Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. Tim
    Tim
    from KCMO
    Updated to include intake and exhaust measurements.
    ECDF0EDB-CE4B-4D7C-88C9-2BBC4660AEA5.jpeg Mcculloch vs57 dimensions. measurements in inches
    patmanta, Stogy, drdave and 4 others like this.
  2. Six Ball
    Six Ball
    from Nevada
    Disclaimer: Don't use my measurements to build a supercharger out of anything but cardboard. :eek:
    Stogy, drdave, brEad and 4 others like this.
  3. Tim
    Tim
    from KCMO
    ^ what he said lol
    I posted it and included to words I was using to search for that info simply because it doesn’t seem to really exist out there and if I was looking for it I’m sure there’s more that are as well
    Stogy, loudbang, Thor1 and 1 other person like this.
  4. Tim
    Tim
    from KCMO
    Well I had time between appointments and ran over to @Joe H house this evening. Boy was I impressed! His pickup is so.. just perfect. Clean, neat and extremely well executed.
    it’s the kind of truck I could spend hours looking at the little details. All the hand made bits and pieces. I was thoroughly impressed and I’m super happy to have got to see his truck and talk to him tonight.
    On top of that the flanges he gave me look great and I’m looking forward to putting them to use soon.
    think he also sold me on the idea of an O2 sensor for an air/fuel gauge for tuning.
    I had a mask on but hopefully my giant smile was obvious :)
    Stogy, drdave, brEad and 3 others like this.
  5. Tim
    Tim
    from KCMO
    Dang a 6 would be a tight fit! A653E917-A127-4DE3-9DFA-A02D4607A0EF.jpeg 08C8B5A7-4053-40D8-808E-7D1DF9A6DCD8.jpeg
    Stogy, drdave, Thor1 and 4 others like this.
  6. Tim
    Tim
    from KCMO
    Now that’s a sneaky blister to clear a magneto if I’ve ever seen one! 455AD14A-20D0-4D4D-8063-2A92DE7409B5.png
  7. Tim
    Tim
    from KCMO
    Man these flanges are going to be perfect 0C1CCD51-068E-4452-8255-5A391101FF81.jpeg
  8. Tim
    Tim
    from KCMO
    250 gasket for mocking up while doing laundry. Pretty dang close! It looks like my guess of two cuts and one weld and pretty close.
    792853D4-C4EA-4958-804C-BB85F8317A20.jpeg the only thing I’m seeing that’s off is the very last hole for the stud is further back from the port on the 153 compared to the 250 but it may be close enough to slot because the flange has a bunch of room DE96A5F5-2733-4ACE-90FC-A529E4B54369.jpeg
  9. Six Ball
    Six Ball
    from Nevada
    Yeah, that back one is the kicker but pretty easily dealt with.
    loudbang, Thor1 and Tim like this.
  10. Tim
    Tim
    from KCMO
    Yeah I’ve got an idea that shouldn’t be to much h***le
  11. redzula
    redzula
    You misspelled "to clear a supercharger*"
    Sent from my rotary phone using The H.A.M.B. mobile app
    Looks like your on the right track with the flange. Modifying something that exists should save a boatload of time over scratch making one.
    loudbang, drdave, Thor1 and 2 others like this.
  12. Tim
    Tim
    from KCMO
    Originally I was going to modify a SBC flange but this is waaaay closer A55A3C4F-3A4D-4996-8196-4C4A51BD09EB.jpeg put the head lights back on and all the rust dust from the bulbs themselves got all over my clean buckets. Oh well :p ECED2A3A-F154-4103-AE1D-A5E65B424495.jpeg
    Chipping away one 2 minute chance at a time
    brEad, loudbang, Stogy and 3 others like this.
  13. Tim
    Tim
    from KCMO
    Quick question @Six Ball does your engine have dowls for the ends of the manifold set?
    I noticed today that the very first and last studs in the block are actually just dowels with no threads. They have a nice tappered/ beveled tip so I don’t think it’s something that got snapped off.
    Stogy and loudbang like this.
  14. A/F gauge is a great idea
    Tim and loudbang like this.
  15. Six Ball
    Six Ball
    from Nevada
    I think that stock they all had dowels on the ends, sixes too. I don't think sealing was much of a problem because the intake & exhaust manifolds were cast iron and bolted together. The dowels helped hang the heavy setup while you fiddled with rest of the mounting hardware. With the less ridged header flanges I have always used bolts or threaded studs on the ends. Studs still let you hang the exhaust while lining up the rest.
