Technical 1963 Oldsmobile 98 Custom Sports Coupe - Lowering
Discussion in 'Traditional Customs' started by cmarcus, Jan 24, 2020.
  1. cmarcus
    cmarcus
    Hey all,
    So I recently sold my 1952 Olds 88 and acquired a '63 Olds 98. Sweet sweet car, incredibly clean. I could not be happier. Shooting for a full repaint before the season begins.
    That being said, another part of the plan is lowering. I have looked into Jamco, and it seems hard for me to swallow nearly $700 for a 3" kit when you can get stock springs and shocks for $300.
    Does anyone know of a spring/shock out there there would get me a 3"+ static drop? Like how the Ford guys are using Aerostar springs and getting a 3" drop. Would love to know if anyone else knows of a conventional spring/shock that would work. And no, I do not want to just cut coils.
    Thank you!
    jvan and quick85 like this.
  2. Chavezk21
    Chavezk21
    Check to see what part number of impala springs are, then check interchange. If they will interchange, I ordered springs from hubbards impala that were 2 inches lower and Variable rate. they were the same price as stock replacements. I cut 1/2 coil on all 4 corners. 64.jpg
  3. ClayMart
    ClayMart
    I'm sure I've seen one these 98 coupes somewhere before, but I sure as hell can't remember when or where. There couldn't have a great number of these built in '63. I'd forgotten how much they looked like a Lincoln or full-size Mercury from a side view. Shouldn't take a whole lot to make this look like a unique, one-of-a-kind sled.
    Especially with a little bit snow on the ground. . . :rolleyes:
  4. cmarcus
    cmarcus
    Hey Clay, yes, you are correct. From what I have heard and read, only around 3200 were made? Don't quote on that, so I could be wrong. Pair that with the fact that the trans in these was a bit of a weak point, I am sure many dropped out of use and never went back. That is why I was so stoked to find one in such great shape! Below is the end goal, back the the all original white paint, and low slung.
    Surfcityrocker, quick85 and flyin-t like this.
  5. Elcohaulic
    Elcohaulic
    The 63 Big Olds has the same suspension as the big Pontiac so I would look in that direction. The Chevy is an X frame and totally different..
    There are spring catalogs that let you order the spring you want.. Most springs they sell today as factory are two or three inches higher that what the car came with..
    You could cut half a coil off the fronts and try some GM A body springs in the back..
  6. loveoftiki
    loveoftiki
    from Livonia,Mi
    Well....since your doing a re paint...why not nose it and deck it..remove the side badge..some chrome reverse wheels and that thing would be a kool mild Kustom..
    jvan, OG lil E and 57JoeFoMoPar like this.
  7. cmarcus
    cmarcus
    Personally, I like the badging and trim on the Olds'. And as far as wheels and tires, I am on a budget. I'm just trying to be a little different in that department. I feel like everyone who does a 60s car does a Bellflower kustom. Which don't get me wrong, I love!! Just for the time being, this is the plan. I just really like the sinister look of black steelies and poverty caps, and the tires are fairly new.
  8. ThisOneGoesTo11
    ThisOneGoesTo11
    from Oxford, PA
    Be careful or you'll wind up with a car that rides like a log wagon. I have a 2" drop coils on a OT sedan and I hate it. Bottoms out on country roads, doesn't handle any better, tough as hell to get an alignment in spec. Get some nice 15 inch wheels instead. My 2 inflation-ravaged cents....
  9. jimmy six
    jimmy six
    Don't remove any badging. Danchuk is making a fortune from guys putting back on nosed and decked 55-57 Chev's of the past. It never goes out of style. I removed every thing I could before going to body and paint, even the interior rear seat and all side panels to get off the side trim. I was lucky I could lower the windows on there stops and take the whiskers off and new were available.
    Good luck and replace the trans with a th350 because I bet the rear gear is pretty high for an OD .
  10. ThisOneGoesTo11
    ThisOneGoesTo11
    from Oxford, PA
    That should be a Rotohydramatic 375 ...1:1 top gear ratio, no OD...
  11. oldolds
    oldolds
    You lower a long and low car like that another 3 inches you will quickly find out how many gas stations are on raised parking lots.
