1957 Olds 371 block/heads (org.dealer replacement motor)
Discussion in 'Parts For Sale' started by buick320a, Sep 15, 2020.
  1. buick320a
    buick320a
    from indiana
    City: Georgetown
    State: Indiana
    Price: $750
    This is ‘57 Olds block (#560928) with matching 16 heads (#571870)
    This makes this a true j2 motor Vin #A273926
    This motor is a dealer replacement motor, fully rebuilt about about 30 years ago ,but never sold. Crank turned .030, rods .020 all new bearings, block bored 40 over with new pistons/rings. New cam, timing chain, rebuilt oil pump and good pan.
    I took this engine apart so I could show you what I found, you can see the photos, this motor is dirty because of setting for over 30 years with no valley cover, but stored inside and turns free. I checked the lifter bores (brushed one and inserted a lifter)
    Heads look great, took a valve out, looks to have had a valve job maybe new valves, new springs.
    This is a rare find, a like new 30 year old motor, sorry I don’t more but have more pictures if your interested . Over $1000 in machine work and parts all factory replacement parts not imports.
    On the oil pan was written, “j2 needs intake” but I found it didn’t have shim head gasket?
    BUT ALL NUMBERS ARE CORRECT AND HEADS ARE A MATCHED PAIR.
    $750
    saltracer32@aol.com
    57JoeFoMoPar and flyin-t like this.
  2. buick320a
    buick320a
    from indiana
  3. buick320a
    buick320a
    from indiana
