we’ll look at these gears together tomorrow and make a decision. What do you guys think about THIS ring and pinion? Would you use it in something? Thanks fellas!! IMG_2444.JPG IMG_2446.JPG IMG_2445.JPG
  9. treb11
    treb11
  10. Dick Stevens
    Dick Stevens
    I would have to be desperate to use it with that pitting, I would gratefully accept your bosses offer and thank him profusely!
  11. Piewagn
    Piewagn
    Let me dig up the invoice treb and I’ll post a picture of it.....
  12. Piewagn
    Piewagn
    I think I am going to take him up on his offer....but that means the trade off for the cylinder heads he was gonna get....
    Although, I do have a feeling he’ll spring for those anyway! He said “you’ve got a fairy godfather that wants to help”......he’s not just my boss, he owns the company!
    Thanks for your input ****.....
    brEad and loudbang like this.
  13. Piewagn
    Piewagn
    Here ya go treb!
    4x 28156 bearing
    2x 28317 cone
    1x 28314XD Double cone/race
    Type the numbers into RA’s search feature and they’ll come up....
  14. Piewagn
    Piewagn
    Well, while waiting on some things to finish up the diff, I started getting my brakes together....those brake shoe retainer clips are a pain in the ***! Anyone know an easy way to get those ****ers installed??
    I’ve also brought home some homework for the weekend....I’ll be setting my pinion preload and prepping and painting the end bells and torque tube.....that should keep me busy.....enjoying your weekend fellas! Adjustments.JPG IMG_2467.JPG
    kidcampbell71, loudbang and brEad like this.
  15. Piewagn
    Piewagn
    Set my pinion preload. Spec call for 20 in/lbs. With a thin layer of gear oil, rotation starts at spec and maintains 18-20 in/lbs throughout rotation. I’m calling it done.... IMG_2469.JPG IMG_2470.JPG IMG_2472.JPG
  16. 62pan
    62pan
    I don't see any sign of that lock washer that goes between the two nuts.
    loudbang and Piewagn like this.
  17. Piewagn
    Piewagn
    Well, the lock washer and jam nut went on after I finished up setting the preload.....just didn't get a pic....
  18. Piewagn
    Piewagn
    Everyone can sleep well tonight....even went fore and aft with the washer tabs....:D:D IMG_2480.JPG
  19. Aaron D.
    Aaron D.
    Nice job. When I did mine, I really enjoyed learning how the Banjo rear works and goes together.
    Atwater Mike, Piewagn and loudbang like this.
  20. Shutt
    Shutt
    I installed one like that with 3 pitted teeth and a galled bearing; had trouble patterning it and it whined from 40-50. Replaced it.
  21. Piewagn
    Piewagn
    Thanks Aaron! Definitely a different experience than all those bearing replacement jobs I did in front diffs of GM K series trucks when I worked at the dealer. They were a breeze....
    This one is repeated ***embly and dis***embly.....I'll be able to do these blindfolded by the time I'm done.....
    Aaron D. and loudbang like this.
  22. Piewagn
    Piewagn
    Sourced different stuff from an old friend I haven't seen in a while and replaced all the bearings. Just like that, he pops up outta nowhere last evening while I was jerkin' off in the garage...I'm tellin' ya, The Hotrod Gods looked out for me on this one!
    brEad, loudbang and rusty valley like this.
  23. Piewagn
    Piewagn
    FINALLY!!! Everything came out sweet! All bearing preloads, the pattern was spot on with .006” lash!
  24. loudbang
    One BIG STEP finished. :)
    kidcampbell71 likes this.
  25. Piewagn
    Piewagn
    Oh...you bet LB! I can get to hangin' and plumbing the brakes when this goes in! I'm itchin' to get to the body. But the next biggie is the engine clean up and inspection. But, I suspect that to go smoothly....it was a running engine that just came out of a driving car when I bought it..... Famous last words huh? :D
  26. Piewagn
    Piewagn
    Got all the brakes ***embled....Looking for park brake hardware, or I may plumb some type of hydraulic lock lever or something.....
    Book says to insert speedo gear with gear end towards the rear...if I do, the snap ring groove is not exposed...I checked witness marks on the other drive shafts I have and it looks like gear side was towards trans....I don’t remember how they came off....any input on this?? IMG_2492.JPG Adjustments.JPG
  27. Aaron D.
    Aaron D.
  28. Piewagn
    Piewagn
  29. Piewagn
    Piewagn
  30. Piewagn
    Piewagn
    Paint will be dry by morning then I’m ready to hang it! Thank God.....only ate up about 3 weeks! Hopefully things will hit cruise control for a while now, we shall see.....thanks for stoppin’ by fellas!! IMG_2493.JPG
