Projects Mild custom '51 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by PhilA, Nov 4, 2019.
  1. PhilA
    PhilA
    ... Just in time to think about boarding the garage back up, there's the possibility of two hurricanes early next week. Great fun.
  2. tomkelly88
    tomkelly88
    I'd be grinning too Phil, your car sounds great!
    also, in the video, the 5th and 7th lifter (from the right) were spinning/rotating? is that ok?
    chryslerfan55, loudbang and PhilA like this.
  3. 302GMC
    302GMC
    from Idaho
    also, in the video, the 5th and 7th lifter (from the right) were spinning/rotating? is that ok?[/QUOTE]
    Yes ... the tappets wouldn't wear evenly without rotating.
  4. PhilA
    PhilA
    They all do spin when you bring the revs up, at idle the lifters are a little worn to cause them to not rotate well; the really rapidly spinning ones were a shade tight and in constant contact with the cam, causing them to spin.
    The valves I shot the video of before they'd been adjusted... That's why they sound a little noisy still.
    Phil
  5. PhilA
    PhilA
    Tonight, I decided to get a bit creative.
    I stripped the insulation off a length of big wire, slipped it over the end of the glass inside the door and then squished the sash channel over it. It grabbed well enough to allow me to carefully wind the glass up and down. That'll do until I can get all the correct parts.
    Phil
  6. Copper Top
    Copper Top
    I have used the soft side of Velcro to make window channel felt. It has glue on the back and sticks good.
  7. PhilA
    PhilA
    Unfortunately the whole rubber channel is gone, leaving just the I-section metal behind that holds the vent window.
    I found a source of the correct steel-edged rubber/felt channel so will try repair it using that.
    Right now, the glass is mounted centrally in the sash so it winds up and misses the metal lug that it previously hit (and that is what cracked the glass).
    I might try getting the broken rear pane to slot into the sash channel I recently got, which should hold it roughly to the correct shape and allow it to be wound up and down until I can get replacement glass.
    Phil
  8. PhilA
    PhilA
    Managed to pull the glass out without breaking it more; gently eased the sash channel onto it, which is holding it in shape.
    Got the mechanism all back in as it should be and the window going up and down.
    Finally, attached the felt runner channel back to the vent brace with semi flexible adhesive. That's now clamped in place and should set overnight.
    That leaves me now with a full compliment of windows that go up and down (mostly, to a degree). Many thanks to our very own 302GMC.
    Phil
  9. PhilA
    PhilA
    I thought "I know, I'll take a picture with all the windows rolled down, because that's a first for the car while it's been in my ownership". So, there you are. There's the photo; however the rear right glass can roll down so far the top scissor falls off the track. I need to see what's missing internally, if there is a metal "shelf" inside the door that's missing to stop the window being wound down too far, or what is up with it but that's no good. Wound the window back up and it took all the felt in the rear channel I glued in last night with it. Bah.
    Phil
  10. goldmountain
    goldmountain
    Must be uncomfortable driving in Louisiana in the summer with the windows up.
    Sent from my SM-T350 using The H.A.M.B. mobile app
    Woogeroo and loudbang like this.
  11. PhilA
    PhilA
    Yes, particularly when the inside of the glass begins to form an oily greasy haze of moisture and it's 95F out.
    You need heat on the glass and cool to your face. That's not a combination a lot of cars offer.
    Crank the air conditioner up and the inside of the glass dries but the outside then fogs up like a cold beer bottle, and you end up with your wipers on in the sunshine...
    chryslerfan55, loudbang and brEad like this.
  12. PhilA
    PhilA
    Aha. I eyeballed down inside the other door.
    The bottom stop appears to be attached to the door plate.
    Guess what didn't come with the car.
    I hate shade tree mechanics.
    Phil
  13. PhilA
    PhilA
    In lieu of anything else, I gave the side glasses a deep clean. They come up respectably. If you can't fix it, clean it, right?
  14. PhilA
    PhilA
    Well, something slightly off-topic that made me smile... I sold my '65 Hillman waaaay years ago. One of those cars I wish I had never sold. Someone told me they'd seen it, rotting away down the side of a barn about a decade ago. Today, a picture surfaces of it all painted up nice, in the middle of being restored. That made me happy. I think I've got the original rear plate for it in the attic; might send it to the new owner as a morale booster.
