1952-59 Ford Let's see pics of your engine compartments!
Discussion in 'Off Topic Hot Rods & Customs' started by evintho, Aug 11, 2020.
  1. evintho
    evintho
    Like the ***le says. I don't care if it's filled with rats nests or it's a 100 point show stopper! Post 'em up! I'm always looking for ideas!
  2. welderdave562
    welderdave562
  3. TomDobbs
    TomDobbs
    Sanitary!
    welderdave562 likes this.
  4. Texas57
    Texas57
    IMG_4903 (1).JPG An older shot of mine with the hood off. Some "different approaches" that may have gone unnoticed:
    The battery tray was custom made and sunk into the inner fender about 3 1/2-4" to make room for the big heads/valve covers. It was originally on p***enger side where my air filter had to be.
    The windshield washer reservoir/pump is a nice little neat unit off a 2000ish Mustang, and yes, the washer ****on on the multi-function steering column switch is operational. Washer nozzles are Camero (?) headlight units.
    The Jetta power distribution box is mounted on the inner fender just behind the battery. Special clamps have to be made to mount it. I cut up a household door hinge that was the right size to fab the clamps. I also have one that can't be seen in this pic that is also on the inner fender, but below the outer fender in back. The Optima 4 post helps keep the multi-connections neat.
    The noisy hood hinge springs were replaced with hydraulic units with the added advantage of having more room to run the A/C condenser lines.
    Firewall had 26 cavaties/holes filled...no wiper motor on firewall, it was moved to inside the cowl. No hood latch.......forward opening hood made it safe/feasible to just use hood pins.
    Engine originally had coil packs and spark plug wires. I changed it to a simulated coil on plug (COP) that was factory standard in '97. Really cleaned up the engine compartment with that stuff gone. "Simulated" meaning it isn't a true COP. The computer in the COP engined cars sends out 8 signals. On the original setup, my computer sent out 4 signals, and the original coil packs (4 total coils)sent out the signal to 2 cylinders simultaneously. I just changed the wiring so the wiring splits up each of the 4 signals to 2 each for the 8 signal total. Valve covers off a '97 4.6 dohc were used for the conversion.
    Mustang Cobra (2002) hydroboost unit for the brakes........no room for a va***n booster, and an electric unit was out of my budget. Absolutely wonderful braking system. The s.s. power steering reservoir was custom made for my application with 2 return lines and a bottom fittting with barbs so I could use the stock Lincoln rubber supply hose.
    Probably other stuff I'm forgetting.
  5. cka7
    cka7
  6. Pheaton193
    Pheaton193
    from Reno, NV
  7. 50sboy
    50sboy
  8. Dos Cincos
    Dos Cincos
    I'll post a version that is somewhere between rats nets and show stopper
  9. It's not pretty but it runs 332.jpg , just about to fit a new water pump and fuel pump.
  10. fordsbyjay
    fordsbyjay
    from Lafayette
  11. 56longroof
    56longroof
    Here's mine. Needs a little cleaning but I'm too busy driving it. 20200510_165041.jpg
  12. guthriesmith
    guthriesmith
    This is what mine did look like right up until I decided to quit fighting with Holley 94’s and put a 57 intake and Edelbrock four barrel on it. It actually doesn’t run as good as it did with the 3x2, but is WAY more dependable. Sitting at 98,000 miles now, I am thinking a rebuild may be in my near future.
  13. Zax
    Zax
  14. Dominick Hide
    Dominick Hide
    Not my own, but one that I did...
  15. Texas57
    Texas57
    Very nice......what is it? The hood latch setup and forward opening hood looks T-bird, if that is what it is, must have some extensive body mods.
    Pheaton193 likes this.
  16. Texas57
    Texas57
    From England?
  17. Dos Cincos
    Dos Cincos
    Hey Texas - tell me about the hi-low horns you are running up front on yours.
  18. Texas57
    Texas57
    Just swap meet items, and they are not loud enough. One of my future projects is to replace them with the horns I kept off a Mark viii donor car.
    Since there was some interest, I added a bunch of notes to my posted pic above.
  19. Dominick Hide
    Dominick Hide
    Yes, car is '55 Thunderbird. Owned by Wayne Zablosky and built by David Guymon about twenty five years ago. I redid the engine compartment a little while back.
    The car...
    Yes I am originally from England, but been living in Texas since '84!
  20. okiedokie
    okiedokie
    from Ok
    Rich you are one sharp guy. Good eye. What a neat Tbird.
  21. Texas57
    Texas57
    I had thought about the unique hood latch setup for my car, that's why I recognized it. Yes, very skillful design and execution on the mods. I like it alot. Not too often you can modify a cl***ic like the T-Bird and come away with a winner.
    Dominick, what part of Texas?
    DIYGUY likes this.
  22. Dominick Hide
    Dominick Hide
    I am in Plano (Dallas suburb).
    DIYGUY likes this.
  23. shortshift
    shortshift
    Love the cold air intake on 50sboy s pic on post #7 above. Anyone know what air cleaner that is. Want to do the same on the 54
  24. 50sboy
    50sboy
    Its a Spectre...filter is just paper - but they sell singe, dual inlets and all piping and elbows...just need to weld or clamo them up. Ebay guy was selling scratched ones - I sanded & painted it anyway, so got it on the cheap.
  25. qicvick
    qicvick
    56longroof, DIYGUY and JeffB2 like this.
  26. JeffB2
    JeffB2
    from Phoenix,AZ
    1-oops.jpg 50's.jpg The blue exhaust manifolds are long gone replaced by HEDMAN 88400 headers.
  27. Dominick Hide
    Dominick Hide
    56longroof, okiedokie, DIYGUY and 2 others like this.
  28. shortshift
    shortshift
    Heres Mine..351W
    56longroof and DIYGUY like this.
  29. steveodeluxe
    steveodeluxe
