Projects Aussie 32 frame / Model A coupe build.
Discussion in 'Traditional Hot Rods' started by Wardog, Feb 7, 2019.
  1. Great build keep the updates coming.
    Wardog likes this.
  2. yblock32
    yblock32
    from Australia
    I did the same years ago when I built my coupe
    Wardog likes this.
  3. brady1929
    brady1929
    Great job.
    Wardog likes this.
  4. Its coming along great. Keeping things traditional do you still need to compliance this as a hot rod or do you get away without it?
  5. sloppy jalopies
    sloppy jalopies
    At GE they used #12- fine thread br*** slotted screws, they discontinued the product and asked if I wanted the rest of them... couple lbs. … few $ per lbs. …
    I gave bags of 50 or so to every model A guy I knew...some I didn't …
    lasted about 5 years before I ran out...
    I stumble on one now and then in the nut, bolt, washer box...
    I run into the same screw size problem with the tank to firewall screws...
    more than half of them snap off about 1.5 turns out... drill and tap to 1/4"-20...
    brEad likes this.
  6. Wardog
    Wardog
    It’s basically a stock 1932 ch***is with a hydraulic brake upgrade but yeah it will get an inspection.
    1947knuck and Josh the Painter like this.
  7. Wardog
    Wardog
    Haha. One mans trash is another mans treasure.
    1947knuck likes this.
  8. 31Apickup
    31Apickup
    Just got a bag of 20 #12-24 screws thru Amazon. Stainless with Phillips heads.
    Wardog likes this.
  9. Beanscoot
    Beanscoot
    "Just got a bag of 20 #12-24 screws thru Amazon. Stainless with Phillips heads."
    Exactly. Should be no problem getting any size needed with this internet thing, despite the local hardware store not stocking uncommon sizes.
    I like to keep the original size and style fasteners as much as possible on machinery and cars. Even if they are Whitworth!
  10. Wardog
    Wardog
    Not a lot of progress lately.
    My son and I have finished off his motorcycle build and I’ve been working on some yard projects for my wife.
    I’ve also been working a lot of different shifts in my work’s busy season
    In saying that I have welded in the sub rails and am making some templates for the wheel wells.
    A7D0C462-C490-4C88-977E-2AC11FA1CA0F.jpeg 3DC64C3E-70EB-40F6-81CD-313C3B3B44B5.jpeg 622A2719-76E9-4DA8-8DB3-DF606B8F264C.jpeg 31BD76E8-75E8-4623-A58F-2B10BDBAFA7B.jpeg
    Deutscher, Retroline, Stogy and 2 others like this.
  11. The37Kid
    The37Kid
    Is that piece that mates the Steadfast rail to the rear crossmember part of the "Kit" or something you had to fab yourself? it all looks nice. Bob [​IMG]
    Stogy likes this.
  12. Wardog
    Wardog
  13. Looking the goods!
    Cheers, Josh
    Wardog likes this.
  14. Wardog
    Wardog
    I made a start on the quarters on Friday. It felt good to be putting some metal back in.
    51BDF665-9C6C-44EF-AE24-906786384E40.jpeg FF156F60-A01F-4A5F-A22D-0545580CB288.jpeg 07E63DAD-9EA0-4219-BE32-B38EA454A6F4.jpeg
  15. Wardog
    Wardog
    7860E2E0-7E16-417A-8789-56F816B1D204.jpeg 33705B5C-A16F-441E-803B-196A0475D44D.jpeg 493C3F34-293B-4492-84DD-08EEE5949266.jpeg 6FF6B394-104B-4B17-B073-FA7426E44988.jpeg 79A43351-0879-43E4-9AA8-377D8C99E084.jpeg 09AB32F4-29A9-4865-B9A6-53AE4EE9E323.jpeg 5C3FE2AD-267F-4CA8-A026-A4FA2650053D.jpeg Good progress this weekend.
    ralphson, Deutscher, v8paul and 13 others like this.
  16. The37Kid
    The37Kid
    Like the bead work on the wheel wells! Bob
    Stogy, Wardog and sloppy jalopies like this.
  17. brEad
    brEad
    Nice job! Good seeing a youngster helping out, too. Important for them to learn things can be fixed or made from scratch.
