Projects The Resurrection Roadster
Discussion in 'Traditional Hot Rods' started by Roothawg, Sep 5, 2020.
  1. Roothawg
    Roothawg
    0030DA58-95B8-4FE2-8480-2018B04534EA.jpeg 22922578-AABA-4099-8245-C9FC40C7BD5A.jpeg FEF67AC9-91CC-4173-A8F3-14468AED91F9.jpeg Some of you know I found an old
    Survivor model A roadster from the St Louis area a while back. My wife and I have been driving the wheels off this car. It’s so much fun. The problem was it was needing some love and tlc.
    The car was built in 56 and ran at the local STL tracks. It was resurrected in the 90’s and got a new lease on life.
    I picked the car up and the DP primer that was sprayed in the 90’s was flat and showing it’s age.
    Second gear was missing some teeth but we drove it anyway. We logged about 4K miles this summer going from first to third.
    The interior was sort of a harvest gold and reminded me of my mom’s barstools from the 70’s. It looked sort of homemade.
    The old Strombergs were leaking so bad that people would pull up beside me and tell me that they were puking fuel.
    We didn’t want to stop driving the car, so we waited until the heat of the summer when it wasn’t any fun to drive. When it reached 100 F we started tearing into it.
  2. Roothawg
    Roothawg
    C3F6BD68-46D2-46A8-8861-1BF572E69732.jpeg BC5805B2-71B5-4F62-BA41-F8C8343EBDD8.jpeg One of the things that bothered me most about this car was the homemade seat. It had a steel bar that ran right through the middle of our lumbar. I was afraid that if we were ever rear ended, we would be paraplegic. It doesn’t help that I was raised by a crash test engineer. My dad ran the crash sled for the FAA for 25 years.
    Here is a few pics of the seats. They had some sort of black foam or something that was decomposing. It had seen its useful life. I’m pretty sure that this was a mix of bus seats and boat seats. One of the arms was completely broken as well.
  3. Roothawg
    Roothawg
    I figured while I had the motor and ****** out I would address some of the leaks. This would help keep mama happy if it wasn’t marking it place. The motor and ****** were pulled. It’s my first experience with a closed driveshaft. A lot of questions on the HAMB.
    AA578582-706F-47CC-B11A-ABBA2050B14A.jpeg CAE5826C-A133-4638-A05A-C232E0001015.jpeg 50729D0D-4CD4-4D26-B0B2-9D6EBB85F790.jpeg
  4. Great job man,,,,,,,repair it and put it back on the road .
    Put a 100 thousand miles on it,,,,,,then keep driving it,,,,LoL .
    That is a nice old hot rod,,,,,,y’all enjoy it !
    Tommy
  5. Roothawg
    Roothawg
    Mama and I had a DA party. The original bodywork was pretty decent. No hidden surprises. Well, except for the fact that the previous owner had possibly used Armor All or Pledge on the body.
    EA1B7258-0F3D-4F77-A598-E116583E50B3.jpeg 2318844B-7230-4737-8076-141FDB2F2F68.jpeg
  6. lumpy 63
    lumpy 63
    Silicone contamination Root?o_O
    Dan Hay and loudbang like this.
  7. Roothawg
    Roothawg
    Big time. I won’t go into it, but I’ll show you a sample of what happened. This is after 3 rounds of wax and grease remover. It was stripped 3 times to bare metal and sealed. Anyway, it’s staying in primer. It will be good enough for a driver.
    chryslerfan55 and Okie Pete like this.
  8. Roothawg
    Roothawg
    I tried out Slick Sand poly for the first time. I really like this stuff. It sprays nice and blocks out even better.
    FBA62B61-6ACC-4209-A3A7-776748CFA8AA.jpeg 46B7ABBC-BB7A-427F-8942-B4CBC6650E10.jpeg
  9. qzjrd5
    qzjrd5
    from Troy, MI
    Awesome car!!
