Projects short block sitting a while...
Discussion in 'Traditional Hot Rods' started by meticulousmatt, Aug 25, 2020.
  1. meticulousmatt
    meticulousmatt
    The info I can find for those pistons says they would put the compression ratio above 11:1 a gas station by me does sell 110 octane, but that would be expensive having to use
  2. meticulousmatt
    meticulousmatt
    I will be taking it to a shop to be safe. As far as the pistons go, the info i can find says they will produce a compression ratio above 11:1 with it being bored out and 64cc heads. A gas station by me does sell 110 octane, but that would be expensive having to use. I might switch to flat tops right away while it's at the shop.
    VANDENPLAS likes this.
  3. Matt, you can always use a large chamber head, 76cc were available as factory heads. See what C/R you'll get with that combination.
    Turnipseed likes this.
  4. gimpyshotrods
    gimpyshotrods
    If, and only if, that 11:1 information is correct, for 64cc chambers, aluminum 76cc heads may be ok.
    On a 4" bore, or thereabouts, 10cc in the combustion chamber is worth roughly 1 point in compression ratio.
    So an increase from 64cc to 76cc should put you at about 10:1. Plus aluminum dissipates combustion chamber heat better than Iron.
    Then, conventional premium fuel should be fine.
    Truckdoctor Andy likes this.
  5. UGOTBIT
    UGOTBIT
    from Upstate NY
    I would have ran it.
    Static comp is only part of the equation.
  6. gimpyshotrods
    gimpyshotrods
    He can't run it.
    He said short block, not long block.
    Short block = no heads.
    It is a partial short block, at that, because he's got no cam or lifters.
    RMONTY likes this.
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Looks like he honed it at home and didn't do a very good job. The hone looks more like a circle than a crosshatch. Don't mean to be overly critical but if thats the quality of the work the guy performed, you need to dis***emble it if for no other reason than to fix the honing.
    427 sleeper likes this.
  8. UGOTBIT
    UGOTBIT
    from Upstate NY
    I understand that, I guess a better way for me to say it would have been, I would not have dis***embled what is there.
  9. RMONTY
    RMONTY
    ^^^^^ exactly my point. Had this been honed by a machine, the crosshatch would have been uniform and pretty....something more along the lines of this....
  10. Looks like the hone job was done with a block home not a Christmas tree.
    doesn’t look horrible but not “text book” either
    don’t look bad but yes for what it’s worth take it to a machine shop
    Pistons are cheap also
    And should be able to sell these ones and recoup some cake in the process
    RMONTY likes this.
  11. RMONTY
    RMONTY
    You have a lot more faith in someone else's work than I do, not that there is anything wrong with that. And I am not skeptical by birth, people have helped me become that way!
  12. TrailerTrashToo
    TrailerTrashToo
    Words worth remembering.
  13. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I think I was skeptical at birth and people made me worse.........:p
