Projects A New Deuce Project.....Chevy II style!
Discussion in 'The Hokey Ass Message Board' started by Roadsir, Sep 30, 2019.
  1. Roadsir
    Roadsir
    Lots and lots of choices our there. I'm not after pro-touring, weight and cost will be factored. A Smithcraft could save up to 150 lbs, whereas a CPP about weight neutral but a lot less cost.
    I left out any Hoffman group companies!
    Smithcraft
    https://smithracecraft.com/product-categories/round-tube-front-ends/62-67-chevy-ii-nova-frame
    Chris Alston
    https://www.cach***isworks.com/c-1828-nova-62-65-chevy-ii.aspx
    Churchboys
    https://www.churchboysracing.com/
    Speedways G Comp
    https://www.speedwaymotors.com/G-Comp-1962-67-Chevy-II-Nova-Front-Suspension-Kit,147272.html
    Detroit Speed
    https://www.detroitspeed.com/1962-1967-chevy-ii-front-suspension
    Scotts
    https://www.scottshotrods.com/1962-67-nova-ifs-front-clip/
    CPP has there set up that uses the original subframe
    http://www.cl***icperform.com/Store/1962_67_Chevy_Nova/6267TCAULKB.htm
    Fatman has a setup to use modern struts with the original subframe
    http://www.fatmanfab.com/product/1962-1967-nova-independent-front-suspension-ifs-kits
    TCI
    https://totalcostinvolved.com/products/1962-1967-chevy-nova-custom-ifs/
    brEad and loudbang like this.
  2. landseaandair
    landseaandair
    from phoenix
    I'd prefer The Church Boys stuff on the stock frame, could even just use their upper control arms since that's where all the main benefits are. Maybe later upgrade to the lowers, rack and pinion & coil overs if you want. I can't say I'd never put a clip on a Chevy II, especially if I got a really good deal but I like the look of a stock frame and walk by all the open hoods with missing shock towers at the shows.
  3. Nova Thug
    Nova Thug
    from SG Vizzle
    The CBR stuff is really nice.. You can buy it in phases and build it over time.. They now offer a front clip that you can add to their existing suspension parts to up grade the total front end..
    The Smith Racecraft is ridiculously light..
    If you’re thinking of HP and torque levels mentioned earlier here you’re going to have to fortify the unibody structure.. The ch***is will flex and twist quite a bit just daily driving with out big power stress loads. Once you start making suspension mods the body will start to compensate for the new suspension..
  4. Roadsir
    Roadsir
    Yeah the Smithcraft trims 150lbs! but it looks a little racy not sure how it would with more street duty ( though this really wont be cross country car. CB might be the way to go.
    I do plan on tieing the subframes. Would like to fab my own, like the Chris Alston version below. A cage will help a lot as well.
    brEad, loudbang and AHotRod like this.
  5. DDDenny
    Hope you don't mind some hijacking your thread.
    My Nova is purely a street car but the upgrades I did on it are about the closest thing to a full tube ch***is while still retaining its full original floorpan.
    I built a 2x3" "backhalf" ch***is based on custom rails bent by Art Morrison from templates that I furnished, the thin original rear frame stubs were removed without altering the trunk pan, the new rails hug the stock floorpan kickup perfectly.
    I built the crossmembers as well as the subframe connectors, and tied it all together with an eight point roll bar based on Morrison components, the diagonal tubes off the main hoop run through the floor and tie into the subframe connectors, also tied it to the floor through the two floor drain plugs.
    By the way, those diagonal tubes are required when drag racing a unibody car, I don't believe the two forward (side) roll bar tubes are considered legal for drag racing but that was never part of my plan anyway.
    The original forward floorpan and front subframe are also tied in to the custom front crossmember and as with the rear suspension the front is not mentioned due to being a bit taboo here.
    Sorry, never took photos of the ch***is build but here are a couple topside shots, also a shot of the tubular trans (Muncie) crossmember which should also add some rigidity, the car is very low so the exhaust p***es through those two big tube sections.
    20170903_112224.jpg 20170903_111808.jpg 20170903_114420.jpg 20181223_105933.jpg
    Deuces, brEad, kidcampbell71 and 3 others like this.
