Projects 1949 Buick Sedanette Mild Custom Build
Discussion in 'Traditional Customs' started by rockable, Mar 16, 2019.
  1. rockable
    rockable
    Took it down off the stands and,moved it,outside to see how it sits. I'm liking it!
  2. lippy
    lippy
    from Ks
    Man that looks great!! Lippy
  3. Corvette Fever
    Corvette Fever
    from Michigan
    That is one great looking Buick you’re doing. Very nice work and attention to detail, good job. They really do make excellent customs. [​IMG]I had a 47 convertible years ago. I do have an original power window switch if you should need I t.
  4. BJR
    BJR
    That looks great, nice stance!
  5. loudbang, Thor1 and rockable like this.
  6. rockable
    rockable
    If youve ever looked at those Buick side opening hoods and thought, "Boy those look cool, I would love to have a car with that one day.", youve, obviously, never tried to adjust one and get it right. I've spent most of 2 days screwing with mine and have adjusted every panel from the doors,forward,trying to get the hood to fit, latch in and look decent. When you move one thing, it affects the other. I havent figured out yet how I am going to do it once its painted.
    SS327, loudbang, LAROKE and 3 others like this.
  7. BJR
    BJR
    I must have gotten lucky with mine, it fits and shuts and latches fine.
    loudbang and Thor1 like this.
  8. rockable
    rockable
    And doesn't rub the paint off the edges? What is the gap between your hood and fender?
    chryslerfan55, loudbang and Thor1 like this.
  9. BJR
    BJR
    I have the hood off now replacing the head gaskets on my Cad engine. Hope to finish it this week end but I will be working alone and will not be able to put the hood back on to measure it. The car is at my farm in Wisconsin, and I live in St Paul MN. I will take pictures when I get the hood back on. Have you looked at the factory shop manual on how to adjust the hood hinges? I just followed that and it worked.
    loudbang, Thor1 and Hnstray like this.
  10. lippy
    lippy
    from Ks
    Mine kinda fits but it's original and the latches are tweaked. In fact I think two of them on opposite sides aren't even't working. I don't take it over a hundred. IMG_4890.JPG
    brEad, 40FORDPU, loudbang and 4 others like this.
  11. rockable
    rockable
    Yes, I looked at the manual. My car had been butchered on the front end. It had no core support and things had been "modified". I had to reconstruct it, so there is some variability there, as well. When you move a fender in OR out, you have to move the thing a corresponding amount, plus you have to get it at the right height, angle, etc before the pins will slide in smoothly and the mechanism can latch. I have it about as good as I'm going to get it unless I rebuild the hinges or modify them.
  12. BJR
    BJR
    I was thinking about putting a safety catch in the center front of my hood incase one of the side hood latches lets loose when I meet a semi or a gust of wind at speed.
  13. rockable
    rockable
    I believe I would!
  14. lippy
    lippy
    from Ks
    I was also thinking of putting some kind of safety catch on the front of the hood, maybe cable operated from inside. Lippy
  15. rockable
    rockable
    0807201110.jpg 0807201119.jpg Dang! Trying to get the hood gaps close and NOT RUBBING is proving difficult....but I'm not done yet. I did take a diversionary trip and closed the hood gap above the grill. I could get my fingers,in there before. Now, I have a nice 3/16" gap.
    chryslerfan55, brEad, Lines and 10 others like this.
  16. Hang'emHigh
    Hang'emHigh
    Glad I'm not the only one with that disease, lol. Love what you've done with this car. Even the non-Hamb-friendly mods. Just the right mix!
  17. rockable
    rockable
    This is going to be a long distance cruiser. It's over 1000 miles to Salina from here but I plan to go to KKOA again...one day.
    loudbang, Thor1 and jim snow like this.
  18. Hang'emHigh
    Hang'emHigh
    Love to do a '50 Sedanette in a similar style one day. I bet your car will make a great long distance driver.
  19. Fat47
    Fat47
    I can't give you any magic on the hood. Like BJR I followed the manual and lucked out. It took some time but I think I got the gaps pretty even. I had to contend with a new clip on the front end but it didn't seem to throw everything out of proportion. I did have help from a 40 year body man who knew a lot about the old school stuff but it was mostly trial and error. Stay with it and walk away for awhile when the frustration begins to set in.
    chryslerfan55 and Thor1 like this.
  20. rockable
    rockable
    After 4 days of adjusting, bending, shimming and finally, using a porta power, I got the gaps to 1/4". However, it still gets really close in spots when you lift the hood 6-8". I'm just worried that it might chip or rub the paint off.
    My paint and body guy is stopping by this week to look at it. If we can't get that to work, I may go look for a BMW mechanism that slides forward and tilts forward. I'm not anxious to do that but I am beginning to hate these hinges.
    SS327, loudbang, Stogy and 1 other person like this.
  21. rockable
    rockable
    This damned rear seat was something I just had to digest a little at a time. If I got cut or stuck by a hog ring once.....you know the rest. I placed sew foam in between the coils laterally and then ties them down with some webbing I had. LOTS of hog rings and lots of cursing. I'm never going to complain about what upholstery costs again.
  22. Hang'emHigh
    Hang'emHigh
    Remind me why we do this to ourselves again.... ;)
    Brand Apart, loudbang and Thor1 like this.
  23. Peanut 1959
    Peanut 1959
    "Hog riding"??? No wonder you got scratched up! [emoji12]
  24. rockable
    rockable
    Went to the Pull A Part today and found a '95 BMW with forward tilt hood mechanism. I had to go buy a battery powered Sawzall before I could get everything I need. It's supposed to rain tomorrow but I plan to go back on Sunday and get the parts. The idea of a forward tilt hood appeals to me for a lot of reasons over the side hinged hood. Wish me luck in getting those parts integrated!
    LAROKE, loudbang, Thor1 and 1 other person like this.
  25. vtwhead
    vtwhead
    Geesch you sure seem to like a challenge!:) I have no doubt however that you will make it work given your past history.
  26. rockable
    rockable
    My buddy, Richard, has helped motivate me to do this build right. He's going to help me with the hood mechanism. After all, it was his idea. :D
    And I'm in no hurry. I DO enjoy a good challenge.
  27. igorsgonemadd
    igorsgonemadd
    Oh please take lots of pics of that process. I’m fighting with my latches right now. That’s definitely something I would be interested in doing to my 51! Really great work so far man, rock on!!
  28. rockable
    rockable
    My front bumper fits well and I'm about ready to just stick with it as is. The rear bumper, however looks "flop eared". The outsides stick,out further than they should and the gap is not good. So, I conducted a little surgery today and I'm very happy I did it. This is how they should be.
    0813201334.jpg 0813201334a.jpg 0815201501a.jpg 0815201502a.jpg 0815201503.jpg
  29. vtwhead
    vtwhead
    Your flip flops remind me of the last time I wore them in my shop.....I ran in to get something, hit the air hose (with one of my feet) which was attached to the die grinder with a pointed carbide cutter on my bench. It went sailing in the air and drove the pointed carbide into my foot. On dam ****** mess FWIW:)
  30. rockable
    rockable
    I do like to wear sandals in the summer. Welding and grinding is not a recommended activity with them, however. I do sometimes try to slide by. :rolleyes::p
