can i use a wood band saw to cut metal?
Discussion in 'The Hokey Ass Message Board' started by forsakenfew, Dec 23, 2004.
  1. gatz
    gatz
    Thought I'd clarify this helpful post....the original font was rather small.
    FORMULA TO FIND S.F.P.M. IS:
    MOTOR R.P.M. X MOTOR PULLEY DIAMETER / DRIVEN PULLEY DIAMETER X BAND SAW WHEEL DIAMETER X 3.1416 / 12 = S.F.P.M.
    I changed pulleys on my motor and driven pulley on a Craftsman wood saw. Works great. I used a 2" drive pulley and an 8" driven pulley...but i bought a 1.5 drive pulley and a 9" driven pulley to cover just about anything. Hope this helps.
    You can buy bi-metal blades cut and welded from MSC.
    For this 14" Walker-Turner, the blade was #03166360 8' x 1/2" x .035 "wavy" made by Irwin.
    Suitable for metal, not wood, although they will work @ higher blade speeds.
    Price check was $43.29. They'll last a long time with proper care.
    I bought this Metal/Wood saw at a State Auction many years ago for $285. I had been looking for one for a long time.
    It has a backgear + a 4-step pulley to gear box arrangement , much like a small South Bend lathe.
    At the auction, someone had purposely put the saw in direct-drive and back-gear at the same time to make it appear as though it were broken or jammed up.
    After winning the bid, a guy comes up and made offers to me in increasing amounts, all the way up to $425. I turned down the quick flip and then asked if he'd help me load it in the pickup.
    He did, and when I left the auction, got to thinking..."I bet it was him that did the gear trick" LOL
    You can also buy cutting wax in a paper tube.
    Here's one that's not too much money; MSC Part #: 35438217
    Fastenal carries some too, Fastenal Part No. (SKU)3126544
    Speeds and Feeds charts are plentiful on the 'net.
    Here's one...
    https://www.sawblade.com/band-saw-blade-speed-and-feed-chart.cfm
  2. gatz
    gatz
    I put new "tires" on it shortly after buying it.
    These are urethane tires. Very tough. Rockler sells them.
    It's worthwhile to have a mounted brush under the table to clear metal chips before they embed in the tire and build up.
    What can happen is that the saw blade rides atop the chips and makes it easier come off.
  3. clunker
    clunker
    from Boston MA
    That would work for him, if he could find one. There are tutorials on line how to build a gear reducer too. Another thing to keep in mind is that the metal shards will eat the rubber tires on a saw designed for wood in short order.
    If you Google "Primo band saw" the auction where he purchased it pops up. Looks like a serious saw, saw he must have some big projects in mind or else there are a lot of cheaper/better alternatives.
    With the new rules in effect I'm sure a mod will delete this thread. It would be worth it for the OP to take it to GarageJournal, though. Here's a thread on the gear reducer you are talking about with part #'s and other info.
    https://www.garagejournal.com/forum/showthread.php?t=144536
  4. blowby
    blowby
    from Nicasio Ca
    Mine was easy, just added a BIG pulley. Original wood pulley still behind. 0814170710.jpg
    bct and clunker like this.
  5. Uncle Ronn
    Uncle Ronn
    from Modesto CA
    Check out Ryan's post on The Garage Journal
    Converting Craftsman Band Saw to D C Power
    Ronn
  6. Uncle Ronn
    Uncle Ronn
    from Modesto CA
    search
    Vintage Craftsman Band Saw DC Conversion
  7. stanlow69
    stanlow69
    With all this talk about gear reduction. Just go to Harbor Freight and buy a speed controller for $20. Bought one for my router and it works great. And I never have any luck buying tools there. They never last.
  8. jimvette59
    jimvette59
    You should slow it down to about one foot per second. Jim T.
  9. 1946caddy
    1946caddy
    from washington
    Harbor Freight.
  10. powertoolsguyd
    powertoolsguyd
    The main difference is metal cutting band saws run the blade slower than wood cutting saws.
    Band saws for woodcut very dense materials. It generates less heat and in this way can be cut with far higher blade speed. You can cut faster. The wood band saws have one speed -fast.
    You can saw any wood on a metal band saw, if you have a nice shape (carbide tipped or diamond) blade.
    The metal cutting band saws are constructed more robustly. The metal has to cut far denser and tougher materials.
