I'm mounting my '32 body on the frame and doing repairs to the firewall. I need pics of how the feet attach to the frame. Is there a bracket that pulls the cowl down over the feet and bolts to the frame too?
the feet of the firewall is bolted to the frame with two bolts on each side. yes , there is a bracket on each side of the cowl that you use a bolt to pull it down on the firewall...that bolt goes to the framethorugh a hole that's between the two firewall feet holes
Hambr "hotrodDrummer" posted alot of nice detail-pix in one of his threads : Here are 1 of those pix : Klaz
