50 Power Wagon Woodie
Discussion in 'The Antiquated' started by mamllc, Aug 6, 2020.
  1. mamllc
    mamllc
    I started this project about 6 months ago so the first post will show a lot more progress than later ones. The truck is a 1950 Power Wagon, the wood body that was on the truck when I got it was built by someone who either didn't have the original wood to copy or didn't try. The original plan was to build an exact copy of an original, but as the owner intends to use it, some changes were made to improve functionality. Styling will be mostly Campbell. It is a three door style with the spare tire on the running board behind the drivers door. I am working on the spare tire mount and finishing the opposite door now. After that will be the tailgate, trim, veneer for all the panels, a few thousand odd details then blow it all apart and start making it shiny. IMG_4041.JPG IMG_4058.JPG IMG_4081.JPG IMG_4103.JPG IMG_4121.JPG IMG_4129.JPG IMG_4131.JPG IMG_4138.JPG IMG_4142.JPG IMG_4150.JPG IMG_4156.JPG
    49ratfink, ol'stinky, rc57 and 22 others like this.
  2. mamllc
    mamllc
    Not sure how many pictures will fit in one post but a dozen seemed like a nice round number. The roof is mostly original except that I decided to dress the corners up some. The original back corner posts had the same shape on the back as the new ones but the outside was straight instead of having the same profile as the other pillars. I decided to shape the outside of the rear post to match the front pillars. Tall people will be driving it so the front seat will be moved back along with the B pillar to make a bigger door and better access. The back door will be s IMG_4194.JPG IMG_4222.JPG IMG_4223.JPG IMG_4224.JPG IMG_4225.JPG IMG_4226.JPG IMG_4244.JPG IMG_4246.JPG IMG_4257.JPG IMG_4296.JPG IMG_4294.JPG IMG_4298.JPG tretched some too in order to keep things proportional.
  3. mamllc
    mamllc
    Using bear claw door latches but staying with roll up windows. One piece gl*** in the front doors, originals had a fixed wing window. Quarter panels will get solid gl*** instead of sliders. It has A/C now and the four front windows should provide enough ventilation. IMG_4353.JPG IMG_4354.JPG IMG_4356.JPG IMG_4358.JPG IMG_4384.JPG IMG_4381.JPG
  4. WiredSpider
    WiredSpider
    Amazing work
    I envy people that can work with wood.
    I,m not one of them
    rod1 and classiccarjack like this.
  5. BJR
    BJR
    Am I watching "This OLD CAR". Where is Bob Vela? Nice work and it looks great. You have talent sir.
    210superair likes this.
  6. gene-koning
    gene-koning
    WOW! That is some nice wood work.
    I'm lucky to cut a board straight with a power saw and a guide. I'm impressed with guys that can do wood work, and what your doing is better then most the stuff I've seen. Gene
  7. F-ONE
    F-ONE
    from Alabama
    This is not what I expected. Wow! just wow!
  8. Fordors
    Fordors
    @mamllc, your abilities suggest training as an artist, wood worker, tool maker and pattern maker all rolled into one. Very impressive, that will be one beautiful truck when completed.
    You will enjoy seeing another scratch built Woodie, on a one ton Ford truck ch***is. Go to fordbarn.com and search for GB SISSON.
    classiccarjack and 210superair like this.
  9. 51504bat
    51504bat
    I second the woodie build by GB SISSON on the Barn. I sent him a PM with the link to your build. I don't know how often he gets on the Barn at the moment. He is busier than a one armed paper hanger right now with his cabinetry business.
  10. mamllc
    mamllc
    Found the thread, it's a long one! Way too late tonight to get started on that. I'll have to have a closer look when I get more time.
  11. 41 GMC K-18
    41 GMC K-18
    Perfection cannot be rushed !
    Everything old, is new again !
  12. ras
    ras
    Very impressive skills. I'm curious how you cut the finger joints? Did you buy a jig or make your own, maybe a picture? Is the structural wood maple? Thanks in advance for your response
  13. mamllc
    mamllc
    The wood is Ash. For the finger joints I had a set of wing cutters made and do it on a shaper.
  14. rustednutz
    rustednutz
    from tulsa, ok
    Truly an amazing job! I'm looking forward to the finished vehicle.
  15. woodbutcher
    woodbutcher
    :D That is just outstanding.Thanks for posting.Looking forward to updates.
    Good luck.Have fun.Be safe.
    Leo
  16. 38bill
    38bill
    from Minnesota
    Thanks for sharing your project. I really love seeing wood bodies being built.
  17. 1952henry
    1952henry
    Nice job. Thanks for the pics. A fellow Marmon-Herrington owner and I have swapped thoughts about a woodie body on an F3 M-H frame. Neither of us have your abilities. Woodies were built on standard F2 and F3s. No woodie M-H has surfaced, however.
  18. Clean , crisp, and precise . Such talent put to a cool build on a Power Wagon . Thanks for the pictures , I agree there is a thousand more " to dos" but I'm sure you will work your plan and plan your work. Looking forward to following the progress.
    lothiandon1940 likes this.
  19. CaptainComet
    CaptainComet
    Boy, you sure are killing a bunch of trees there ....
    Nice Work! I build furniture as a hobby.
    Haven't made this leap yet .... woodies and guitars, those are some serious woodworking skills.
    VANDENPLAS likes this.
  20. john worden
    john worden
    from iowa
    Beautifully done.
  21. Okie Pete
    Okie Pete
    Beautiful Craftsmanship.
  22. rustydusty
    rustydusty
    As a "retired yacht carpenter" I can really appreciate your skills. I also am impressed with your "finger joint" system. What are you using for adhesive?
  23. mamllc
    mamllc
    Guitars aren't something I make a habbit of, but got roped into this little repair on my brother inlaws Les Paul. IMG_1276.JPG
    Rawrench, 6inarow and CaptainComet like this.
  24. mamllc
    mamllc
    Yacht carpenter? Ever heard of a wood sportfish called a Rybovich? That's where I got started in custom woodworking. This one is 48', finished it in 87. IMG_1207.JPG
  25. mamllc
    mamllc
    Forgot to answer your question.... I use epoxy for the finger joints and for most other things too including veneering the panels when I get around to it. I use a little yellow wood glue once and a while too.
  26. mamllc
    mamllc
    The doors are all done, got the spart tire mount finished and am on to the tailgate. IMG_4405.JPG IMG_4407.JPG IMG_4408.JPG IMG_4409.JPG IMG_4410.JPG IMG_4411.JPG IMG_4412.JPG IMG_4435.JPG IMG_4434.JPG
  27. Rolleiflex
    Rolleiflex
    Man, that is one big beauty!
  28. 57 Fargo
    57 Fargo
    Holy ****!! This is amazing!
    6inarow and lothiandon1940 like this.
  29. oldwagonlover
    oldwagonlover
    Very impressive. I hope to do the same thing for my 48 Chevy!
    You have me inspired, bought my shaper withsliding table and have my finger joint blades. Plus bought a 4” tall spindle cutter so I can copy pattern for my wood.
  30. mamllc
    mamllc
    I have never considered myself to be exceptionally talented. I know that not everybody can do this kind of work, but I think a lot more can than know it, they just haven't tried. Good to see you jumping in, best of luck to you!
