Technical Can I Thin a Large Flat Washer?
Discussion in 'Traditional Hot Rods' started by HuskerNation, Aug 7, 2020.
  1. HuskerNation
    HuskerNation
    I need a 1/16” thick washer to use as a cam thrust washer but have been unable to find anything. I did however find 1/8” thick washers in br*** which could work if I can somehow thin them down. Not having a lathe or mill, I’m wondering if there is anyway I can actually accomplish this?
    Previously there was a phenolic type washer that broke apart:
  2. badshifter
    badshifter
    Some br*** sheet stock from McMaster Carr or similar source and 2 hole saws or better yet ch***is punches, and you have a 1/16" thick washer.
    What engine?
  3. HuskerNation
    HuskerNation
    The engine is a 37 Hudson 212ci 6cyl (splasher). I’d done an in car re-fresh of the engine but didn’t realize the problems these engines have with eating the old OEM cam thrust washers. I was originally hopeful I could cut the washer & slip it into place without completely removing the cam but I’m not so sure it’s really possible.
    If the cam has to come out the head comes off, valves & lifters out & intake off,at minimum, just to get at everything. But if the cam comes out, I’m not putting it back without a performance grind put on it & bigger intake valves at minimum. Which means it will be spring before she’s on the road again and that is what I’m trying to avoid.
  4. Boneyard51
    Boneyard51
    This is kinda backyard, but take a three inch piece of round wood , a little larger than your washer and drill a hole about 1 inch deep in it with a about 5/16 drill bit as close to center as possible. Then glue the bit into the wood. The lock your drill press and dress the lower surface square in relationship to the base of your drill press, with a sharpen chisel. Then push that down onto the base with sand paper there, and turn till true. Then glue your washer to that surface. Place sand paper on your drill press base. Press the rig down while turning. You should have a fairly even straight thinner washer. May take a couple sheets of sandpaper!
    Bones
  5. HOTRODPRIMER
    HOTRODPRIMER
    Have you tried ACE hardware? HRP
    '51 Norm likes this.
  6. partssaloon
    partssaloon
    You want to look for a Machinery Bushing. They come in thickness' from 10ga. to 20ga.
  7. 62SY4
    62SY4
    from Irwin, Pa
  8. ekimneirbo
    ekimneirbo
    Instead of a washer, are the surface areas around the cam drillable (thick) where you could drill additional holes and tap them? If so, you could make two separate pieces. Horseshoe shaped on one end and just square (whatever fits) on the opposite end. Then you could just slide them in place and screw them to the block. Your picture is not clear enough to tell if this would work or not, but it would sure make future replacement easier. I'd hate to think I'd have to do that much dis***embly every time the cam spacer fails. You just make a hole with the right size hole saw in a thin piece of br***,alum,steel plate and then cut it in half at the center of the hole.
    Also, I would think twice about grinding a rare cam like that for a race profile. You make the base circle smaller and the lobes and then you have to find lifters that work in it and take up the slack you created. The cam may need some tlc, but I'd be cautious about what I did to it.
    squirrel likes this.
  9. HuskerNation
    HuskerNation
    Some great ideas! I should have stated at the beginning, the head of the cam is 2.5” across. So I can do an OD of 2.5” or maybe bigger with an ID of a tad over 2.0”.
    Thats is an interesting idea to split it & perhaps drill & tap the block to hold it in place. I’ll have to keep an eye out for 1/16” material or some how grind the br*** washer I have thinner.
    Okie Pete likes this.
  10. HuskerNation
    HuskerNation
    I’ll try some more pictures to see if they help.
    Okie Pete and kidcampbell71 like this.
  11. HuskerNation
    HuskerNation
    As you may have seen the heads of the two bolts were hitting on the back of the cam gear, as the cam moved in & out. (Circled in red)
    Your right, I should really find another cam & lifters to send off so I don’t screw up the only cam I have.
  12. RichFox
    RichFox
    If I was doing it, I would go with the br*** shim stock and hole saws. If you don't have hole saws do you have friends?
    tomkelly88 and kidcampbell71 like this.
  13. Kiwi 4d
    Kiwi 4d
    Steel shim spacers should be readily available in variable thickness.
    nunattax and VANDENPLAS like this.
  14. hotrod37
    hotrod37
    from Indiana
    Could you cut along the cir***ference (slight angle), and just “screw” it behind the end of the cam? (Like a spring)
  15. If that phenolic was factory, I'd try a square piece of br*** or bronze with just a 'U' cut into it. You won't have 360 degree coverage, but the gap will allow oiling and you should end up with about 220 degrees of coverage or so. With a little fabbing of new tabs, you can probably even use those existing two bolts to retain it.
    harpo1313 and X-cpe like this.
  16. ekimneirbo
    ekimneirbo
    What I would like to see is a view on a slight angle where I can see the space or area between the raised area on the left and the surface behind it. Is there a gap there? Is the surface to the right of the cam the engine block or part of a housing? The screw heads rubbing on the back of the gear needs to be dealt with, but that might have been because the phenolic broke. It also might help if there is a way to direct more oil to this area to help resist wear when you subs***ute a different materials for the phenolic.
  17. blue 49
    blue 49
    from Iowa
    I'm thinking a transmission shop might have a thrust washer that would work for you.
