Projects Aussie 32 frame / Model A coupe build.
Discussion in 'Traditional Hot Rods' started by Wardog, Feb 7, 2019.
  1. waxhead
    waxhead
    from West Oz
    Nice work on the patch panels.
    Stogy likes this.
  2. Wardog
    Wardog
    Thanks mate. I feel like I’m getting somewhere lately.
    Stogy likes this.
  3. Wardog
    Wardog
    Haha. Thanks, I’m glad I impressed such a pair.
    Stogy likes this.
  4. Wardog
    Wardog
    Thanks, they should blend right in.
    Stogy likes this.
  5. Benny28
    Benny28
    from Australia
    Stogy likes this.
  6. Wardog
    Wardog
    Cheers @Benny28 Still heaps to do mate.
    Stogy likes this.
  7. Wardog
    Wardog
    Yesterday I sanded the wheel wells and painted the body patches.
    This week at work I noticed a pile of old v belts that we no longer had a use for. I took one home thinking I could cut it to length and take it to the shop as a guide to buy what I needed. It fitted perfectly, so I also bought home the other 2 as spares.
    Deutscher, Jet96, mgtstumpy and 9 others like this.
  8. Outback
    Outback
    from NE Vic, Oz
    I love it when things come together like that!
    Stogy likes this.
  9. Wardog
    Wardog
    I've got to have a win every now and then.
    Stogy likes this.
  10. Wardog
    Wardog
    Whoever used to own my coupe needs their drill and body filler confi****ed...
    I found more after I took this photo...
    Deutscher, Jet96, mgtstumpy and 3 others like this.
  11. Wardog
    Wardog
    I painted the wheel wells satin black today.
    9B424DD3-04CC-4A1B-8D9D-D79CC9696D15.jpeg 2C4175AA-FCAA-4939-A08E-9AD73002D403.jpeg
  12. Stogy
    Stogy
    Every one of those holes were drilled with Hotrod Love...or is it better than Bullet holes...probably neither...making it right then pinstripes...;)
  13. Wardog
    Wardog
    So much better than bullet holes. If I had to beat everyone of those holes back out that fire wall would be all over the place.
    Stogy likes this.
  14. Beanscoot
    Beanscoot
    Less bullet holes in Australia.
    Stogy likes this.
  15. Atwater Mike
    Atwater Mike
    Ward, I'm approaching body sub rail procedure on my '27 Touring. Your pics helped immensely, great decisions and fabrication.
    Was moving along, then life tripped me up. I have a nice rear section from the 'C' pillars back, (fronts of rear doors) but was undecided on the sub rails.
    '32 frame is narrowed, pinched and shaped to fit the '27, (had a 'gl*** '27 roadster body, then I found the steel tub)
    Not an overnight job. Thanks for all the details, your header reshape was great.
    Where do the tight bends in tubing come from? Someone had a 2" 'donut' some years back, grabbed some, used them. Haven't seen them lately.
    Stogy likes this.
  16. Wardog
    Wardog
    @A****er Mike Its great to hear this thread has helped someone else along with their progress.
    I searched and gathered info on here and the net myself so I kind of see it as paying it forward.
    I bought a 5” OD donut in 1.75”
    tube for the headers. I ordered it on line but can’t remember where. It wasn’t hard to find.
    brEad and Stogy like this.
  17. Wardog
    Wardog
    When filling holes I try to stay away from welding with a br*** block behind.
    If possible I make a filler piece and weld it in. I have a punch that can pop out discs up to 1/4” but a lot of the holes in my firewall were larger.
    So I made a disc punch to pop out larger slugs. It makes 3/8” and 12mm. Then I drill the holes out to the closest size and fill it with a punched disc.
    This is a hole I drilled out to 3/8” and tapped a disc into. It will make for a neater job with less heat distortion from the weld.
    Deutscher, Stogy, Jet96 and 7 others like this.
  18. Cool hole punch!
    Stogy likes this.
  19. Wardog
    Wardog
    Thanks, it works well.
    Stogy likes this.
  20. waxhead
    waxhead
    from West Oz
    Nice work
    Stogy likes this.
  21. Wardog
    Wardog
    Thanks mate.
    Stogy and waxhead like this.
  22. Wardog
    Wardog
    I had some good progress this weekend.
    I filled all the unwanted holes in the firewall.
    The body was bolted down properly with the new body blocks for the first time.
    1041D9E6-64DE-40FC-9938-BB29E0D742E5.jpeg B038B8F2-4B19-49CA-8436-27CDA4B0E8AC.jpeg
    I made a template for the sheet metal to go around the steering column and pedals.
    Then I turned my attention to the rear floor. This panel comes in the Steadfast kit. I had to modify it to clear the rear u bolts.
    Deutscher, Stogy, Outback and 5 others like this.
  23. Wardog
    Wardog
    This weekend I made a bracket to support the steering column at the dash. It’s rock solid and hides well under the the fuel tank.
    6F6473F4-6175-4E52-B976-48A8BA861BF3.jpeg E15B29CE-D73E-479B-B967-C3F830C8705E.jpeg 6B602923-DC9F-4B74-AD28-8DCC7CB34B69.jpeg B93D4626-BFC4-44D7-A7BF-30140F857EEF.jpeg
    Then I made the patch for the fire wall that goes around the steering column and pedals.
    Deutscher, Stogy, Outback and 3 others like this.
  24. Coming up a treat mate !
    Stogy likes this.
  25. Wardog
    Wardog
    Thanks mate.
  26. Wardog
    Wardog
    This weekend I worked on my grille. I relieved the sides to drop it down so it lined up with the cowl but still run a full size insert.
    I cut up a little bit so I wasn’t messing around with the mounting points on the shell. I marked 1” then 1/4” intervals.
    I used the hood top I used to have on the car to set the height by lining up the belt line of the body and hood.
    I ended up taking out 1 1/4”.
    E1F1C2DC-DFF8-45ED-BE29-AB302BCA09EA.jpeg C8D04545-3DAA-46E8-8389-FD4119C43493.jpeg D2B4F841-F116-4C46-BCCB-A1BDFA856D0D.jpeg
    Deutscher, v8paul, Stogy and 8 others like this.
  27. brEad
    brEad
    That was a pretty slick idea to dial in the height of the shell! Looks like you nailed it.
    Stogy likes this.
  28. Wardog
    Wardog
    Thanks @brEad it turned out pretty neat.
    Stogy likes this.
  29. Wardog
    Wardog
    I made a start on the floors.
    I had to make a trans hump. So I tried to make it as small as possible and styled it like a 32 trans cover.
    Deutscher, teach'm, Stogy and 6 others like this.
  30. Outback
    Outback
    from NE Vic, Oz
    You are smashing it out @Wardog looking good! Highboy I ***ume?
    Stogy likes this.