  6. Roadsir
    Roadsir
    I welcome the ideas. Great planning and fab on what you did. I was planning the diagonal bars and thinking it would be good make sure there are crossmember / structure below those areas for sure
  7. Nova Thug
    Nova Thug
    from SG Vizzle
    There are a number of different strategies that can be employed to build up the ch***is structure. An internal cage will go a long way towards fortifying the body as well as protection for the driver but if this is to be a street driven car a cage can be ***bersome especially if you have p***engers. I like tying as much of the car together as possible but you will have to determine how fast it’s going to be and build your cage to the cl*** it will likely need to be certified to.
    loudbang and Roadsir like this.
  8. DDDenny
    I also built a shock tower strut.
    Deuces, BradinNC, Baron and 1 other person like this.
  9. Roadsir
    Roadsir
    @DDDenny That's a smart looking piece.
    Spent more time looking at the CB stuff, warming up to keeping the original subframe.
    loudbang and kidcampbell71 like this.
  10. DDDenny
    Sent you a PM.
  11. Roadsir
    Roadsir
    A few parts I found at the Twin Cities Roadster Swap.
    Chevy Deuce grilles are a lot cheaper Ford Deuce grills.
    Deuces, brEad, kidcampbell71 and 2 others like this.
  12. The ideaman
    The ideaman
    Back in the 90's I had a series of chevy II' s as drivers, back when they were reasonably priced. Like many of you, I wish some were still in the garage. How about a Blueprint Engines 400 sbc. 508hp and 470 ft/lb' s for $5800. Any updates?
  13. DDDenny
    I was about to ask if anyone had heard from you but I see your post in the cl***ifieds so I know you're around here still.
    What's hapn'n with the Chevy II?
  14. Roadsir
    Roadsir
    Thanks for asking! Not dead yet, just literally fell off the face of the earth....We listed and sold our home of 20+ years last fall, sold, and moved to a neighboring town of 600 folks, 2 bars and I think there's a Church but who knows:) We moved in December into a beautiful home on 1.4 acres overlooking the MN River Valley with more garage but the place needed some updates. With COVID i'm on a 10% reduced work and salary. It's come at a good time in terms of getting projects done. So, New I've done, new carpet, new luxury vinyl tile, throughout, painted 8 rooms. Finished insulating, rocking, taping, painting the garage and added separate service panel in the garage. Built overhead storage, and bought a 12 X 20 storage shed.
    I still have a condo garage 20 X 40 (800 sq ft) that is 15 minutes away, but in our little berg there is a neighborhood of steel buildings buffering a residential and a industrial space, but all the buildings were sold. I put a posting up on the community facebook forum looking for a building and got a message pretty much immediately. I had several interested people in my Condo Garage, so after a week of back and forth I sold the Condo garage (close Sept 1st) and purchased a 32 X 48 (1536 sq ft) Steel building that is heated, wired, spray foam insulated but needs to be tinned out on the inside. I close on that next week and will have a couple weeks to move everything (race car project, roadster project, nova project, plus equipment and parts). So it'll be a busy *** August to get everything moved.
    I hope to be back on the cars this winter....
    brEad, Chucky, greaser and 3 others like this.
  15. Roadsir
    Roadsir
    Here’s a few pics
    This is an old image but my shop is a a block from our house on hazel lane (across a pond) This is the type of community where a lot of folks wheel around in utv’s , side by sides, or golf carts.
    Deuces, rod1, brEad and 9 others like this.
  16. DDDenny
    Wow, a new place, not counting all the work that must be pretty exciting.
    Roadsir likes this.
  17. Roadsir
    Roadsir
    Well, tomorrow I start moving 8lb of **** into a 15lb bag. The extra space will be nice, though it’s going to take some work to get the inside tinned out, a few more outlets, airlines etc.
    Shop that I sold to a good friend. It will have some nice equipment going in.
    Deuces, AHotRod, brEad and 7 others like this.
  18. loudbang
    Wow those Airlines must use some pretty small Planes to fit more than one in there. :rolleyes:
  19. Roadsir
    Roadsir
    Damn auto type. ......
    Serious heat and humidity today. I’m thinking I need to have a combo open house and swap meet. I’ve got way more than I will ever use.
    Deuces, AHotRod, brEad and 3 others like this.
  20. Nova Thug
    Nova Thug
    from SG Vizzle
    Nice looking shop..
