Hot Rods 35 Ford garage find
Discussion in 'The Hokey Ass Message Board' started by Wayfreight, Aug 11, 2020.
  1. Wayfreight
    Wayfreight
    Afternoon everyone. I thought this was really cool so I thought I would share. This car has been tucked away in a garage since 1963-ish & I was fortunate enough to be given the opportunity to be the next caretaker.
    The gentleman I bought it from has owned it since 1960 & purchased it from the original owner. He drove it in stock form for a few years then parked it to install a 327 & powerglide & different rear end sometime in the late 60's, maybe early 70's, he's not sure anymore. Never got it running and it sat since then.
    It's absolutely rock solid, not a patch anywhere, doors close beautifully etc.
    Somewhere along the line for whatever reason it got a coat of primer over the original paint & gl*** rear fenders. Originals are in the back & are going back on the car. Original flathead was included too & anything missing is supposedly 'up in the rafters somewhere- you go find it son'
    Plan is to update the brakes & fix the suspension, the engineering is late 60's stickwelder so maybe fix a few welds and preserve it as much as possible.
    Have some questions & some pics below if someone could offer some input I would appreciate it.
    The rear suspension- I know I got problems- options/opinions on fixing this? It all has to come off anyways as the welding is....questionable.
    Front end- it looks original but the shackle angle looks wrong to me- front spring too long or it's sitting show it should?
    Exhaust- it's tight under there. The drivers manifold is VERY close to the steering shaft & there isn't a lot of room to shift the engine anywhere. I'm fine with manifolds vs headers but it has a ramhorn on the other side and I'd like them to match at least. I'll pull it & move it to the p*** side if necessary but wondered if anyone knew a set of headers that would fit so at least both sides would match.
    Factory undercoating- is it usually at least a quarter inch thick & heavy as hell? Or previous owner applied most of a roof to it? I have a model A with original doors & it's probably 3 times as thick as the model A.
    As always, thanks for any ***istance.
    35cab, slv63, kidcampbell71 and 6 others like this.
  2. rusty valley
    rusty valley
    fords did have some heavy tar inside the panels for sound deaden-er. usually, its all dried up, flaked off and laying in a pile at the bottom. nice car!
  3. Max Gearhead
    Max Gearhead
    from Wisconsin
  4. Wayfreight
    Wayfreight
    Ok thank you sir. If that's the case I'll leave it, just seems rather excessive.
  5. catdad49
    catdad49
    Great score!
    lothiandon1940 likes this.
  6. Wayfreight
    Wayfreight
    Thank you. I've known the older gentleman that owned it for a number of years.
    He is, and I say this with all respects, a tough & crusty old *******.
    He didn't ask me if I was buying the car- he told me.
  7. scrap metal 48
    scrap metal 48
    Very cool.. Great project...
  8. lothiandon1940
    lothiandon1940
    You did good. Keep us in the loop as you make progress.:)
  9. Nice car.Look at the 55 Chevy exhaust manifolds.Not the best for performance,but they can be problem solvers.
  10. Wayfreight
    Wayfreight
    Thank you sir. That looks like it will work. Appreciate it.
  11. 56don
    56don
    Congrats. Looks like you have a winner.
  12. Wayfreight
    Wayfreight
  13. RICH B
    RICH B
    Front axle and spring are '42-'48 on a '35-'36 wishbone. Makes for a mismatch in spring width. The later cars had the shackle close to vertical and used a panhard bar for lateral control.
    If you split the 'bones for ****** clearance; minimum is better; brings up the question of what was done to the X-member to get the trans in there.
    Split 'bones will also require work to return the spring eyes square to the axle. Could always get a new correct width front spring at that time.
  14. Wayfreight
    Wayfreight
    Thank you. That is exactly what I needed to know. Crossmember has been torched to fit the trans so will need work but not an issue. Appreciate the advice sir.
  15. Looking at the rear axle it appears the split rear wishbone is the sole torque control.They arent that strong.Consider adding a top one for added strength.
  16. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Great find! If you're interested, that coat of primer may be fairly easy to buff off (especially if it's lacquer) to see what that original paint looks like. Figure the car has been indoors since it was a bit over 25 years old (early 60's). Maybe garage kept by the original owner? No telling what that original paint may look like?
    slv63 likes this.
  17. woodiewagon46
    woodiewagon46
    from New York
    I can't get over how nice the drivers side exhaust manifold clears the steering box, almost like it was made for it. What year Chevy is it from? The big issues with headers is the steering box. I wouldn't worry about a match, if it works don't change it. I would however make a heat shield between the header and steering box. As Rusty mentions the sound deadener from Ford works, so I wouldn't do anything about it. If you remove it you will need to replace it to deaden that tinny sound.
  18. Wayfreight
    Wayfreight
    I'm pretty confident the original paint is good, this car is super solid & the lacquer primer is worn off in spots so I am going to try and wet sand it off and get down to the original paint best I can.
  19. Wayfreight
    Wayfreight
    Not sure yet, the block is tight enough up against the firewall so I can't quite read the numbers yet. I'll leave it if necessary & run mismatched but it's right up against the steering shaft, literally touching it so looking for a bit more clearance there if possible. Might shift the whole operation to the p***enger side 1/2 inch or so.
  20. Exhaust manifold looks like it might be Chevelle. Also noticed that the rear leaf spring was bent(heated) near the eyes; an early form of lowering.