    For cutting these materials need to generate
    more heat, that means you have to slow things down to the right speed for particular materials.
    It has an adjustable 2-speed gearbox. Most have a chart that shows what speed should to use for what materials. You usually have a stronger blade (wider and thicker).
  11. wbrw32
    wbrw32
    A NEW YOUNG GUY WITH NO POST COUNT,,,GROW UP
    kidcampbell71 likes this.
  12. grumpy65
    grumpy65
    Wtf ??? ****-fight over a 16 year old question.o_Oo_Oo_O
    Turn caps lock off and relax.:confused::confused::confused:
  13. wbrw32
    wbrw32
    AT ,,MY AGE,,I NEED CAP LOCK TO SEE THE WORDS BETTER,,Mr Grumpy
  14. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    or...
    ...you could just increase the font size and not annoy others.
    grumpy65 likes this.
  15. grumpy65
    grumpy65
    OK , POINT TAKEN.
    But why so cranky with new guys? You flamed me when I was new, and you seem to make a habit of it.
    Relax, accept, teach, guide.
    Irish Mike and VANDENPLAS like this.
  16. Flathead Dave
    Flathead Dave
    from So. Cal.
    seb fontana likes this.
  17. Lloyd's paint & glass
    Caps don't bother me either, but old men that think their way is the only way and everyone else is stupid sure does. Get off the computer and get to work if you know everything. Don't hate me cause I'm young
    VANDENPLAS and blowby like this.
  18. Mr48chev
    It never ceases to amaze me how many first time and probably only time posters join to share their "expertise" on threads that have been dead for years.
    VANDENPLAS likes this.
  19. prpmmp
    prpmmp
    It never ceases to amaze me that the first time poster has to start somewhere and has a good explanation but gets flamed anyway!! So we just accept the same old high posters changing there starter post with different wording of useless garbage!! We want new blood to carry on the tradition but we don't let them in!! If you want to be a ***hat go over to the bullet, there is plenty over there!! Pete
  20. jimvette59
    jimvette59
    I did it with a speed reducer and the proper blades. There is no easy way.
  21. OLSKOOL57
    OLSKOOL57
    In our piping fab shop in 1996, Milwaukee Portaband saws worked extremely well.
  22. The keyboard commandos can be a bit much, but this is the kinder, gentler HAMB.
    31hotrodguy and grumpy65 like this.
  23. winduptoy
    winduptoy
    I always thought it depended on what kind of music the band plays.
    I've got a lot to learn still
    Rock and roll on...
    Sent from my XT1585 using The H.A.M.B. mobile app
  24. grumpy65
    grumpy65
    Ok, I didn't mean to start anything with anyone.:(
    This place really is a gold mine of relevant information, opinions, and all things good about traditional rodding. New guys should always be welcomed respectfully, and guided gently to understand what the HAMB is all about. A little leeway and tolerence with at***udes and points of view should be seen as a good thing. I would not be here if we were all expected to build and drive the exact same thing. Better things to do.
    How about we all back off a bit and chill out. I was only trying to point out that ripping into newbies is a bit lame in my view. They will work this place out for themselves quickly, and decide if they want to stay or not. Just remember, it will get real lonely around here if none hang around.............
    I was not trying to rally a lynch mob for @wbrw32 . Again..........relax.:cool::cool::cool:
    So, bandsaws anybody ???
  25. X38
    X38
    **** me, you are a new guy! 15 years back you would have had "your *** handed to you on a platter" as was commonly said, for a comment like that.:eek:
    Unless of course, you're being sarcastic.
    VANDENPLAS and grumpy65 like this.
  26. grumpy65
    grumpy65
    Oh come on. Surely I have moved up to "relatively new guy" by now. Looks like I will be a really old man before I get to be an "old guy". Hope I can manage to keep my **** together that long. :D
    Who, me, sarcastic ??? **** no. I would never poke the bear just for fun. ****er wouldn't melt in my mouth. :rolleyes:
  27. bigdog
    bigdog
    Nope, next step after newbie is "grenade inspector".
  28. grumpy65
    grumpy65
    Search function tells me I have been a "grenade inspector" for a little while now.
    This being post #170, only 230 to go to be a member.........woohoo.
    Will do my best to handle the **** until then. Think I can manage. ;)
    31hotrodguy likes this.