  21. Roadsir
    Roadsir
    Thanks....Haven't got much accomplished much on the cars, but hope to start making headway on car and shop projects starting in October.
    Also excited to hear that our local Twin Cities Roadster Swap meet is back on at a different location, so hopefully I can sell some early Ford Parts and Replenish on Nova parts. I've been looking at Church Boys Racing and Smith Racecraft products to get some ideas and plan, more to come!
    loudbang, brEad and kidcampbell71 like this.
  22. Corn Fed
    Corn Fed
    Good to hear you are about ready to get back to turning wrenches.
    Where/when is the swap going to happen? Is it still being put on by the same group?
  23. Bob Lowry
    Bob Lowry
    Those are great hot rods. Here is an interior, before and after, of what I brought home. Have a great time with it! nova 18.JPG nova 12.JPG
    Deuces, loudbang, Roadsir and 3 others like this.
  24. Bob Lowry
    Bob Lowry
    Engine compartment, before and after, kept it simple..... nova 15.JPG nova 9.JPG
  25. DDDenny
    Bob, curious if that's an original Nova dual snorkel air cleaner?
  26. Roadsir
    Roadsir
    kidcampbell71 and loudbang like this.
  27. Roadsir
    Roadsir
    F2BD429A-07A5-4224-85B2-BB0FFEF3B21C.jpeg 27036D30-5D2B-4EC8-94C4-584ED23537B7.jpeg FB906F5C-ED25-4274-936D-23E7A5B1536E.jpeg 1A42D313-CBA2-456C-8518-1C92A84629F3.jpeg 579050CE-8FFD-431B-A601-E098B451E716.jpeg EEA2A71C-27B4-40CB-BD1F-75F476879241.jpeg 2DE5DFB2-2C49-4950-887A-2916A364A3C9.jpeg C90A3014-6E09-48AC-A4FA-A8482DA4520F.jpeg 8F92F8FD-EC24-47FC-B5C3-AB6B3FFA2BF2.jpeg 25FC2686-03F8-486D-A581-4F5D95D93D9E.jpeg DBA30F21-98D6-4FCD-81CA-75EB13F36621.jpeg 5B7E6C62-1F77-4787-A6AA-A76AD0A0053B.jpeg BAC275AD-E9D2-4B1F-A1EB-0C7129AC7086.jpeg 4A72BC19-29F5-4248-9806-7089E1287994.jpeg C571DBE9-6DBF-4EC9-870E-D8220BC30BAC.jpeg 7E0AAB8A-50BE-414A-B47E-697E80E52EA4.jpeg E927F26A-E923-4748-A4F9-629F95DFB5AC.jpeg 3C30205F-EFAC-46C1-BC1B-91BA56645DBE.jpeg The Chevy II is officially kicked off, kind of kicked into gear when I found a guy in October wanting to sell off his never installed Church Brothers front end, original powder coated subframe, and Calvert rear springs, cal tracs, sliders at super discount and delivered to boot. So I got the car stripped down and blasted, and ready to start metal work. I’ll upload a few pics.
    Bob Lowry, Deuces, BradinNC and 9 others like this.
  28. DDDenny
  29. Roadsir
    Roadsir
    Drilling spotwelds …… having fun! , fitting the sub rail connectors. Received a pallet from cl***ic industries, bumpers, trim, gl***, interior kit (aqua), all the soft parts, hardware, lighting.
    C59A7F55-DA9A-480C-8227-C1B47C5EE9BB.jpeg 0E73574C-459E-47E4-BA70-94A8FA3D248D.jpeg 63D1F251-6290-496F-BC57-208AE2280B7F.jpeg 2EB68E6B-B923-42FB-BE80-0568E768ED3D.jpeg 663A6BBE-BA7B-4138-84D0-19E22D8AE380.jpeg BB16DF7F-BD46-440D-B8C7-96DE4D63B247.jpeg 80CC2D87-2E81-456D-946F-CD04C708A203.jpeg 7E817485-0F67-4B49-8C42-77A7F7E7E003.jpeg
    Deuces, Just Gary, brEad and 3 others like this.
  30. DDDenny
    Yes!
    I see you got repro Super Sport bucket seat mounts, what are you going to use for seats!
