Customs Electric wiper kit only covers 7" path - 53 GMC Pickup
Discussion in 'The Hokey Ass Message Board' started by logic2, Sep 22, 2020.
  1. logic2
    logic2
    I have a 53 GMC 5-Window (2 piece gl***) LS Custom with Electric wipers.
    The wipers do work but they barely cover about 7-10" of the window gl*** from Left to Right (MAX). Looks like they should be covering about 15"or so...
    Is there an adjustment that fixes this issue ?
    Has anyone else experienced this problem ?
    Thanks in advance,
    Mike,
    North Texas
  2. studebaker46
    studebaker46
    whose wiper kit?
  3. logic2
    logic2
    It came with the truck. I'll crawl under and see if I can see any identifying marks.
  4. Bob Lowry
    Bob Lowry
    I have a '54 3100 with electric wiper conversion and the blades are only 11" long, so compared to the
    total gl*** area, I guess you could say it is small. Especially if you're comparing it to the new factory cars.
  5. squirrel
    take pictures....
  6. CME1
    CME1
    I have installed several , Newport Engineering , electric windshield wiper kits, on different model car's. I have almost every time had to adjust the coverage. With this brand , it is a very easy job to do.
    olscrounger likes this.
  7. logic2
    logic2
    Interesting...
    How do you adjust coverage ?
    Is there an adjustment on the Cam / Rotating Arm ?
    Thanks in advance,
    Mike
  8. Mimilan
    Mimilan
    Newport wipers use a "Marine wiper" motor.
    You can pull the cover off and change the "sweep" by moving the crank pin further out [or in] on the gear wheel.
    You can also reverse the contact plate on the wheel, so it parks either left or right.
    Hnstray likes this.
