Technical X Crossmember Options For Stock Model A Frame !
Discussion in 'Traditional Hot Rods' started by chev34ute, Dec 3, 2018.
  1. chev34ute
    chev34ute
    Hey Guys.
    I have seen a couple of images of 35 to 48 Ford X crossmembers being added into 32 frames, I would like to do the same to my Model A frame. I am just wondering if anyone has done this ? I am keen to see some images.
    Hurley50 likes this.
  2. You can use a 35-48, need to trim it a little. I couldn't find one local and used a Dagel X member.
    chev34ute likes this.
  3. mgtstumpy
    mgtstumpy
    Here's a 32 style X-member
    Then there's this Dagel kit
    This is a HAMBERS with a 36 X-member
    Or this?
    Here's a transmission mount
  4. chev34ute
    chev34ute
    All look very impressive.
  5. Phil P
    Phil P
    That's the great thing about being here, I was pondering this very question before bed last night and here's a thread on the topic. Additionally I'm thinking of boxing my frame, for a low HP car (283) is a k member a necessity or just a good idea. Or can you choose one or the other. Phil
  6. grdra1
    grdra1
  7. chev34ute
    chev34ute
    It certainly is because our state department of transport has very strict rules regarding the construction or modification of frames, right down to the thickness of the metal used, the type of welding, and the need to use transmission tunnels and boxing for side rails. All of this makes building a traditional rod harder. Thier long term goal is no doubt to legislate early rods off the road, so anything I construct will need to meet these strict guidelines.
  8. akoutlaw
    akoutlaw
    I used SoCal tublar K members because I felt that they gave me more space for routing exhaust & the other necessities.
    Blues4U and mgtstumpy like this.
  9. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    In my '31 build there really wasn't any reason to drastically modify the stock frame. Modify and box the stock x-member, box the rails and put some thought into where to put bracing. Holds up well to a 5.0 HO motor with no chassis flex.
  10. pitman
    pitman
    Often made them, using .14 wall 2x4 rect tube.
  11. Atwater Mike
    Atwater Mike
    In a Model A frame, (usually boxed) I've used the 'K' member,
    A) Round tubing, 1.5" dia., .095" wall.
    B) rectangular tubing, 1.5" X 4", .095" wall.
    C) Fabricated braked sheet, .187" thick, 1.5" X 4" channel legs.
    'C' design is basically a '32 center member, braked and welded to close spec.
    Scale 52"-60" wingspan Control line airplanes were harder than this... all bulkhead, stringer, and rib inclusive...Hand cut, and plans hand drawn...Some of us 'die hard'!
  12. Aaron D.
    Aaron D.
    I put a 39 X member into my stock model A frame. It took a ton of work, but it does stiffen the frame well.
    Blues4U, Tim, 48fordnut and 1 other person like this.
  13. UGOTBIT
    UGOTBIT
    from Upstate NY
    I know this is an old thread, but does anyone know if anyone offers the 32 K member rear leg braces in a Model A frame like these that mgtstumpy posted?
    My workspace is, well, not as nicely equipped as the one pictured. chassis with 32K and brace.jpg
  14. UGOTBIT
    UGOTBIT
    from Upstate NY
  15. Benny28
    Benny28
    from Australia
    This is what I came up with using my original cross member still tossing up weather to brace it
    sloppy jalopies and chev34ute like this.
  16. Aaron D.
    Aaron D.
    Looks nice Benny.
  17. sloppy jalopies
    sloppy jalopies
    Yes on the K member as it adds a ton of strength to the crossmember...
    the pedals want to twist the x member forward...
    the left K member really helps re-enforce the crossmember against that twist...
    if I box my '32 frame it will be about 8" fore and 8" aft of the firewall and about 24" from the flat of the rail up and to the apex of the kick...
  18. dsiddons
    dsiddons
    from Indiana
