Technical 50 Olds rear brake shoes
Discussion in 'The Hokey Ass Message Board' started by Belair235, Aug 27, 2020.
  1. Belair235
    Belair235
    I need to pick some brains out there... I’ve got a 50 Olds series 76 with a right rear brake seizing up. The wheel cylinder is leaking and the lining has been wet and true to form it is locking up and eventually seizing up tight. With that being said... I have been looking for rear brake shoes and can only find fronts, my buddy has a 50 Ford and his are the same size front to rear, does anyone know if this is the same for Oldsmobile in 1950. Also the washers between the drum and axle flange on both sides, I found to be a bit odd.[​IMG][​IMG]
  2. 302GMC
    302GMC
    from Idaho
    Wild guess on the washers - couldn't find 76 drums, so why not use an 88 - 98 drum & shim away from backing plates ?
    So, a quick look in a 1956 MoToR flat rate book shows the drum is '49 - '50 6 cyl Olds only, and doesn't interchange with anything. GM part # is 412556 on the drum, shoes w/ lining 417984 if that helps any ...
    Shoes should be easy, just measure dia. & width, Bendix shoes fit dozens of other cars.
    What does drum hit when you leave the washers out ?
  3. Belair235
    Belair235
    From the looks of it the brake shoe was rubbing on the side of the drum. The shoes are 2” wide, I would think they would be more narrow.
  4. Belair235
    Belair235
    Oh and thanks!
  5. captaintaytay
    captaintaytay
    11" x 2" shoes FMSI #228
    I think you have a brake drum problem.
  6. BJR
    BJR
    See it the brake drum on the left rear has the washers. If no washers compare it to the right one and see what the difference is. The washers were obviously to space a drum meant for a different application so it would not rub on the backing plate or edges of the shoes. Another thought, maybe the drum is correct and the shoes are too wide, and meant for a V8 car.
    Hnstray likes this.
  7. Belair235
    Belair235
    That is a very distinct possibility, both sides are shimmed with washers.
  8. Belair235
    Belair235
    Because it is shimmed on both sides I’m leaning toward the shoes being too wide.
  9. captaintaytay
    captaintaytay
    Well, then it looks like it would need to be a 11 x 1 3/4" shoes. If that's the problem, which you are guessing at.
    The old Chevy Pick-ups had 11 x 1 3/4" shoes. FMSI part # 55.
    That might work, but I still suspect drums. Good Luck I hope you find the problem.
  10. oldsjoe
    oldsjoe
  11. Bird man
    Bird man
    from Milwaukee
  12. Hank37
    Hank37
    Back when I was working at a Chevy dealer i found that 78 Chev. Impala rear drum brake shoes and wheel cylinders were a direct fit on my 49 Olds. rear .
  13. Belair235
    Belair235
    I’ll definitely look into that, thank you for your help.
  14. Belair235
    Belair235
  15. captaintaytay
    captaintaytay
    Yes, but I only mentioned narrower shoe because your thinking shoes could be to wide.
    I don't think the shoes are the issue, JMHO, I say wrong drums.
