Projects 1934 Ford Pickup Build U.S. Mail
Discussion in 'Traditional Hot Rods' started by Ratspit, Jul 11, 2020.
  1. Mat Thrasher
    Mat Thrasher
    I love this build. Keep up the great work.
  2. Ratspit
    Ratspit
    Moving back into the cab, it was time to address the floor, toe boards and begin the tunnel.
    20200629_121209_resized.jpg 20200629_121046_resized.jpg 20200629_121248_resized.jpg 20200722_115140_resized.jpg 20200722_115104_resized.jpg .
    tb33anda3rd, Toms Dogs, brEad and 6 others like this.
  3. Fitnessguy
    Fitnessguy
    Great build and great fab work. Looking forward to seeing how you tunnel out of the back of the cab. Keep posting!
    kidcampbell71 likes this.
  4. Ratspit
    Ratspit
    With the grill modified and positioned we moved back up front to start tackling the hairpins. Since this truck is going to be sporting a suicide front axle we needed to devise a way to attach spring the hairpins. We played around with a number of ideas and finally settled on a custom mount.
    20200629_121122_resized.jpg 20200629_121127_resized.jpg 20200629_121145_resized.jpg
    tb33anda3rd, 39custom, brEad and 3 others like this.
  5. alchemy
    alchemy
    Now half the weight, and the all the road forces that hit the front axle, are transferred through those clevises to the spring. Are they strong enough?
    sdroadster and sloppy jalopies like this.
  6. sloppy jalopies
    sloppy jalopies
    ditto alchemy, … thought the same thing...
    the wall of the tube is thinner where tapped...
    will it stress then crack where the clevis's trailing thread ends ?
    it doesn't just flex vertically it also will twist horizontally...
  7. Ratspit
    Ratspit
    Here is a picture of a similar setup. The truck has quite a few miles on it with no issues. I do agree that there will be some horizontal stresses from this design.
  8. Ratspit
    Ratspit
    Yesterday was mock up day.
    20200722_131528_resized.jpg 20200722_131537_resized.jpg 20200722_131549_resized.jpg 20200722_131306_resized.jpg
  9. Max Gearhead
    Max Gearhead
    from Wisconsin
  10. warhorseracing
    warhorseracing
    from cameron wv
    You said earlier in this build that it would have a U.S. Mail theme. Now I am seeing your vision and, it will haul the Mail.
  11. King ford
    King ford
    from 08302
    Hearing the theme song from " the Waltons " is a HELL of a lot better than the theme song of " deliverance " .....or " cops" .....but seriously this is going to be a SWEET TRUCK Ratspit!...looking forward to more updates! As to the concern over the load created by the spring attached to the hairpins AMERICAN made neutralized chrome molly radius rods and high tensile strength AMERICAN MADE clevises ( and bolts naturally) and it ought to work great!
  12. clem
    clem
    Nice truck !
    Thanks for posting, (and ignoring all the nonsense, and continuing to post).
    Max Gearhead likes this.
  13. 57tailgater
    57tailgater
    from Georgia
    "SPECIAL DELIVERY", "FIRST CL*** MAIL", "RFD: Really FAST Delivery"
    Awesome build and thread!!
  14. Ratspit
    Ratspit
    Thank you gentlemen. The next step on the build was to attack the dash. The original dash was nice but what the heck, a 40 dash is even cooler right?. We had to cut and tuck the corners, shape the top, and fill a few holes.
    20190312_175952.jpg 20200629_121256_resized.jpg 20200702_082151.jpg 20200702_082134.jpg 20200708_064212.jpg
    Toms Dogs, Tim, 51 mercules and 9 others like this.
  15. @Ratspit
    Are you going to do a hydro clutch? You gaining some headway there, Looking good !
  16. Ratspit
    Ratspit
    JYD1,
    Yes, the plan is to use a hydro clutch so the transmission tunnel is as small as possible. We are finishing up the tunnel and more of the floor details now. I'll post a few pictures soon.
  17. Ratspit
    Ratspit
  18. Ratspit
    Ratspit
    The transmission tunnel has finally taken shape. It was a little bit of a challenge to keep it tight to the ****** and limit the impact on the floor space, while at the same time shooting for a traditional look.
    Tim, brEad, Mat Thrasher and 8 others like this.
  19. dwollam
    dwollam
    It's gonna be right hand drive right? My wife could use it then to deliver mail! Oh wait, automatics only for our mail carriers. :(
    Dave
  20. Ratspit
    Ratspit
    With the tunnel in place it was time to figure out the e-brake location. I saved the original lever from the BB when I took it apart with the idea that I would use it on the build . Since the T5 lacked a mounting point we built a frame mounted bracket.
    tb33anda3rd, Tim, brEad and 8 others like this.
  21. Ratspit
    Ratspit
    As the old saying goes, "The devil is in the detail". And boy are there a lot of details. First on the list was to fabricate a E-brake pocket for the newly placed handle.
    20200928_115459_resized.jpg 20200928_115509_resized.jpg 20200928_115503_resized.jpg
    tb33anda3rd, 51box, nunattax and 11 others like this.
  22. Ratspit
    Ratspit
    The rear panhard bar had been on the list of things to do for quite a while. Pretty straight forward install with a great kit from Socal for the QC. 20200928_115322_resized.jpg 20200928_115317_resized.jpg 20200928_115257_resized.jpg 20200928_115301_resized.jpg
  23. Max Gearhead
    Max Gearhead
    from Wisconsin
  24. 51 mercules
    51 mercules
  25. Tim
    Tim
    from KCMO
    That ebrake mounted off the cross member is a great idea, might have to steal that one!
  26. Ratspit
    Ratspit
    Greg,
    Yup, that's the dash. Thanks again.
  27. Ratspit
    Ratspit
    To ****on up the floor we had to fabricate fillers for the 4 corners of the cab. Eventually these will be riveted in place. 20200928_115348_resized.jpg 20200928_115354_resized.jpg 20200928_115400_resized.jpg 20200928_115409_resized.jpg 20200928_115516_resized.jpg 20200928_115526_resized.jpg
  28. loudbang
    You metal magicians kill me. Well I needed to make a pocket for the ebrake. Before long presto chango a real neat pocket that would have taken me a week or two make and looked half as good. :confused:
  29. 51 mercules
    51 mercules
    No prob! Glad to see you're making progress on your truck. Looking good!
  30. Okie Pete
    Okie Pete
    Thank You for sharing your build .
    Amazing eye for details. You are a craftsman not a fabricator .
