Customs 1965 Impala plugs hit pistons
Discussion in 'The Hokey Ass Message Board' started by Johnny Puroll, Jul 31, 2020.
  1. Johnny Puroll
    Johnny Puroll
    Just put 661 heads on to wake up my 283. Gap closed on plugs. Old heads have washer seat, new have tapered. So I went with plugs for a 305 h.o. Who else had this problem?
  2. Some plugs are designed with a projected tip that fits farther in to the chamber.You may need to go to a non projected tip.
  3. squirrel
    R45T plugs instead of R45TS might fix the problem. Those are AC numbers, which may or may not make any sense to you. But they make sense to the folks who built the engines you're dealing with
    lothiandon1940, Baumi, j-jock and 4 others like this.
  4. jimmy six
    jimmy six
    I didn’t use resistor plugs back when I did that. AC 44’s were the plugs I used. When I went to Rochester FI I had to use C43’s (C was for commercial) which were the equivalent to 42’s to get to run right.
  5. Johnny Puroll
    Johnny Puroll
    Thank goodness, I couldn't see anyone reporting on what spark plug they ran afterward. So I was worried it wasn't going to work after the fact.
  6. Johnny Puroll
    Johnny Puroll
    Means something to me now, I only run ac delco in gm
  7. To elaborate what Squirrel said, a quick lesson in AC spark plugs and what the letters and numbers mean.
    The "R" denotes a resistor plug. The numbers, heat range, the smaller the number gets the colder it is. Only spark plug I think is the reverse is true is NGK but there could be others today. The "T" designates a tapered (non gasket) seat and the "S" is extended tip. When it has an "X" (for example R45TSX, R45TX) that designates an extended gap, if memory is correct as it's been a long time since I ran into that situation the gap has to be .060 for that designation. When you go to the auto parts store ask them to pull a R45T and a R45TS and compare the difference of how far the tip extends from the body of the spark plug.
  8. Johnny Puroll
    Johnny Puroll
    So I went with R44T and no clearance issues... Its running, but its very loud. Would those 305 heads make the exhaust that much louder, I need quieter mufflers.
  9. Mr48chev
    Can't say on the "loud" part, maybe it is just happy because it can breath better.
    lothiandon1940 and ffr1222k like this.
  10. Johnny Puroll
    Johnny Puroll
    It also stumbles cant hande snapping the throttle... before or after all these modifications.
  11. Johnny Puroll
    Johnny Puroll
    What are the quietest muffler people have used... I just wanna cruise in it.
  12. Ericnova72
    Ericnova72
    from Michigan
    This is typically not enough initial ignition timing, or not enough accelerator pump shot from the carburetor if timing is good.
    What is your initial timing set at, and what carb are you using??
    j-jock and squirrel like this.
  13. When you installed the intake gaskets did you block off the heat riser p***ages? That can change the exhaust note somewhat, using the crossover p***age can dampen some of the exhaust note.
  14. squirrel
    Timing...first thing to double check.
  15. Johnny Puroll
    Johnny Puroll
    Summit K1104 Cam, Holley Contender Intake, 650 4 Barrel, 661 heads, stock manifolds but dual exhaust. "That had already been added" Crane L933 rockers.
    Timing advance 0 degrees.