    Stogy and Wardog like this.
  18. ct1932ford
    ct1932ford
    What a great thread! Nice work all around and I like to see the children involved. :cool:When do you chop the top?:rolleyes:
  19. Wardog
    Wardog
    Haha, there’s plenty to do before the chop.
    Stogy likes this.
  20. Wardog
    Wardog
    I’ve just about got all the welding done now. Just the fire wall to go. 97867AD9-1919-40E4-9AEB-55747701AE59.jpeg 752AE205-98F1-4835-B944-04F45AB78BAE.jpeg 610CB539-4CE3-4592-B665-C2D3BCE644BF.jpeg 3AB7F969-D69A-4EA3-90C2-1D24095B82DC.jpeg 2F80D6F7-E153-4282-930F-FDDD6489FF29.jpeg
  21. Wardog
    Wardog
    Talking with a friend he told me to check if the tops of the quarters had rolled in before welding the rear braces. Putting the deck lid on showed the right hand side had and was touching. So a little (hand) pressure with a scissor jack moved it back to where it needed to be.
    CD63B38B-4360-4497-B365-480BEFEBE873.jpeg 6322027B-CA8E-45DC-AAEC-E10B43BBBCDA.jpeg 3EDE3D5F-2BB3-4193-AF5A-4FA835EF5990.jpeg
  22. alchemy
    alchemy
    Every time I see guys doing all this welding on subrails, I get nervous about decklid fit. A current project I'm working on had been cracked and welded at the corners of the decklid many times by previous owners. Then a total floor and subrail replacement by us. As you can imagine, the decklid wouldn't fit anymore. I actually cut a sliver from the top of the quarter and pushed the trough and bead outward to make room. It was way beyond just pushing it up with a jack.
    I think checking/fitting doors and decklids at all parts of the fab process is very important.
    Atwater Mike likes this.
  23. I have the same problem on a Coupe I’m working on at the moment, both sides.
    it is something I notice on a lot of As and appears to be quite common.
    I will try your fix but I’m seeing some slicing and dicing in my future.
    Great build by the way.
    Wardog and Fairlane500 like this.
  24. Wardog
    Wardog
    Checking with the opening panels is definitely important. One thing to remember while doing this is how well or not those panels fitted up in the first place. My doors always sat high at the rear if checking at the belt line. That’s something else I’ll fix while I’m at it.
    Outback and waxhead like this.
  25. Outback
    Outback
    from NE Vic, Oz
    Looking good mate!
  26. Wardog
    Wardog
    I spent Friday afternoon finishing off my patches and sanding back welds.
    567C8780-2002-4ACA-B8D4-533D53F01ED3.jpeg E9264103-AB2A-418E-82BC-251670AF57BB.jpeg 0D8B791C-5E6C-4F34-8EB5-4926C22901D8.jpeg
  27. Wardog
    Wardog
    Saturday I installed the rivets in the rear of the body and got some primer on everything. After lunch I put some filler on the repairs.
    B005A8F9-8B44-411C-B823-35D463E9967F.jpeg D1505B4D-6505-4D2A-80F8-C9A162CE592E.jpeg 87A93287-8D65-4809-AA93-AB1026E8800C.jpeg 4DC77496-45FC-4A8E-B91C-6FA044771D95.jpeg 527692E9-52EA-42D5-81A6-98C3B06A4668.jpeg
  28. Wardog
    Wardog
    Today I sanded the filler back on the 4 main patch panels.
    7CDDF95B-D7A8-4636-B99B-D8D4139CF736.jpeg DF846B73-6C40-4C12-854A-B27A5CF578A5.jpeg
    My wife took this photo as I was sweeping up and trying to blow the rest of the dust outside.
    Deutscher, v8paul, Just Gary and 8 others like this.
  29. Outback
    Outback
    from NE Vic, Oz
    Nice work mate, good to ser progress
    Stogy likes this.
  30. Stogy
    Stogy
    "A Plus Job @Wardog...Mickey was quite the entertainer but Bodywork wasn't his Cup of Cheese...:D
    Cheers Mate...Walt...
    Big Thumbs Up from Stogy too...;)
