Technical Auction find...ID these tail lights ?
Discussion in 'The Hokey Ass Message Board' started by Barn Hunter, Aug 29, 2020.
  1. Barn Hunter
    Barn Hunter
    Found a few things at the auction. Anyone know what these tail lights came off of? Thanks. 20200828_164323 (2).jpg 20200828_164331 (2).jpg 20200828_164406 (2).jpg 20200828_164514 (2).jpg 20200828_164600 (2).jpg 20200828_164626 (2).jpg 20200828_164701 (2).jpg
  2. raymay
    raymay
    Nice finds. The taillights look like 37 to maybe 40 Buick. We had a 37 Buick 4dr convertible that had similar lights.
    49ratfink, Barn Hunter and Squablow like this.
  3. 52HardTop
    52HardTop
    Yep, they're 39 to 40 Buick according to a search and ebay listings
    49ratfink and Barn Hunter like this.
  4. saltflats
    saltflats
    from Missouri
    Hold it on the end of a spinning shaft to check shaft RPM.
    49ratfink, egads and Barn Hunter like this.
  5. gatz
    gatz
    hand tachometer;
    Is useful for setting cylinder speed on machines like presses or farm combines.
    There was usually a divot or c'drill hole on the end of the shaft that the rubber tip would be pressed into.
    We had something similar that my Dad used on an AC 60 combine to set the cylinder speed for specific crops
    (saltflats beat me to it)
  6. 1320 Fan
    1320 Fan
    The tach tool is shown below out of the box in bottom photo. Rubber drive end at bottom was held against fan belt with engine running for idle speed.
    Barn Hunter likes this.
  7. Barn Hunter
    Barn Hunter
    Thanks for the replies. I thought AC Delco too when I saw it. Didn't know what a hand tach was.... 20200828_164720 (2).jpg
    VANDENPLAS likes this.
  8. catdad49
    catdad49
    Good Stuff!
  9. Ebbsspeed
    Ebbsspeed
    Nope. Think about it. If that rubber drive end was held against the fan belt it would read WAY more RPM than if it was used correctly, which is by pressing the rubber tip to the center of the rotating shaft.
    Don't bother picturing it, that's not the way it is used.
  10. squirrel
    that's the AC Delco logo....
    tractor company looks like this
  11. '51 Norm
    '51 Norm
    from colorado
    I used a contact tachometer at work in the power plant for all kinds of rotating equipment. That is until the strobe tach was invented. The real advantage to a strobe tach is that it isn't necessary to get your hands near moving machinery.
  12. X-cpe
    X-cpe
    Big farm machine for harvesting grain crops.
  13. gatz
    gatz
    Didn't mean to imply that was an Allis-Chalmers tool.
    A quick search turns up a lot of AC Hand Tachometers which are obviously AC Delco units; some having that same cylindrical box.
    Google combine harvester
  14. '40 I think.
    Ben
  15. utahdodge
    utahdodge
    I just used mine to show the flywheel rpm on an old International stationary engine. An engine like this has a flat pulley on the side to run a belt to a piece of farm equipment.
  16. wraymen
    wraymen
    @Ebbsspeed. Most of the expensive ones came in a kit with multiple attachments. A wheel was included for measuring the speed on a belt. You simply multiplied/divided the reading by two or what ever the instructions said.
  17. utahdodge
    utahdodge
    Not a true hit and miss, but the same idea.
    Barn Hunter and sgtlethargic like this.
  18. wraymen
    wraymen
    A few I have bought over the years.
    EB5DE922-342D-44F8-9C67-516A1A3609B5.jpeg 16D065C9-0B64-4A08-A2DE-7E4394C3816D.jpeg 82000784-4235-4BF7-BBC4-0B9A43EC42EC.jpeg 442EA71A-AA78-4957-A489-DD2237708DA9.jpeg A78A1641-129B-42A5-A32B-F040BD7FBA70.jpeg
  19. warhorseracing
    warhorseracing
    from cameron wv
    Must be a city boy. Have you ever seen a grain drill?
    Hnstray, egads and Barn Hunter like this.
  20. Budget36
    Budget36
    Why would you need to drill grain? ;)
    VANDENPLAS, egads and Barn Hunter like this.
  21. gatz
    gatz
    Surely you've heard of GMO (genetically modified organism)
    Once a desired trait is identified, the grain drill is used as a means to inject the desired DNA into the seed.
    Barn Hunter and Budget36 like this.
  22. egads
    egads
    From taillights to grain dna,:eek::eek: you people need to get out more !!!:):)
  23. chevy57dude
    chevy57dude
    Bait, that is!
    Haha
    VANDENPLAS and Hnstray like this.
  24. wraymen
    wraymen
    ^ I’m just responding to the OP and another poster. I’ve been ignoring the other one for quite some time now.
    Maybe if he was actually funny it would be enjoyable.;)
  25. wraymen
    wraymen
    No I’ll feelings here, post what ever you like.
  26. warhorseracing
    warhorseracing
    from cameron wv
    You need a grain drill to plant the grain for the combine to harvest or a corn planter. Yall need to get out and learn some stuff about where your food comes from. And it is not the store.
  27. Some older Gleaner brand combines were powered by 292 straight sixes or 327 V-8 GM engines, that could be used in one of those homemade hot rods, back in the day.
    Barn Hunter and Hnstray like this.
  28. Budget36
    Budget36
    Really dude? You actually mean grain is grown from the ground? WOW!
    I had no idea, can you tell me where babies come from? Always been curious about that.
  29. Hnstray
    Hnstray
    from Quincy, IL
    They come from combining two processes.......’drilling’ and ‘fracking’ (pumping fluid under pressure”......
  30. chucka
    chucka
    What was the question again?
