Anybody ever seen one of these before. I've never seen one and was wondering how it works exactly. Is it of interest to us hot rod guys???
Looks like a good way to kill yourself imo. Vintage tools are all well and good but when its something like a spring compressor you dont want to muck about. Sent from my SM-A105G using Tapatalk
Hi Russ I am wondering if there is a piece missing? I suspect maybe there is a flat bar or I beam that goes in the cradle end that screws / compresses the spring. If the compressor bit went over the spring and then had an i beam parallel to the spring then it would lengthen the spring when the screw handle was turned in
It's a K R Wilson A-321 Rear Spring ***embly Press, for a Model A Ford. There is a picture of it on page 272 of the service bulletins. You have the complete unit and it's not missing any pieces. Model A collectors would love it.
How it works is, the two fingers at the top clamp to the rear crossmember flange. The two rods hang down and the threaded piece with the cradle fit under the banjo. You connect the threaded part to the two rods and clamp away until the rear is up enough to remove the shackles. Yes, it does sound dangerous to me also, but that's how it was done back then.
If you can get a copy of the Model A Ford, service bulletin's for February 1928, there is a picture of it in use on page 226. I stand corrected, it doesn't clamp to the flange on the rear crossmember it goes over the top of the crossmember. They also show two blocks of wood that go between the rear end and the shackles. Still looks dangerous.
ACME 30 was onto something there, just that the beam he is looking for is actually the axle . Boy, when wound up it becomes a weapon. There can be a lot of energy in a compressed spring of any age or type from what I have seen over the years...
That's an overload giz; it is upside down in the picture; clamps to bells around the banjo and ends of the spring push on the frame. Must have been a lot of different overload set-ups made back in olden times.
I am just trying to imagine how these two components relate to each other, since a 40 rearend would have the actual spring behind the diff, yet the secondary springs looks to be in line with the diff so to speak?
The added spring ends up centered right on top of the banjo. The long leaf is on top and either bears on the stock axle bumpers or there could have be added stops for the spring. Sent from my Nexus 5X using The H.A.M.B. mobile app
I see, that will work then. I just wonder how many of these types of Gizmo's are out there that have been conceived over the years, especially ones that were commer******ed, then of course you probably have a good number of homemade stuff as well...
A 'reserved thinker' told me he had a Model A spring that he wanted to dis***emble, but was worried (convinced!) that when the center bolt was removed it would shoot the upper leaves into the adjoining county. I suggested an old blanket, and wrapped the spring not too tightly, and buzzed the nut off with a 3/8" drive impact. "Whump"... No nothin', just jumped once like a lazy old Western Diamondback. Unwrapped 3 layers of blanket and picked up the leaves. Didn't even have to sweep the driveway...
Ha, that sound about right. Knowledge is king, which usually comes with experience or good advice. I took a rear spring out of a 36 Coupe years ago with a buddy who had a lot of experience with that kind of stuff. The spring was loaded and ready to break loose. He got to a point where it was ready to release and said, stand back and he trow a large hammer at some part of it and it sprung out big time. Glad I had no hands or fingers any where near that event...