    Stogy, Tim and loudbang like this.
  16. Tim
    Tim
    from KCMO
    @Six Ball yeah that’s what I kinda figured. Going to leave them for mock up and decide whether they get a stud or a bolt based on how hard it is to fit. I lean towards a threaded stud because it’s generally easier to fish a nut onto a bolt than blinding trying to get a bolt threw and lined up.
    @Tman yeah he told me about how he used his and it just seems to make since if I’m going to drive the wheels off it. Still back and forth on a permanent gauge or not.
    And if permanent if it’s visible/ under the dash with a swing down, on the fire wall etc
    maybe I’ll stick a boost/ vacuum/ air fuel set of gauges in the header above the windshield where you don’t notice it at first but would be very easy to peak in and see while tuning.
    I’ve got a couple “not period correct” things I’m planning to hide there. Might make them hide behind the sun visor with it’s up or something similar
    Stogy, drdave, Shadow Creek and 3 others like this.
  17. drdave
    drdave
    The "new" 261 for my Chevy had pins on the ends of the manifold set but the 235 that came out had bolts. I had the machine shop remove the dowels and thread the holes for bolts/studs.
    Stogy, loudbang, Tim and 1 other person like this.
  18. Tim
    Tim
    from KCMO
    I’ve heard that some of the dowels were screw in
  19. Tim
    Tim
    from KCMO
    Some times ya just gotta sprint to the garage, cut some **** up, and run back into the kitchen before the pit boils over lol. 8D7CF8B2-63C5-456E-8939-C297BA604D9E.jpeg marked the cut lines. Dead center of the bolt holes. This is how the gasket was cut but it made the most since to me to line everything back up so I did as well. B6DA9C0B-05B9-4D41-A40C-C1AD741D50C0.jpeg I was thinking if I slot the hole on the end to reach the Dowel that if I want to capped I can cut this hole into a U and weld it on. AB756778-CB0B-4E3E-8A17-92D2C6F9CEEA.jpeg well here goes A89234D5-FE03-4FCD-8427-2B8C47AD2EAC.jpeg 42F20140-9022-4A4A-B317-72B03BB58C8F.jpeg fit pretty dang good! I cut it just like the gasket was but the flange has flat edges top and bottom for the most part and I found when I lined them up that last port will line up perfect when the gap is closed. The hole doesn’t line up and will need dropped though. I guess if you had different tools or process you could have cut around the correct hole and jig sawed it all together but even given a second go at it I think welding half a hole shut and adding a half a hole is going to be less effort and time in the end 66B338AD-7524-416C-8A41-2689F184608A.jpeg I am thinking the back is going to need a little added material once it moved forward. After wiggling it into place I think a slot is going to work better than a hole so I’m thinking add some length to the tangs and use a fat washer.
  20. Tim
    Tim
    from KCMO
    95924882-DCAD-4AFC-A29F-8C11ACD4258E.jpeg Quick couple Of minutes in the vice and I’ve got it closer than I thought I would.
    I went back and forth between smashing it about 3/4 deep and 1/4 deep.
    basically when round it was close top to bottom with a little room to wiggle but side to side no go.
    so I smashed it side to side at 3/4 to fit and then more or less moved down and pinched the top to bottom into a squarish shape at 1/4. Which let the first smash side to side more or less stay put.
    bends very easy in my big vice. I think once you figure it out you could likely do one in minutes.
    74B15AC6-7EA5-4479-83FA-97139FBD6192.jpeg It actually fits in the long narrow openings so I’m thinking this left over piece of flange could be used for a little bit of a hammer form.
    And if not it’s handy to be able to test fit a primary with out fighting it onto the car first.
    ryans going to weld the flange into one solid piece tomorrow night and then once it’s back I’ll start fitting primaries.
    got a new battery and a parts to finish the long ago started windshield wiper install in the 46 so I’ll probably shift to that while I’m waiting on the flange to come back
    kidcampbell71, Stogy, brEad and 7 others like this.
  21. Tim
    Tim
    from KCMO
    When I dropped off my flange for Ryan to weld back together he gave me back the hood I had him drive the pins out of so the side are free.