  12. 57JoeFoMoPar
    57JoeFoMoPar
    I'm going to be starting an Air Lift system install on my 61 Super 88 this week. I'm pretty sure the ch***is is very similar if not identical. That will give you all the drop you want.
  13. bobss396
    bobss396
    I had a '64 88 when I was a kid... springs were all on the shot side and it was lower than your car. It s****ed everywhere, driveways, parking lots and I had to be mindful of raised sewer covers. Look up replacement springs in the Moog catalog, it will give you an idea on configuration, rates and sizing. Something 2" shorter with the same spring rate would be a start.
  14. Elcohaulic
    Elcohaulic
    I'd trade the hubcaps for chrome lug nuts on the black steel wheels..
  15. cmarcus
    cmarcus
    I actually think you are right...I have the spider caps, and think I will leave them...
    Elcohaulic likes this.
  16. khead47
    khead47
    Call Eaton Spring in Detroit.
    jvan likes this.
  17. I'm gonna cut your springs while you are sleeping Charlie
  18. cmarcus
    cmarcus
    It's already the plan, brother! :)
  19. guthriesmith
    guthriesmith
    Just found your thread Charlie and am following along now. :cool: You can't get much more traditional than cut springs...
  20. malibuj
    malibuj
    from Canada
  21. cmarcus
    cmarcus
    Bringing this one back to the top. I finally decided to go with Jamco 3" static drop.
    That being said, while my buddy has the car to put in the springs/shocks ( I just don't have the space or time to do it right now) we are doing bushings, etc. That being said, the are having a hell of a time pressing out the old ones, putting in the news ones, etc. We are starting to wonder if complete A-arms would be the right way to go. However, they do not currently offer complete A arms for a 1963 Olds 98. Can anyone confirm if there is another C-body platform who has control arms that would be interchangeable?
  22. Elcohaulic
    Elcohaulic
    I would stick with the stock suspension parts. Use new rubber bushings and put 1" lowering springs on it.. Use 1/2 tall ball joints in both upper and lower control arms. This will give you a nice camber curve since you will be switching to Positive caster and negative camber..
    The fact that the bushings are hard to get out is a good thing! I'd keep them and reuse them. It shows the arms were hardly used. I get them out in a vise with either pipe couplings or big sockets..
    I would also put the money into a nice Lee 14:1 steering box with a 20 pound valve and a set of Bilstine shocks.
    Do you want to just look at it or drive it and look at it?
  23. 57JoeFoMoPar
    57JoeFoMoPar
    Good choice going with the 3" static drop. You can't go wrong with that set up.
    I'm almost done with my air ride install in my 61, and would have been long done had I not gotten sidetracked with another Olds I bought. In looking at the pics of the install that @malibuj posted above, there are a few things I don't like about how they went about the install of the front bags especially. But we'll see if my way is better once I have my car back together and on the road.
  24. Gahrajmahal
    Gahrajmahal
    When you paint you will Be removing all the emblems and trim. I found while in primer I really liked my car without the rocker Mouldings and wheel well mouldings. I shaved the door handles and Locks and it really emphasizes how long these cars are. I would move your fender badges to the quarter panel rear. I would remove the hood letters, and if you really wanted to keep them integrate them into the grille, otherwise you can use them in the interior.
  25. cmarcus
    cmarcus
    Finally got it done! The Jamco 3" springs and shocks combined with a front end rebuild and alignment have her driving and handling just as good as she looks. Super happy with the outcome!!
  26. guthriesmith
    guthriesmith
    Looks good Charlie!
  27. cmarcus
    cmarcus
    Thank you! I do get SLIGHT rub at full lock, so maybe will go to a slightly shorter tire (you know, which will also lower it a tad more... :cool:)
  28. guthriesmith
    guthriesmith
    Lol...just don’t go to full lock...problem fixed and on a budget. :D
    On a serious note, I recently went to taller tires on my 56 which made it look lower (since more tire was up in the wheel well) but also helped my ground clearance some. Seemed like a win to me.
    Stan Back likes this.
  29. cmarcus
    cmarcus
    I guess I didn't think of it that way! Hmmmmm...
    guthriesmith likes this.
  30. Chavezk21
    Chavezk21
