Technical 1954 bel air 350 swap
Discussion in 'The Hokey Ass Message Board' started by Robert Braun, Aug 22, 2020.
  1. Robert Braun
    Robert Braun
    Putting a 350 SBC in my 1954 bel air.. Can I use the stock radiator or do I need a different size or type?.
  2. sdluck
    sdluck
    Not enough info here,but normally if it is in good shape yes? Where are you located?
  3. chambosinthere
    chambosinthere
    I have an aluminum radiator from eBay, KKS brand I believe and two electric pusher fans. I live in AZ and drive the car year round, hasn't gotten above 190. 20191117_170115.jpg
    Robert Braun likes this.
  4. Smoothy
    Smoothy
    Back when I had my 54 2Dr HT it had a 350 and 200 4R Transmission. Used a 55 Chevy radiator and stock mechanical fan, didn't have a shroud or any electric fans. Ran 190 degrees all the time, even on hot 100 degrees plus summer days. I think 55 Chevy and 54 are the same radiators.
  5. Mr48chev
    A lot of it depends on the condition of your radiator.
    If it is original it is 66 years old. That alone may mean that it is not going to be in the best shape.
  6. krylon32
    krylon32
    from Nebraska
    If I were spending the money on an engine swap the radiator is not a place to go cheap. Can make or break your conversion.
  7. You will be fine. I ran mine for years before I sold the car. No issues on even the hottest days
    Sent from my SM-J337V using The H.A.M.B. mobile app
  8. Robert Braun
    Robert Braun
    What info am I missing? I am in Oklahoma..
  9. sdluck
    sdluck
    Stock ,mild, or modifed 350,what trans,what rearend
  10. Bob Lowry
    Bob Lowry
    If it's working good now, I would do the swap and see how it does with the sbc. I have done many
    hot rods, replacing 6 cyl. Chevy's with small blocks, and never had an overheating issue with the stock
    radiators. Try and see.
  11. jimmy six
    jimmy six
    Get yourself a cement mixing tub. Fill it with water and some simple green, attach a vibrating sander to the side. We put the radiator on some styrofoam blocks and turn on the sander for about 6 hours... I will be clean. If you don’t like simple green put in a gallon of vinegar. But rinse it afterwards.
    We put a SBC In a 53 in 1964 and never had a problem with the stock radiator.
    Algoma56 likes this.
