Technical ***August 2020 Banger Meet Thread - More of the Same***
Discussion in 'Traditional Hot Rods' started by Jiminy, Aug 1, 2020.
  1. Jet96
    Jet96
    from WY
    Posted by Flatred53 8758BE81-1EFB-4993-9734-5295920E22C2.jpeg DD403FD4-3B9F-406B-9257-332278DCD0BA.jpeg
  2. railcarmover
    railcarmover
    it depends on how the vac advance is set up,some catch their signal above the throttle plate,some below.id guess your Mallory ports below the carb..the only above the ****erfly ported carb that I know of is a late flathead holley 94..8BA EAB models..
  3. 97
    97
    I have seen the instructions for Mallory distributors all the way back to the first one on Holley's site . You need the model number from the name plate . Cant find it now but here's one for a YL series.
    https://static.summitracing.com/global/images/instructions/maa-29015.pdf
    Jet96 likes this.
  4. V4F
    V4F
    from middle ca.
    no offense , but is all that a cooling system for oil ?
  5. Jet96
    Jet96
    from WY
    Cooling or heating I really have no idea
  6. V4F
    V4F
    from middle ca.
    someone put in alot of work ........
  7. Probably for not much result. I cut one up lately, yuck a mess..........
  8. V4F
    V4F
    from middle ca.
    looks to be small tubing probably not much flow if any
  9. nutrocker
    nutrocker
    Finally got the motor back together after a long wait for the custom cam due to COVID.
    Still got a bit of work before fire up time but it’s getting close.
    The roll bar is only there so I can compete at VHRA Pendine Sands a bit later in the year. 5DF57E38-0645-46E9-A094-E974C9C5724C.jpeg 51103B5A-7A24-4422-B94F-5123BDF1B92D.jpeg 1F3E387A-D992-42DE-9EEC-A60C9ED19DB5.jpeg 48053D17-2E9C-424D-9F9D-2817812AB394.jpeg 8BF47F7D-D120-4BF1-8A71-34A001383287.jpeg 84E75780-C4EE-4C09-96F3-FEB0BC2C44FF.jpeg E5CA621D-077C-4612-B778-4A04D0D3A4A7.jpeg 422A6CBD-DED1-4B26-85D9-CF5172BBA270.jpeg 08A21208-28DD-4F31-ACD3-87FD78C4D889.jpeg 77C5EC4E-01DF-4B4E-909A-59E4C88327FE.jpeg 1B8B75A1-A992-4E08-8572-62CACC38B681.jpeg 90E067DE-6A63-474A-B234-B3947D3AC700.jpeg 2551D5F8-99BE-4F09-9B25-4C723DA877FB.jpeg 8156279B-AB15-406C-881F-EB5AE970574A.jpeg 52053375-18B6-441E-8747-137C88BA6FEB.jpeg
  10. Mental the first time I saw it. Still is.
  11. railcarmover
    railcarmover
    "There's a hole in daddy's arm where all the money goes"
    Covid took John Prine...
  12. Kiwi 4d
    Kiwi 4d
    Holy smokes @nutrocker my eyes hurt now . Just scanning all the pictures trying to take it all in as there sure is a lot going on and all very nicely detailed as well.
    You are going to have a blast driving that little T for sure.
  13. 62pan
    62pan
    Damn, that's a lot of plumbing for oil lines. Why is there oil going to the head and rocker covers ?
    kb9jlo and barrnone50 like this.
  14. nutrocker
    nutrocker
    the ones going to the head oil the rocker shafts and the ones in the rocker covers oil mist jets. This gives a mist of oil onto the valve stem and rocker tip.
    GuyW, kb9jlo and 62pan like this.
  15. winduptoy
    winduptoy
    Dang
    Sent from my XT1585 using The H.A.M.B. mobile app
  16. winduptoy
    winduptoy
    @nutrocker
    Overkill for a grocery getter.
    Bet you shop one item at a time so you can run back and forth lots.
    Ice cream still frozen when you get home?
    Shutter Speed, burl and Jet96 like this.
  17. The Wade looks like it was made for that use Nutrocker,
    Is that an oil pressure light hanging on the carb inlet?
    Pendine certainly draws some wonderful machinery.
    Love the plumbing.
    kb9jlo and Jet96 like this.
  18. railcarmover
    railcarmover
    Yup...he was a great song writer
  19. poshdbs
    poshdbs
    Wow, now I understand all the pulleys!
    kb9jlo and nutrocker like this.
  20. nutrocker
    nutrocker
    Yes, that’s an oil warning light hanging off the carb scoop. Reason being is if I have the full tonneau cover on while driving I can’t see any of the gauges. Oil pressure is a must see item on this engine.
    kb9jlo, Old Dawg, Jet96 and 1 other person like this.
  21. ^^^^^ Goes without saying that, a bit going on not to be looked after
  22. Nutrocker,
    nice ride, drive the hell out of it!!
    What is the tank in front of radiator?
    J
  23. nutrocker
    nutrocker
    Thank you.
    It’s an oil tank as it’s dry sump. I’m not overly happy with it out front like that. Makes the car look a bit weird.
    Once the motor is all sorted and it’s done a fair few miles I’ll look at making the whole car look better.
    kb9jlo likes this.
  24. Good on Ya! the car looks pretty good as it sits.
    Let us know how that motor runs, J
    nutrocker likes this.
  25. WHOA! that'll be a REAL runner! Ya! Leave that oil tank right up front: It'll keep it cooler & it's tall so it'll allow the oil to rid itself of frothy air bubbles How stout is the bottom end? (you'll need it running it hard!)
  26. nutrocker
    nutrocker
    Bottom end is pretty tough. I think the weak areas are the head gaskets at 12:1 cr and the lower section of the block.
    Outback, 282doorUK, kb9jlo and 5 others like this.
  27. nutrocker,
    if that bottom end lets go, shoot me a call, I might have the solution.
    John
    kb9jlo, Outback, ottoman and 5 others like this.
  28. nutrocker
    nutrocker
    Is that the new block or a girdle with the extra mains. I can’t run the new block as it takes me out of Vintage cl***, but I can run the crank with a girdle.
    Outback, kb9jlo and poshdbs like this.
  29. Nut rocker
    It is girdle on original block
    I am in same place no new blocks allowed
    J
  30. winduptoy
    winduptoy
    Well, @patina steve bettered the record on the salt today some 11 mph in a banger belly tanker.
    The car is in impound and we'll see if he backs it up tomorrow. Then I can tell you the numbers. I got the call and was in a drug induced sleep so I don't want to say...keep your fingers crossed for our buddy
    guitarguy, G Baese and Jet96 like this.
