Technical A Moron's guide to figuring out the rear gear ratio
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Aug 3, 2020.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I listed a Ford 8" rear axle in the cl***ifieds that had previously resided under a friends Model A, he removed it years ago and it is void of the tag stating the gear.
    My friend has since p***ed away and I can't ask him any questions, the axles have been removed and I guess I need to put them back in to turn the yoke to get the ratio.
    I have never done that, thus the *****'s guide ***le.
    How do I proceed? HRP
    3W JOHN likes this.
  2. manyolcars
    manyolcars
    With one drum not moving, turn the other twice while counting the revolutions of the pinion yoke.
  3. alchemy
    alchemy
    Since it's laying on the floor, I'd remove the ten bolts and pull the chunk. Then you can also examine the condition of the gears.
  4. Slopok
    Slopok
    Count the ring & pinion, then divide.
  5. blowby
    blowby
    from Nicasio Ca
    What's that cover above the pinion for?
    3W JOHN and HOTRODPRIMER like this.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Some times the fingers are quicker than the mind, other times it gives members the opportunity to give another member a ration of SH!T. :rolleyes:
    If you will notice the axles are not in the housing and the drums are laying on the floor, I can turn one drum all day long and nothing happens with the parts in their current location. :D HRP
    grumpy65, Texas Webb, 3W JOHN and 5 others like this.
  7. fiftyv8
    fiftyv8
    from CO & WA
    That cover is generally used as a rubber bump stop plate in some models.
    I'm with alchemy and slopok on opening it up and doing a thorough check, that way no mistakes or unhappy endings.
  8. HOTRODPRIMER
    HOTRODPRIMER
    I will, my thought process was if someone needs a rear axle, it already has the mounts for the ladder bars or four bars and cup's for the springs, for 100 bucks it's cheap even if the gears are bad,but I do need to check it out. HRP
    Desoto291Hemi and 3W JOHN like this.
  9. 38Chevy454
    38Chevy454
    You could pop the axles in, so the splines are engaged. Then hold one side still while turning the pinion until the opposite axle makes two revolutions.
    Or just remove the the center section bolts and be able to check the gears the easy way by counting teeth on ring and pinion and then divide ring count by pinion count. Also able to see gear and nearing condition, take a few pics to show buyer. This gives the best chance to sell.
  10. -Brent-
    -Brent-
    This.
    With the housing out of the car, brakes off, and axles out, you're 80% there.
  11. blowby
    blowby
    from Nicasio Ca
    I don't understand. What is behind it, it must cover something?
  12. jaw22w
    jaw22w
    from Indiana
    As long as we're correcting, it is pinion yoke, not egg yolk.:rolleyes:
  13. Flathead Dave
    Flathead Dave
    from So. Cal.
    You shouldn't be calling stupid people *****s.
    They don't understand what a ***** is. All you did was to confuse them and now they are walking into walls.
    Sent from my SM-G973U using The H.A.M.B. mobile app
    61Cruiser, grumpy65, 3W JOHN and 2 others like this.
  14. manyolcars
    manyolcars
    and spelling yoke wrong :)
  15. 56don
    56don
    Am I any smarter for reading this thread??:confused:
  16. manyolcars
    manyolcars
    I'm convinced that I am getting dumber. I've spelled yoke correctly my entire life until now
  17. 392
    392
    Just pull chunk like said. Very eeeasy even a ***** can do it. You asked and named. All bs aside that is easily done with spot on specs and condition.
  18. X-cpe
    X-cpe
    If he pulls the carrier, he looses all plausible deniability if there is a problem with it. (LOL)
    3W JOHN, HOTRODPRIMER and MO54Frank like this.
  19. Black_Sheep
    Black_Sheep
    I’m not familiar with 8” Fords but most ring gears are stamped with the number of ring gear teeth and pinion teeth, divide the larger number by the smaller number to determine the ratio. Obviously you have to pull the pig to view the numbers, but it’s the most foolproof method IMHO
    427 sleeper, 3W JOHN and HOTRODPRIMER like this.
  20. HOTRODPRIMER
    HOTRODPRIMER
    I don't think so Don, but at least we are getting a spelling lesson.:D HRP
    3W JOHN, TagMan and 56don like this.
  21. If you're lucky, the punkin has been out before and they didn't re-install them steenkin copper washers.
  22. Hnstray
    Hnstray
    from Quincy, IL
    The piece that is held by the smaller circle of bolts is called the pinion carrier. It is common to 8” & 9” Ford axles. It comes out of the carrier housing and contains the pinion, pinion bearings (3) and the pinion seal as well as the yoke. It was a terrific idea and makes setting the pinion depth so much easier as the depth is adjusted by shims between the pinion carrier and the housing.
    As mentioned in a prior post, the little ‘hoodie’ thing is a contact point for the pinion snubber that many cars had, especially Fords of that era. There is a rubber bump stop mounted to the frame or body just above it.
    Ray
  23. Hnstray
    Hnstray
    from Quincy, IL
    There is a very good chance you typed it correctly and your computer ‘corrected’ it for you. It happens frequently that the machine fills in the most likely (common) word after a few letters are entered. Drives me nuts! Also, this iPad often enters the numeral that is colocated with the alpha letter I typed. Also, inappropriately adds capitalization with the slightest provocation! :mad:
    Ray
  24. gimpyshotrods
    gimpyshotrods
    Schrödinger's ring and pinion?
    61Cruiser, Baumi, razoo lew and 6 others like this.
  25. blowby
    blowby
    from Nicasio Ca
    Ah OK, my bad. After zooming in I get the picture. Looked like that hoodie thing was a separate cover. Thanks.
  26. 3W JOHN
    3W JOHN
    Danny,did you ever figure it out?
    HOTRODPRIMER likes this.
  27. HOTRODPRIMER
    HOTRODPRIMER
    No John, I have just had too many irons in the fire lately, I been helping Brenda at the shop and Al hasn't been back to works since the start of all this covid ****.
    Damn, I'm suppose to be retired! HRP
    3W JOHN likes this.
  28. goldmountain
    goldmountain
    You could ***ume it is 3.00:1 and apologize later.
  29. Mr48chev
    I've never had any faith in the turn and count method. That is only good for a ball park figure anyhow.
    Agree 100% with X-cpe you could have pulled the chunk and counted the teeth in the time it took to go back in the house and ask how to do it the easy way.
  30. grumpy65
    grumpy65
    Or, as many seem to do these days, advertise it as the most sought-after ratio, and then claim ignorance after the sale and refuse to entertain any notions of a refund. As I'm sure you all have noticed, the world just gets better and better each and every day. :eek:
    No @HOTRODPRIMER , I don't think you would do this. Have read enough of your stuff to have judged you correctly. :)
    Ring and pinion count is the way to go.
    3W JOHN, clem and HOTRODPRIMER like this.