    It was stubborn and he’s got more time than I do at the moment so had him break it down.
    Don’t know if I’ll use these ones but eventually I’d like to be able to run a full stock hood, jist a hood top, just hot rod louvered hood sides or a full hood with hot rod louvered sides.
    this will let me at least mock those looks up and get some ideas for building a hidden spring loaded dead bolt useing the stock hinge pin loops. Something like this one shown.
    it would let me have the holes for the dead bolt pins be the same for just the top or just the sides. The handles would be threaded so I can slide the lock ***embly out and stick a stick pin in and run it as a second complete hood.
    I need to see how thick the metal is on this set but I’m considering just keeping the handles, latch points and the hinge area and but welding on a whole new sheet full of louvers instead of trying to remove the stock louvers, fill the hole and then louver that. This hoods pretty ****ing shot so if I’m gonna mess with it it’ll mostly be for bits and pieces 6482E51A-55CE-4904-8116-3433DBA75C8E.jpeg 74A6BB2A-CE22-4D9A-B937-A6101B0A88B8.jpeg 9B8E84A4-F7CE-4C86-A627-3C48B445FA16.jpeg BDFD2B96-C02C-42B7-A2E0-BDE789B3C696.jpeg 401F3B05-0C2B-4CD5-BDE3-8900D5FCB65E.jpeg last one isn’t a stock hinge or spring loaded but it’s a thought
    Stogy, loudbang, Six Ball and 2 others like this.
  22. You need to make some T dollies. [​IMG]
    Then order the book. It covers header fab. [​IMG]
    Stogy, loudbang and Thor1 like this.
  23. Tim
    Tim
    from KCMO
    Read it , made em ;)
    Stogy, Tman, loudbang and 1 other person like this.
  24. brEad
    brEad
    Getting close!
  25. Tim
    Tim
    from KCMO
    Photo dump of the “new” running boards. I’m missing one outside trim piece but since I’m going to paint them I can probably make or find a rough one to use.
    FEE80C5F-43AF-4048-A135-13B7C4610BE5.jpeg 915B59C2-AC94-4364-B5E0-B4D9832C5335.jpeg 8BDCD03C-00E0-4CA7-B381-FBC6EDB4C893.jpeg 1D996947-65B0-486D-9651-83BAF28A3412.jpeg 7D86E37E-EF74-44F9-B2A2-6E218E7BC356.jpeg CD4F0B54-5629-4413-AEB6-CC0CD7BE3D27.jpeg 09768402-9CC1-467C-882B-D1060E8A5C27.jpeg 0C45202E-A896-47CC-BFCB-B8AA3C1BFDF0.jpeg 86F2AE49-9811-420F-98EF-945F5BD3A6A2.jpeg 82ED166D-E316-4B2C-A7AC-7D3710129BDF.jpeg 698F06A7-7DC7-464D-8B63-C789535F0290.jpeg
    kidcampbell71, Stogy, drdave and 4 others like this.
  26. Six Ball
    Six Ball
    from Nevada
    They are pretty straight you'll get them fixed. I love hot rods with mud & snow tires.
    Stogy, Thor1, loudbang and 1 other person like this.
  27. Tim
    Tim
    from KCMO
    Haha @Six Ball they really are growing on me. Things are so stiff the last time I put air in the tubes I found they only had 3 pounds in them lol. Tire wasn’t compressed at all
    Stogy, drdave, Thor1 and 1 other person like this.
  28. Six Ball
    Six Ball
    from Nevada
    Funny thing, My pickup has a slow leak in the right front. I was putting air in it at my son's and he decided to check the rest. The left rear was about like yours. Really stiff m&s tires. I really like how much better it handles with all 4 tires aired up.
    Stogy, drdave, Thor1 and 3 others like this.
  29. Tim
    Tim
    from KCMO
    I bet lol
  30. Tim
    Tim
    from KCMO
    Buddy made me a nice hardwood steering column wedge and stained it for me. Super pleased with it.
    15DB3B1A-CA6A-4D3F-AC70-6FD79F6E2D13.jpeg Kept the holes small so I can run a small pilot hole drill threw it all so the dash holes line up.
    got the correct welding rod for the header/ intake flange yesterday so should have that in the next week or so and I can get back on the header project
    drdave, Stogy, Thor1 and 1 other person like this.
