Projects steering shafts & u joints on a 31 model a sedan
Discussion in 'Traditional Hot Rods' started by coody, Aug 31, 2020.
  1. coody
    coody
    need some advice.Installing a 65 mustang steering column in my sedan.I have the column cut& mounted with the end of the shaft about 1" below the floor at the firewall.I have a u-joint on the end of the shaft facing the vega steering box.I have a u-joint on the steering box.I have a dd shaft connecting the two. when i turn it,it locks up at the u-joint at the column.To much of an angle.Question- can i use a double steering u-joint to get my angle right.If i can do i need a helm joint also? hope this makes sense.tks!!
    dana barlow likes this.
  2. lake_harley
    lake_harley
    I'm close to being at the same spot on my '30 Coupe. I could see the angle was going to be too much for two "single" U-joints, one at the box and one at the column. I bought a "double" U-joint to install at my Vega steering box and will use a single at the column end. The double U-joint is a Sweet brand and I think it's supposed to be good to a 70 degree angle, but I think mine will be quite a bit less than that. Yes, using a "double" U-joint will require a support bearing near the double joint. I have a 3/4" male rod end intended for 3/4" steering shaft. The ball is machined to .757" I.D. to be able to install it over your 3/4" DD shaft.
    Hope this helps, but I think you already had it figured out.;)
    Lynn
  3. Redrodguy
    Redrodguy
    mcsfabrication and dana barlow like this.
  4. dana barlow
    dana barlow
    from Miami Fla.
    I've sure seen way too many Mickey Mouse steering set ups. Often looks like zero plan,just hook up anyway it could be. Mock up is key> often,many more then one time.
    That time you may feel is wasted on mock up yes did not do,will beat your **** for years.
    Each added u-joint,is added sloppy play<an more so if cheep joints. Try to limit your self to one u-joint at most{steering is higher priority then EX pipes or even having engine in dead center of car.
    Take the time to learn about bump steer,steering ratio and seating,view an comfort*< don't down play any of it=That's a ***** move.
    BJR, Tman, coody and 1 other person like this.
  5. X38
    X38
    Yep.
    I like to do the steering first, with minimal possible direction changes and joints. Then the exhaust. I'm not scared to fab or modify headers if necessary. Too many people want off the shelf headers then Rube Goldberg up some wacky steering corkscrews to get around them.
    The tail should not wag the dog.;)
    coody, Just Gary and dana barlow like this.
  6. coody
    coody
  7. 31Apickup
    31Apickup
    Also are the u-joints in phase? Borgeson shows that in their instructions too.
  8. coody
    coody
    tks for your input! I had to make my own column drop once i figured that out. I cut the column down as much as possible. I did mock it up with broom handles cut down.everything fit but wouldn't turn all the way.But all good.at least i have a solution! Now waiting on my 185/65/15 tires to come in for my 6x15 up front so i can move it out of the shop and do some bodywork :)
  9. coody
    coody
    yep! i learned that from borgeson on another build and always remember that.tks
  10. Kiwi 4d
    Kiwi 4d
    Borgeson is the only U joint as far as I know that is certified to operate at 35 degrees all others stop at 30 degrees.
    @coody a picture may be helpfully