    Phil
  15. Have You considered joining the Pontiac Oakland Club International (POCI.ORG).?
  16. PhilA
    PhilA
    I had, but it pays really to have the car up and on the road first.
  17. PhilA
    PhilA
    Tonight, more glass.
    Subject: Front driver's side windshield. Arguably the most important pane of glass on the car, and one of the least clean.
    After a deep cleaning, significantly better.
    From inside the car, the difference is clear to see.
    Next up, the rear view mirror. It was stuck in the night-time position. Pulling it forward would result in it snapping back again as soon as you let go. Loosened the thing off and undid it from the pillar.
    Screwdriver to gently prise it open.
    Mirror glass cleaned, finger tab cleaned (yuk) and adjusted because over time the little arms that hold it snug to the glass had become very slack, and it was able to move in relation to the mirror, so the spring would never fall over-center and lock in place.
    Attempted to clean the case, gave up and threw it in the dishwasher because it needs to be nice and hot to clean up, hotter than I fancied getting my hands under the faucet. That'll be ready tomorrow. I'll give it a coat of wax because the chrome is beginning to get all pitted, which should slow that degradation down. It'll also look nicer in through the windshield, clean...
    Phil
  18. loudbang
    You should try a "Claybar"on those old windows it really removes more gunk than just windex or soap and water.
    chryslerfan55 and kidcampbell71 like this.
  19. PhilA
    PhilA
    Is going to but the glass is surprisingly not very scratched or pitted for its age. A sharp blade and then Windex has brought it up clear enough not to glare. My main problem was the previous keeper had clear coated the roof but not protected the glass against over-spray, so that all needed to be removed from the surface. The surface itself is still smooth so that brought it up clean.
    Claybar is excellent for where the screen is hazy or scratched by the wipers, it pulls all the dirt out of the pocks and grooves, as you say.
    Phil
  20. PhilA
    PhilA
    Fixed the mirror.
    Phil
  21. goldmountain
    goldmountain
    Learned something new. Didn't think day/night mirrors were available back then.
  22. PhilA
    PhilA
    Yup. It was a paid option on the Deluxe.
    kidcampbell71 and loudbang like this.
  23. PhilA
    PhilA
    Continuing a theme, I just ordered a couple new mirrors because the ones in the car are loose and one is cracked and no longer silver.
    Ordered a new traffic light viewer to replace the sun-crazed lens that's in this one, which flares quite badly in the sunshine.
    That should all be in next week.
    Phil
  24. PhilA
    PhilA
    And gosh, it's two years today I dragged this home with me.
    How time flies.
    Phil
  25. 64dropptop
    64dropptop
    from union city
    Enjoyed ur thread well detailed and man ur work on point!! I’m Pontiac fan as well I have - 1939 Pontiac 8 convertible and 38 Pontiac convertible!!
    kidcampbell71, loudbang and PhilA like this.
  26. PhilA
    PhilA
    Went to Tractor Supply. Big jug of 30 weight diesel oil, antifreeze and some brake fluid and brake cleaner purchased.
    Today was "it's easier to ask forgiveness than permission".
    I did however finish cleaning the glass this afternoon. The haze around the bottom edge is where the glass is beginning to delaminate.
    Phil
  27. PhilA
    PhilA
    Similar shot, but finally I polished the side of the car. Only took 2 years.
    Better. Needed doing. Absolute déluge today, everything flooded.
    Phil
  28. PhilA
    PhilA
    A final thought for today- I have just seen the progression day by day on this car, so stepping back in time a couple years does make me realize how it's come along.
    2 years ago.
    Compared to today.
    Happy with that so far.
    Phil
  29. MUNDSTER
    MUNDSTER
    That’s great, love this thread. You hooked me with the radio rebuild and I’ve been following ever since. Great job, love the car [emoji1303]
    chryslerfan55 and PhilA like this.
  30. PhilA
    PhilA
    Thanks. I stopped earlier to take account of what's changed between those two films.
    For one, all the dashboard works now. The switches work correctly. The clock works. The lights all work. The windows go up and down. The horn works. The gearbox changes gear properly. The engine no longer sounds like a bag of bolts. It's got a radio. The antenna works. The rearview mirror works. The wipers work. The screen wash works. All the locks have keys. The paint has a half decent gloss to it. The heater works.
    Probably more that I've forgotten, too.
    Phil