    Gary
  18. deathrowdave
    deathrowdave
    from NKy
    NP 205 transfer case has 2 on the center shaft , close to what you need
  19. gimpyshotrods
    gimpyshotrods
    https://www.grainger.com/product/BL-Thrust-Washer-35TY56
    Okie Pete and fordflambe like this.
  20. gimpyshotrods
    gimpyshotrods
    "THRUST WASHERS
    THRUST 1 1934-52 HUDSON 8, 1934-47 HUDSON, TERRAPLANE 6 CAM THRUST WASHER - THIS ITEM HAS USUALLY DISINTEGRATED BUT IS NECESSARY ON ALL THESE SPLASHER ENGINES- $20.00"
    https://www.hudsonmotorcarco.com/parts.htm
  21. nunattax
    nunattax
    what i would do.since the original part is available i would buy one of those maybe two.you could get back on the road straight away.the shim is wearing from lack of lubrication can a replacement be machined from improved (self lubricating )material from mcmaster carr.if its worth fixing its worth doing it right.clean the block thoroughly,it looks from the photos that there are small pieces of crud floating about. new oil and filter time.
  22. gimpyshotrods
    gimpyshotrods
    kidcampbell71 likes this.
  23. Mr48chev
    In answer to the original question. I have "polished" washers/spacers down by laying a sheet of sandpaper or emery cloth on a flat piece of gl*** and sliding it on the abrasive paper until my fingers ached.
    VANDENPLAS, Okie Pete and Nostrebor like this.
  24. RichFox
    RichFox
    So how did this ever come out? Did you buy the washer from Grainger? Or the replacement? I could make one from br***. But not for $7.
    VANDENPLAS likes this.
  25. lippy
    lippy
    from Ks
    Me too, what happened?
  26. HuskerNation
    HuskerNation
    Ok, I just ****oned it up tonight for the second time in a week. Hopefully this is the end of it!
    So I took the angle grinder to a br*** washer & screwed a deck screw into a 2x4 with the washer around the screw then used the grinder. With a fair amount of pressure I could keep the washer spinning to a manageable amount & it came out to 0.070. With some sandpaper work on it it was a real nice 0.068” & the new OEM style replacement was 0.069”. I took the group’s recommendation & cut it “U” shaped. I drilled & tapped a hole at the edge of the washer, then had to bevel the contact of the 8-32 screw (Loc***e on the screw to hold it tight) on the washer for it to lay flat. I outlined the cam head against the washer so I’m close to 2/3 of the cam head supported by the br*** washer.
    Next I removed the two bolt heads that we’re hitting the back of the cam gear took the grinding wheel to them both & reinstalled them. After taking off 0.040”, if I remember correctly.
    Everything looking good i ****oned up the timing cover & installed the balancer on the crank. When I ran it, the rattly noise was gone but now I had a whirling & whine noise! Ugh! So after adjusting the valves & not seeing improvement off came the timing cover again. At this point I thought it was the aluminum cam gear not quite meshing with the crank gear, since I swapped the cam gear to a newer one. I pulled the cam gear & was going to ****on it up with the old cam gear when I had some divine intervention & decided to re read the instructions for doing the aluminum cam gear retrofitting. As I read it I found an area I wasn’t sure was done. That was to grind back the curve next to the cam head to the back side lip cam slide down where it needs to be. Well looking at the area that should have been ground, I could see it hadn’t been done. Looking closer I noticed a grove next to it that wasn’t as big as it was now. Checking pictures I took previously showed I was correct, the grove was deeper & longer as the aluminum gear was rubbing on the steel, thus giving me the whirling/whining sound.
    So instead of removing the front plate from the block & grinding it, I chose to grind the back of the aluminum cam gear instead, taking off 0.050”. I only needed 0.020-0.025” off but decided to take a bit more. A playdoh test showed it wasn’t hitting anymore. However the bolt heads I ground were very very close to hitting the spokes again. Out came the locking washers & in went Loc***e to hold them in place (note the bore scope picture below was before the washers were removed). I next used my bore scope to make sure it was all good back there & it was!
    So with new safety wire on the cam bolts she was ready to put the new gasket on with the timing cover. She’s once again ****oned up and hopefully fully correct now. Tomorrow I’ll run her & see how it goes!
  27. HuskerNation
    HuskerNation
    In this video you can hear that whirling /whining noise. I believe it was the aluminum cam gear rubbing on the steel plate. Or I’m hoping that’s what the noise was & tomorrow when I test it it will be gone!
    VANDENPLAS, dwollam and egads like this.
  28. gimpyshotrods
    gimpyshotrods
    Fingers, toes, and eyes crossed!
  29. HuskerNation
    HuskerNation
    I just started it up & without valve covers on or coolant in the engine, she’s never sounded so good! I’m in complete shock & just as giddy! I truly can’t believe it’s finally running well... not 100% new engine rebuilt perfect but so much better!!!!
    I’ll post a video later, gotta run it again because I’m in disbelief & then check valves before putting her back together again.
  30. HuskerNation
    HuskerNation
    She still has side (valve) covers off & no coolant in her & while not perfectly quiet, she’s so much better now that all the repairs are done & done correctly!