  10. Roothawg
    Roothawg
    So after a few days of blocking, we put it in sealer. It’s staying in sealer. The car is nice, but not worth an acid dip to fix the fisheye issues. It actually laid down pretty well.
    2417D141-D38D-4393-8786-988B9D1BB2A0.jpeg EE03C32B-060D-468A-8446-D0200F8D6D13.jpeg 6B8CF536-3AD1-4EF9-8973-BA8ECF9B8160.jpeg 73ACAED2-D6FF-46CA-843B-6B276BCDB21F.jpeg 6E04D98D-C608-4C1F-A8B8-8DCD5C95928C.jpeg
  11. Roothawg
    Roothawg
    Every hot rod deserves a Wimbledon White firewall.
  12. Roothawg
    Roothawg
    Started re***embling the car today. We have a week off, so we are going to try to get a lot done.
    2CDCD134-8EA8-49BE-9DC9-A1040C0724A8.jpeg F198B654-0ECD-4066-B800-925E9B15E63C.jpeg
    Replaced the old jute back insulation with some new Kilmat. This car never had many rattles, but this will take it to the next level.
  13. panhead_pete
    panhead_pete
    Oh man that must have been frustrating! What a great looking car, awesome to see it get some love!
    Outback, chryslerfan55 and Roothawg like this.
  14. Roothawg
    Roothawg
    I started laying out seat designs and quickly decided to farm it out. I usually do all of my own work, but the seats alone could eat up a couple of weeks. I decided to make a few phone calls and ended up ordering a set of custom frames from Nicole at Wise Guys Seats. They weren’t cheap, but I am impressed at the quality. They are a lot heavier duty than I would have built. They have a recline feature as well. I doubt I will use that feature once I get them set, but it does help, since the car is heavily channeled. They also came with foam, but that will have to be trimmed to fit, since these frames have been narrowed and shortened. 59D18DEF-841E-4BD3-8258-3B2BD1143F69.jpeg
  15. Looking GOOD Root......
    loudbang and Roothawg like this.
  16. AHotRod
    AHotRod
    Nice Hot Rod Chris
    Roothawg likes this.
  17. lumpy 63
    lumpy 63
    Silicone ****s ***...WD 40 isn't allowed at the shop.
    flynbrian48, loudbang and Roothawg like this.
  18. lumpy 63
    lumpy 63
    Is the 265 going back in ?
    pitman, Roothawg and loudbang like this.
  19. Taboo56Chevy
    Taboo56Chevy
    Sweet little roadster! Why did they only have one fuel pressure regulator on the main middle carb? seems like there the other two that are getting too much psi and leak all the time.
  20. x77matt
    x77matt
    Love it!
  21. Knew you were refreshing it but did not know you tore it down that far! 4k!?!?!?! AMAZING
    Outback and loudbang like this.
  22. Tim
    Tim
    from KCMO
    I’d say the ends are blocked off
  23. loudbang
    Well shoot does this mean the refresh of the 55-56? Ford is being put in the corner for another day? ;)
  24. Roothawg
    Roothawg
    Yes.
    Okie Pete and loudbang like this.
  25. Roothawg
    Roothawg
    Tim is correct. The end two were dummies. I can’t do that. More to come on the fuel system.
    chryslerfan55, Okie Pete and loudbang like this.
  26. Roothawg
    Roothawg
    Just temporarily. We are pushing to get this up and running for the Gathering at the Roc. That’s in October, so we are pretty humped up on it.
    Sorry, guy I don’t know how to use multi quote. I am technology challenged.
  27. ramblin dan
    ramblin dan
    That is awesome. Keep those pictures coming it's inspiring me to get my **** outside and work on mine.
  28. Great little car! Do you have any pics of it from its early days?
  29. continentaljohn
    continentaljohn
    Cool roadster and digging the rebirth
  30. Roothawg
    Roothawg
