Technical Hood Leather
Discussion in 'The Hokey Ass Message Board' started by dmdeaton, Aug 14, 2020.
  1. dmdeaton
    dmdeaton
    Who sells hood strap kits? I have my old set from hot rod leather but too short. I can get some leather and modify but looking to get a new set
  2. woodiewagon46
    woodiewagon46
    from New York
    Restoration Supply Company has an ***ortment of leather straps and accessories. WWW.restorationStuff.com or 1-800-306-7008.
    5window likes this.
  3. Joe Blow
    Joe Blow
    Limeworks and Macs sell the kits and Restoration Supply sells the individual components.
  4. DaveK87
    DaveK87
    from Illinois
    For much cheaper as well
    acme30 and dmdeaton like this.
  5. denis4x4
    denis4x4
    from Colorado
    Go to a saddle shop and make your own with copper rivets. Springs are from Restoration Supply, ss loops from West Marine and clasp is from a horse collar 7FD56D27-C08D-4181-BBE8-A7E824FAFD9B.jpeg
  6. HOTRODPRIMER
    HOTRODPRIMER
    I went to a shoe repair shop and they had leather for belt's & saddle work. HRP
    OLSKOOL57 likes this.
  7. 5window
    5window
    You probably have some Amish/Old Order Mennonite harness shops in your general area that would have or could make what you need.
    JNKYARDDOG_1 likes this.
  8. JWL115C
    JWL115C
    Is Hot Rod Leather still in business? They offered a variety of leather hood straps and hardware.
  9. dmdeaton
    dmdeaton
    He p***ed away sadly. I have my first set from him and I might order springs and modify what I have. I need a little longer now and the springs should get me in the ballpark
  10. Mr48chev
    There is an upholstery shot that calls it's self hot rod leather that as far as I know had no connection to him. High end street rod interiors.
    I'd agree that if you are close to Amish country a harness shop could make you what you need leather wise in short order.
    jadz928 likes this.
  11. continentaljohn
    continentaljohn
    What you are looking for is Veg tan leather and comes in many sizes. You can get belts from Tandy leather as I get sides and shoulders from them along with Montana leather . I make toolrolls and leather aprons and some other leather products. So I cut my own belts or straps out of hides. What width do you need and what length? Also thickness as I have 1/32 to 3/8 thick. The hardware rivets are available from tandy to lengthen your straps and have some as well on hand. If I can help let me know thank you john B678A8E1-FDFD-4460-909D-5B8B6A0CEC8F.jpeg 9C04CD3F-73F3-45A4-B839-58B95C7FFAA5.jpeg
    dmdeaton and belair like this.
  12. winduptoy
    winduptoy
    Everything from Tandy leather. Strap, precut and different colors. Tube nuts and eyelets. Some proper diameter tube from McMaster Carr.
    Cut metal flat s**** to length and made width of strap. Placed on tube so it would be centered above the stock hood latch.
    Silver brazed the flat to the tube.
    Drilled two holes for the tube nuts to attach strap to flat. Cut 3/8" rod to length and affixed the top bracket... Drilled holes in adjacent tubes for a cotter key to capture rod.
    I stretched the strap lifting up the stock latch to mark the eyelet placement. The bottom of the eyelet at about the maximum extension of the latch so as to hold the strap taunt.
    Installed eyelet.
    Rounded leather to a radius roughly that of the eyelet.
    I still need to clean up the sides and dye the same color.
    Cheap alternative, holds the hood. No funky latches to deal with when the hood is open IMG_20200815_190446.jpeg IMG_20200815_190154930.jpeg IMG_20200815_190641.jpeg IMG_20200815_190117087.jpeg IMG_20200530_081851626.jpeg
    Sent from my XT1585 using The H.A.M.B. mobile app
    jadz928 and dmdeaton like this.
  13. indyjps
    indyjps
    Friend of mine does high end saddles, and holters. That width, he probably can make from drops. Decorative s***ching, tooling, riveting is everyday stuff for him
    IM if you want his contact info.
  14. dmdeaton
    dmdeaton
    Thanks guys, all good tips. I ordered some springs from RS and have a box of leather tools, just haven't fooled with them in a while. John, I pm'd you on a tool roll.
  15. continentaljohn
    continentaljohn
    I like the restoration supply and they have many items we area all looking for @dmdeaton sent you a PM thanks
