Projects Mild custom '51 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by PhilA, Nov 4, 2019.
  1. PhilA
    PhilA
    Not many pictures tonight because this is dirty work.
    Put the car back up on stands. Pulled the front passenger brake off.
    Removed the old flexi pipe, cylinder. Removing the cylinder showed it had been leaking too.
    New hoses checked; they don't catch on the wheel at any steering position on full droop. I'll check again on full bump when it's down on its wheels. There's a bit of adjustment available.
    Phil
  2. Lloyd's paint & glass
    Hey Phil, I've been slacking on checking in here, but if you have that door glass out again, trace it on a piece of paper, fold it up and send it to me. I'll get a new piece headed your way. Glass is free, you can pay me back for the shipping someday ;)
  3. patsurf
    patsurf
    that is going to earn you some cred--good man!
    loudbang and PhilA like this.
  4. PhilA
    PhilA
    I've gotta lift the glass back out to do the channels properly, so I'll trace them out then. Thank you.
    You need an acid etch to stamp your auto glass with. Hm.
    Phil
    Nostrebor and loudbang like this.
  5. Lloyd's paint & glass
    Anything i can do to help you know I'll be there ;)
  6. 57 Fargo
    57 Fargo
    Hey Lloyd your slowly convincing me you are a good guy! Lol. Seriously nice thing to do
    Ford52PU, loudbang and PhilA like this.
  7. Lloyd's paint & glass
    Hey those door glass aren't that big, I've got tons of scrap out there in the rack that'll cut a door glass. Worst part might be that it's green tint??? I save those pieces to help out my friends when i can :D just doing my part, hell my 57 would be sitting there if it wasn't for a couple of guys here. Great bunch of people, for the most part ;)
    slv63, Nostrebor, loudbang and 2 others like this.
  8. PhilA
    PhilA
    Nope, whoever bought this didn't fork out for tinted glass, it's fully clear.
    Phil
  9. Lloyd's paint & glass
    Let me check but I'm pretty sure all i have is green tint Phil. But I'm sure i can come up with a piece of clear if i don't have any.
  10. Lloyd's paint & glass
    Granny always said that I was her favorite, but she was a heavy drinker :rolleyes: good woman though....
    Woogeroo, Chavezk21, 37hotrod and 3 others like this.
  11. 302GMC
    302GMC
    from Idaho
    E-Z-Eye glass doesn't become an option on Pontiac until '52
  12. PhilA
    PhilA
    That'll be why then. I guess that was "the next big thing", single piece front window, tinted glass...?
    Phil
  13. PhilA
    PhilA
    Just ordered a length of 2/0 welding wire, so I can finally relocate the battery out of the passenger footwell.
    Phil
  14. PhilA
    PhilA
    Old. Faulty. Missing parts.
    New, greased, all good.
    Need some 1/4" brake line and a flaring tool, then.
    This was "all new" in 2015, according to the advert...
    Phil
  15. Lloyd's paint & glass
    That was almost 6 years ago! Whatya expect out of this new steel Phil :D
    Woogeroo and loudbang like this.
  16. PhilA
    PhilA
    I shouldn't be upset. It's the first fixing that's broken during my tenure.
    Phil
  17. PhilA
    PhilA
    Went shopping. Ready for tomorrow.
    Brake line to front right looks pretty new.
    Front left.. ropey. To the rear, also ropey. Should have enough on the spool to redo to the back.
    Phil
  18. Lloyd's paint & glass
    I can already smell the brake fluid :D
  19. PhilA
    PhilA
    That I don't mind.
    My future contains EP-90 gear oil. Old EP-90. That is easily amongst the worst smells on a car.
    Woogeroo, Chavezk21, Ford52PU and 3 others like this.
  20. PhilA
    PhilA
  21. PhilA
    PhilA
    "New".
    ... I don't think so.
    David Gersic and loudbang like this.
  22. PhilA
    PhilA
    Work brought to a halt by the thread on the flaring tool stripping.
    Great
  23. Surfcityrocker
    Surfcityrocker
    from Austria
    So the "Lifetime" guarantuee of the flaring tool referred to the lifespan of a mayfly.
    Woogeroo, loudbang and PhilA like this.
  24. PhilA
    PhilA
    Pretty much. I got a refund and went bought another one, still the same basic idea, still the same basic junk but hopefully between the two I'll finish the job. Only got two more flares to make.
    Still, got the car jacked up, the front to rear line put in, front left pipe done.
    Looks a bit better coming off the master cylinder now.
    I cleaned up the rear tee block, that was just a wad of gunge with a few pipes coming out.
    Made up a new pipe for the rear left wheel.
    Got the wheel off. The shoes didn't look that old but they were falling apart, the top bias adjuster took a good leg-heave on a 8' breaker bar to free off.
    Cleaned it up, greased it and now it rotates correctly.
    Got the lot stripped down to the backplate, reassembled it all and forgot to take a picture before putting the drum and wheel back on.
    Rear right is left to do. I'll call California Pontiac Restoration on Monday and see if they have an expected due date for the right rear cylinder.
    That's definitely enough for today. I hate brakes.
    Phil
    Woogeroo, bchctybob, ClarkH and 7 others like this.
  25. patsurf
    patsurf
  26. PhilA
    PhilA
    Yup. A length of tube, all the way out from under the back of the car, given a shove.
    CLANG! It went off with quite the report. I thought I had broken my socket to begin with.
    loudbang and TrailerTrashToo like this.
  27. PhilA
    PhilA
    I also really should invest in a proper spring tool. Grabbing brake shoe springs with my channel-loks and fighting with the springs is less than ideal.
    Wind is picking up here, getting the back end of the storm that's in the gulf right now (beta). Tomorrow the plan is to run a new hard line from the tee to the passenger side rear wheel, replace all the hardware and grease everything up, including freeing off the adjusters, in preparation for new hydraulics.
    I might adjust the other brakes up if I have time, too. I need to get a cable grommet while I remember, also.
    List is getting shorter.
    Phil
    brEad, loudbang and TrailerTrashToo like this.
  28. PhilA
    PhilA
    Slight change of plan. Backordered brake cylinder has shipped so I'm putting a halt on work until that arrives.
    Phil
  29. PhilA
    PhilA
    Just to say I did something today, I cleaned my hubcaps.
    Grubby, and I hadn't polished the red after painting it.
    They're old and hazy but at least now they're clean, and the red has a bit of a sheen to it.
    Phil
  30. PhilA
    PhilA
    Look what was in today's mail. More toys!
    Phil
    Woogeroo, bchctybob, loudbang and 4 others like this.
