Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. alanp561
    alanp561
    chryslerfan55 and WTF really like this.
  2. brokedownbiker
    brokedownbiker
    Spent the day wiring up and plumbing my new air compressor- the old one went ***s up right in the middle of a project (of course!). I finally broke down and bought a big vertical tank rig with enough volume to paint and run air tools; I can actually try my hand at painting! I've always had to make do with small compressors that required frequent breaks to let the compressor catch up when using air tools- no more of that!!
    Yeah, I'm a little excited, a new air compressor is a major event these days..... I don't get out much, lol.
  3. alanp561
    alanp561
    With the help of @harley jim , I solved a couple of problem's that have been destroying my sleep for weeks. Namely, how to make my radiator and grille shell fit and how to mount them. I laminated 3 pieces of 1" foam insulation board and formed it into the same size and shape as a 65-66 Mustang radiator. Grille shell is 49 OT Oliver. I like the Oliver 'cause it looks aerodynamic and the Mustang radiator cause it fits inside the shell just right. The grille shell will look really good with 3/8" vertical tubes formed to fit it's rounded shape. Think of it as a poor man's track nose;) imagejpeg_0 (1).jpg 20200913_174043.jpg
  4. Jeff J
    Jeff J
    Finishing up on the A/c in the 65 chev truck . Ran the defr Chevy frame 015.JPG Chevy frame 017.JPG Trucks 013.JPG oster tubes and vent tubes behind the dash Got the new glove box in ! truck 001.JPG
  5. lumpy 63
    lumpy 63
    Pulled the engine out of my 59 Vette project today. Turned out to be a 57 283 block punched out to 301, had big pop up pistons and 1970 double hump heads with 2.02 valves. When I pulled the pushrods I could see pipe cleaners stuffed in em:D The other guys in the shop had never seen that before.I explained this was done back in the day to restrict oil to the top end.It also had a huge home made deep sump pan that was pretty crude. Good day in my book.
  6. jakespeed63
    jakespeed63
    Helped Club brother dial in timing and carb on his 427 CSX Cobra
    Then proceeded to not only accidentally snap off the clear float level indicator, but after removing and installing front float bowl, stripped one of the upper retaining bolts
    Ugh! [emoji107][emoji22][​IMG]
  7. dirt car
    dirt car
    from nebraska
    Procrastinated for some time but finally convinced my 76 year old body to drill the 15 rivets out of a junk wide 5 Ford rim to provide a center take along in the search for suitable wider 15"-16"-18" donor hoops, I was shocked it took just shy of 35 min. Glad to give suggestions & tips to anyone wanting to do the same . Be safe everyone, Ron Baker
  8. railcarmover
    railcarmover
    Counted gear teeth...
    chryslerfan55, ct1932ford and mctim64 like this.
  9. Blues4U
    Blues4U
    from So Cal
    chryslerfan55 and mctim64 like this.
  10. thehazguy
    thehazguy
    Won the N-3 Nostalgic cl*** at Island Dragway's 60th anniversary meet. My brother and my nephew were there to help, watch and enjoy the win with me. Family "Rocks" Be safe everyone. 60 ID trophy.jpg 60 ID winners circle.jpg
  11. 31Apickup
    31Apickup
  12. junkyardgenius
    junkyardgenius
    from Kernow
    Started making up a throttle linkage..
  13. Caprice89
    Caprice89
  15. slim38
    slim38
    from Sudan TX
    Lowered the *** end of my 49. FedEx showed up with the kit and I literally had it all put together in about 40 minutes. Hadn't even torqued it yet but had to get it out to go pick up my son at school. 20200914_160152.jpg
  16. TA DAD
    TA DAD
    from NC
    chryslerfan55 and j hansen like this.
  17. High test 63
    High test 63
    I found out about a guy with a garage full of chevy parts for sale... I managed a little bit of bottom feeding... IMG_20200913_155537941.jpg
  18. BLACK STUDE
    BLACK STUDE
    IMG_20200915_121349703~3.jpg Finished one cover, slipped it over the seat to get a look. Should snug up a bit after the seat foam is in place. Happy with it for a first shot at this upholstery stuff. The old Studebaker might not be the fastest, but it will look good trying.
  19. Black_Sheep
    Black_Sheep
    Out running errands tonight and I spotted a nice 55 wagon with it’s hood up at the BP. It was still there on my return trip so I wheeled in to offer help. It turned out to be a long time acquaintance in a new to him '55 Chevy wagon. The ground cable was loose so it was a quick fix. 119708578_3235014756535983_952320039040771969_o.jpg The 55 was pretty cool, once Steve sorts out a few things it’ll make a nice cruiser...
  20. Departed
    Departed
    from Canada
    I rebuilt a distributor for the Goose. She runs good now!! Watch out here I come !!!!
  21. Departed
    Departed
    from Canada
    Fired up this old mill today.. havnt run in a decade, fired right up on the first crank!!! IMG_0871.JPG
  22. RICH B
    RICH B
    Came across some measurements on the Ford Barn for the back panel a while back; finally made one yesterday. Now just need to pull and paint it.
    chryslerfan55, Lil32 and j hansen like this.
  23. LAROKE
    LAROKE
    From the BillyBob Shop log
    September 17th 2020 Had a false start on getting my ambition back. It's a process. My deep ponder mode ruminations tell me that one day of work in the shop is an anomaly, three continuous days, a pattern, six days a trend, twelve days a habit and twenty-four days a discipline.
    On Labor Day, the daily heat wave temperature dropped a couple of degrees, just enuf to jump start garage activity again.
    Found a vertex magneto for the nailhead build and bought it as a birthday present to myself. I've been looking for one of these for a few years now. I was beginning to fear Tommy Ivo had used them all up. This thing was new in the box. A couple of bronze gears were included as well.
  24. RICH B
    RICH B
    Made a gizmo to set the serrated hinge pins without having to pound on the hinge and chance moving them or cracking the paint. Actually worked quite well.
  25. winduptoy
    winduptoy
    Squirted some paint on the fixit to the rear fender belonging to the Vicky IMG_20200917_091150172_HDR.jpeg
    Sent from my XT1585 using The H.A.M.B. mobile app
  26. PhilA
    PhilA
    All I did was look upward, but tonight the sky was interesting, louvered!
    Is it a sign?
    Phil
  27. pirate
    pirate
    from Alabama
    Well last couple days been dealing with aftermath of Hurricane Sally in coastal Alabama. Worked on generator to get it going after sitting (my fault for not starting it more often) then hooking up cords to various parts of house. Then helping elderly neighbor with tree fallen on house and keeping his generator running and full of gas. Trees down everywhere. But life is good and thankful wife and I or none of neighbors were hurt. Have a lot of clean up to do but have a way to cook, refrigerator running for a cold beer after working, no A/C but fan running. Nothing like the sound of generators in the wee hours and probably a week plus without electricity. But this too shall p***! The price you pay for not shoveling snow.
  28. Filled the gas tank in my '50 for the 10th time this summer. I should check to see how many miles I've gone. :)
    chryslerfan55, High test 63 and Lil32 like this.
  29. slim38
    slim38
    from Sudan TX
    Built some battery cables for my 49 to replace the ****py ones that were on it. I used welding lead cable and br*** ends. Fires off beautifully everytime now. 20200908_153823.jpg
  30. 65pacecar
    65pacecar
    from KY, AZ
    Prepping the gas tank for installation 3DF48427-2E47-491E-AE84-A176DEF747E6.jpg
