Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. roseville carl
    roseville carl
    actually got 91lbs of aluminum for free but it was in a form I couldn't use so......melt it, got 60 of it melted so far, now it gives me more to make **** out of. Of course that's when the new petrobond arrives. Humm casting a block?????lets see, don't need no water holes have sleeves on hand, hummm, nahhh maybe next year. Besides I would need a bigger foundry..................and yes Flathead FED's are a blast keeps this old fart busy and alive.........
    rpm56, chryslerfan55, Tman and 2 others like this.
  2. Pete1
    Pete1
    from Wa.
    Whutz a phone?
  3. Pete1
    Pete1
    from Wa.
    Just curious Carl, do you have any compe***ion where you run or is your trophy shelf bulging?
  4. 97
    97
    I am not so sure that Grant would want any discussion about his age , but he is still racing and still running sixes. The current FED which he built a couple of years ago from scratch at home is powered by a BBC. He still has the old car and the home made engine.In fact he is a Hamber but hasn't said much . User name ownblock.
    https://www.jalopyjournal.com/forum/members/ownblock.253224/
  5. 64 DODGE 440
    64 DODGE 440
    from so cal
    You could give it any kind of ports you wanted...make your own solid heads too and experiment with chamber shapes.
  6. 97
    97
    And bury the head studs deep for greater clamping, more boost ! and/or move them so you can bore it for 3 and 9/16 sleeves, or not even use sleeves, just Nikasil plate the huge bores and even bigger ports, valves and ....... raise the cam bore and enlarge it for much bigger lift cam, 5 main bearings with 4/6 bolt caps/girdle, steel stroker crank, ...meanwhile back in the land of rational reality.........:rolleyes:
  7. roseville carl
    roseville carl
    Pete haven't won any yet I just make the Trophy's to give to Ron Bowers and his injected 6 at Eagle Field (gotta beat that sob sometime soon), gotta make him start on I 5 next time.........,
    And yes Tom there is a seven port 322 for the next rebuild..........
    and Pete still running the cam you ground for me....Love it!!!!
  8. roseville carl
    roseville carl
    well sometimes you get a great feeling, helped a buddy build this engine for his grandson, he sent this video........what its all about.....go gettum Tyler.......
    J.Ukrop, -Brent-, Super88 and 6 others like this.
  9. Gammz
    Gammz
    from Lincoln Ne
    F^*k yeah man!
  10. 64 DODGE 440
    64 DODGE 440
    from so cal
    Good sounding flatty. That should keep his grinnits working.
  11. Old6rodder
    Old6rodder
    from SoCal
  12. Aaron D.
    Aaron D.
    Maybe it's just the video, but it doesn't sound like it's running on all 8 when he drives away. I recently had some rust bits clog one of the jets on my dual Stromberg setup. Sounded just like that, and it was running on 6 or 7 cylinders.
    loudbang and ottoman like this.
  13. loudbang
    Sounds pretty quiet for no mufflers. :)
  14. roseville carl
    roseville carl
    well getting closer......
  15. 64 DODGE 440
    64 DODGE 440
    from so cal
  16. roseville carl
    roseville carl
    gettin closer Tom.........
  17. loudbang
    How long can you run it before it gets too hot?
  18. roseville carl
    roseville carl
    little over a 1/4 mile:confused::confused:
  19. roseville carl
    roseville carl
    People ask what's Eagle Field all about, well here's a compellation of 11 years from a Flathead perspective 10350409_10202070748162359_6443179733606878239_n.jpg 18558601_1589653001046421_2944399826106711150_o.jpg 18815368_1326270354075193_6002303501464658817_o.jpg 20180518_164755.jpg 20180519_055151.jpg 20190531_165342.jpg 20190531_200420.jpg 20191004_114301.jpg 75392740_2418734811577953_5091170528060768256_n.jpg at the line with gary b&w.jpg Chris at eagle 2013.JPG dragster at line.jpg 10350409_10202070748162359_6443179733606878239_n.jpg 18558601_1589653001046421_2944399826106711150_o.jpg 18815368_1326270354075193_6002303501464658817_o.jpg 20180518_164755.jpg 20180519_055151.jpg 20190531_165342.jpg 20190531_200420.jpg 20191004_114301.jpg 75392740_2418734811577953_5091170528060768256_n.jpg at the line with gary b&w.jpg Chris at eagle 2013.JPG dragster at line.jpg DSC_0732.JPG DSC_0755.JPG DSC01523.JPG DSC02670.JPG DSC02739.JPG DSC04362.JPG DSC04377.JPG eagle field may 2018 088.JPG
  20. roseville carl
    roseville carl
  21. Old6rodder
    Old6rodder
    from SoCal
  22. loudbang
    Good stuff, thanks for posting. :)
  23. 64 DODGE 440
    64 DODGE 440
    from so cal
    Fun times and I'm sure there's more to come. Hope to crew for you again. Say hi to the "Old Hippie" for us.
  24. roseville carl
    roseville carl
    will do Tom, we're both just treading water at the moment, but still time to futz with Flathead stuff, its amazing how much of a mess I can make in a few minutes.
    20201127_180942.jpg 20201127_180948.jpg 20201130_113320.jpg 20201130_113441.jpg
  25. 64 DODGE 440
    64 DODGE 440
    from so cal
    Surprised you haven't cast your own timing cover yet. Looking good Carl.
    Put the "Rabbit" on hold for a bit, (hell, it's been on hold for the last several years). Working on putting a straight axle under the front of my avatar. Needed a change of projects for a bit. When it's up and running I'll get back to the race car.
  26. 97
    97
    Something like this Tom ?
    chryslerfan55, 48fordnut and loudbang like this.
  27. roseville carl
    roseville carl
    nice castings but I've never been a fan of set screws for hold down if I cast one it will have shoulder for Chev style hold down, keeps dist from walking when timing. JMHO
    loudbang, 97 and 64 DODGE 440 like this.
  28. 97
    97
    Not my castings, made in Aussie. They look OK, but way too "street rod" for my liking. I like the alloy covers from the later motors , they have another shaft support below the drive gear.
  29. roseville carl
    roseville carl
    still nice looking castings though, those Aussie's make some neat **** ................
  30. 64 DODGE 440
    64 DODGE 440
    from so cal
    You do too Carl.
