Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. lothiandon1940
    lothiandon1940
    Andy, If you hit the "full image " ****on just before you post, your pictures will be bigger............Don. 20200812_171511.jpg
  2. Mike Miller
    Mike Miller
    Made some progress on the 56 floors.
  3. 31Apickup
    31Apickup
  4. lumpy 63
    lumpy 63
    Came home after work and even though its 97 degrees on the patio I finished fitting the T bolt hood bump to the hacked 59 Vette hood, Looks totally *****in:D
    LAROKE, Lil32 and High test 63 like this.
  5. mopacltd
    mopacltd
    Pictures!
    j hansen and lumpy 63 like this.
  6. loveoftiki
    loveoftiki
    from Livonia,Mi
    Trans cooler lines done...No idea why NPD would sell em without a double flare, the fittings my neighbor made worked awesome..this was so easy and took care of the leaks.. F1567F80-E7B3-44B2-8854-AB99D44701D8.jpeg
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Bolted intake (283 SBC) and realized that kick down cable bracket (Turbo 350) is a 4 barrel type. So a replacement 2 barrel type is on it's way.
    lumpy 63 and Lil32 like this.
  8. BLACK STUDE
    BLACK STUDE
    Finally got out the new sewing machine and my red metalflake vinyl. Gotta get in some practice before tackling the interior in the 55' Stude. Maybe I will finally remember to get some photos to put up. IMG_20200813_104439119.jpg IMG_20200812_174454040.jpg Diamond pattern was a lot of work. Between attaching batting and a layer of cloth, then the layout and sewing, it ate up some time. Nice to be able to work on something on the car and not be out in 100 degree heat.
  9. Elcohaulic
    Elcohaulic
    Found out why this monster was stumbling when I would nail it, the cheap Chinese shift light was causing the distributor to brake up. On a whim I pulled the wire from the distributor, took it for a ride to my favorite spot and she jumped up and took off like a big block should..
    https://www.summitracing.com/parts/sum-800105/reviews
  10. High test 63
    High test 63
    IMG_20200815_131400316.jpg getting parts rounded up for a new engine for my roadster.
    Here is my buddy polishing the crank.
  11. nunattax
    nunattax
    never enough room is there
    j hansen likes this.
  12. oldpl8s
    oldpl8s
    Built an anvil base from 4x4s and truss rods
  13. WTF really
    WTF really
    Set the engine and trans in the ch***is 20200812_160938.jpg 20200812_160924.jpg 20200811_170924.jpg
  14. Well momma bought me a set of valve covers for my birthday, so i pulled the covers off of her motor and set mine on it, been a tough day so far :D now it's back to taping :rolleyes: 20200816_115947.jpg
  15. K13
    K13
    Use scrim backed/sew foam. WAY easier.
  16. BLACK STUDE
    BLACK STUDE
    Nobody in town had any. But I can order some online for my next project. Thanks for the suggestion. I'll take all I can get. First time doing this.
    Lloyd's paint & glass likes this.
  17. Racer29
    Racer29
    Rode around in a side by side UTV in the African Sahel. Not kidding.
    Truckdoctor Andy likes this.
  18. Mike Miller
    Mike Miller
    Pretty much finished the welding on the floors, a couple of tacke on the under floor bracing and a coat of H/F bedliner and lift the body off the frame one more time to tighten up some ch***is parts. Then on to the next task.
    DSCF5279.JPG DSCF5283.JPG DSCF5284.JPG DSCF5285.JPG DSCF5289.JPG DSCF5290.JPG
    Chavezk21, LAROKE and j hansen like this.
  19. jimmy six
    jimmy six
    Decided to install the “50-60’s retro tach I’d bought a few years ago. I didn’t want to screw up the column turn signal wire cover and was able to do it. No reason, just wanted to do it, and yes at idle the generator light is either on or flickering. F37976CE-EA8D-45DC-9D01-FFB4D54CFD93.jpeg
  20. 31hotrodguy
    31hotrodguy
    Moved old Buicks around the property. Luckily it was only a 102 today! [​IMG][​IMG][​IMG]
    LAROKE, blowby, David Gersic and 2 others like this.
  21. High test 63
    High test 63
    IMG_20200818_171852683_HDR.jpg picked up the fresh block for my new roadster motor!
    charleyw, 31hotrodguy, LAROKE and 2 others like this.
  22. High test 63
    High test 63
    IMG_20200818_113034627_HDR.jpg also picked up the cam kit i ordered from the local napa store. Box says "made in USA". Open that up and the solid lifter boxes inside say "made in China"!
  23. saltflats
    saltflats
    from Missouri
    Bored out and drilled this smaller and lighter pulley for a 4 bolt harmonic damper going on a 467 inch F.E.
  24. Mike Miller
    Mike Miller
    Cut the rusted out spare tire well out of the 56 wagon, It had been kind of hacked with pop rivitd, sheet metal amd fibergl*** over rust. Going to cover the cargo area with some diamond plate aluminum and convert the back seat area into more cargo space, when I'm done the car will only have seating for two.
    Lil32, 31hotrodguy and j hansen like this.
  25. 57 HEAP
    57 HEAP
    I decided I needed to get lunch at the local drive-in today. I'm sitting there enjoying the delicious food when a car pulls in and the driver gives me a thumbs up. Normally not anything to comment about, but...….
    This person was driving a Hybird car. So it got me to thinking, why would a tree hugger go to a drive-in? Why would they give a thumbs up to a dinosaur burning 57 Chevy? I mean there is nothing wrong with either life style, it just seems odd to me somehow.
    blowby, Lil32 and Hamtown Al like this.
  26. Mike Miller
    Mike Miller
    Are you sure it was his thumb?:D
  27. ct1932ford
    ct1932ford
    Maybe he had one when he was in finishing school!:rolleyes::p
    blowby likes this.
  28. blowby
    blowby
    from Nicasio Ca
    Maybe he was commenting on the delicious food.:)
  29. partsdawg
    partsdawg
    from Minnesota
    Bid and won this rear end ***embly on a local online auction. Pics didn’t show much, all wide angle. Imagine my surprise when I rolled in to pick it up
    Chavezk21, LAROKE, RICH B and 2 others like this.
  30. Black_Sheep
    Black_Sheep
    77F4C4B0-C5C5-4683-983D-F4DC233B5368.jpeg Went to visit Dad after work...
