Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. wheeldog57
    wheeldog57
    As we say all the way across the country from you " looks mint, wicked pissa"
    Woogeroo, tb33anda3rd, Stogy and 3 others like this.
  2. sloppy jalopies
    sloppy jalopies
  3. Rickybop
    Rickybop
    Enjoying your build, J.
    You're really moving along.
    Starting to look like a hot rod?
    Whadda ya mean? It IS a hot rod! :)
    I have to say, yours has to be one of the most unbridled and honest expressions of first-start happy I've seen. Made me smile big, too. Right there with you. Happy for you. So cool...
    Outback, Stogy, J.Ukrop and 1 other person like this.
  4. nochop
    nochop
    from norcal
    Playing this Saturday on the 4300 block of 25 st. About 1 pm
    J.Ukrop likes this.
  5. brEad
    brEad
    Just found your thread, great project! Loved the video of your first start. Looking forward to seeing this one develop.
    Stogy and J.Ukrop like this.
  6. I have a set of rears that I don't need, they are missing the park brake parts though.
    Stogy, chryslerfan55 and J.Ukrop like this.
  7. gimpyshotrods
    gimpyshotrods
    Have to start somewhere!
    Stogy, kidcampbell71 and J.Ukrop like this.
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    You’re right! It IS a hot rod! Thanks for the support—there are few things more exciting than bringing an old engine to life.
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I think I’m going to take both of you up on your generous offers!
    So just like with the bikes, I know there’s a lot of two steps forward, one step back-type situations. Although the car ran well, the water pump was leaking like a sieve. After a great deal of research, I went with one of the newer leakless pumps. Seeing that I have a four-blade fan, I opted to remove the radiator.
    Out with the old. There was a lot of play on the shaft. I think I may rebuild it just for practice and to have an extra.
  10. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Front-to-back play, that is. I’ll be installing the new pump tomorrow if all goes to plan. Also, my floor arrived and I HAD to set it in there. It needs a little customization and some staining and it’ll be ready for action.
  11. pprather
    pprather
    Floor staining. Like a fine cabinet? Or 80 years of oil and grime?
    Phil
  12. flyin flattie
    flyin flattie
    from Redmond OR
    Im diggin this little go job tune up job! I’d say living in SF and driving there in a roadster your gonna want more pistons pushing you up a hill at some point. I used to like about an hour out of SF and would drive my cars around there from time to time. Your gonna want some Power to keep up with the Prius and Tesla’s lol. Keep up the great work!!
    Rickybop, J.Ukrop and chryslerfan55 like this.
  13. flyin flattie
    flyin flattie
    from Redmond OR
  14. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    TBD at this point. I'm going to do some Craigslist searching and see what I can pick up for cheap/free. I do have a rubber floor mat that will be covering it down the line. One thing's for sure—the oil and grime will show up regardless :D
    Thanks! The plan is to drop in a flathead V8 when I get a little more established. Right now, resources are tight and space is tighter. I'm just enjoying the process.
    winduptoy, Stogy, 48fordnut and 4 others like this.
  15. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I'm in the middle of moving, but my goal is to be able to drive the car to the new place. It's only a mile away, but I didn't feel comfortable doing that with the leaky water pump. I have until the 10th of October to have not only the old spot cleared out, but also the roadster ready. As you guys know, I'm always working with deadlines.
    This afternoon I was able to get the new water pump installed. One of the studs needed a little cleanup work, which gave me a great opportunity to use my era-correct tap and die set that I got at an estate sale in SoCal a little while back. With that all straightened out, I put everything back together and fired it up for the first time in a month. After a little fiddling, it fired right up. Best of all, the new water pump seemed to be working just fine.
    And the finished product...
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Next, I started making the template for the lower seat out of cardboard. IMG_0483.jpg IMG_0484.jpg It will be 3/4-inch marine-grade plywood stained to match the floor. It will bolt on to the seat pan and serve as the base for the seat. Grade 8 hardware will be used to secure it.
    That's all for tonight. I gotta do some packing!
  17. jim snow
    jim snow
    Cool set of taps and dies. Snowman
  18. Mr48chev
    I'm going to ***ume that "stained, means sealed. It looks like you are making some serious progress even when you are on a trip across the country.
  19. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you! Yep, that’s what I meant. I will stain it and seal it, after I paint my new bedroom [emoji23]
    Outback, chryslerfan55 and Stogy like this.
  20. gimpyshotrods
    gimpyshotrods
    I should be over to storage this weekend. I will dig them out. I can swing by @Pocket Nick's place and make the full-circle.
    Outback, chryslerfan55, Stogy and 4 others like this.
  21. 13clicks
    13clicks
    you still wanting that intake and header setup I have waiting for you?
  22. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Moving has been going smoothly, but it sure has taken up a lot of my roadster time. That being said, today was a red letter day.
    Even though this is an early style build, I knew I wanted to run steelies from the start. After talking with @13clicks about what he did on his roadster to have steelies and mechanical brakes, he sold me the front adaptors he made. They should be showing up shortly.
    Then there are the wheels. My friend Brandon Flanner of East Bay Speed & Custom hooked me up with a killer set of 16-inch ‘40 Ford steelies. They’re four inch fronts, 4.5-inch rears. I had a great time hanging out at the shop, catching up and learning the finer points of hot rod rolling stock. Later this week I’ll be buying my bias ply Firestone black walls. I can’t wait to get these on the car! Note the original pinstriping!
  23. A Boner
    A Boner
    Ebony penetrating stain.
  24. Tim
    Tim
    from KCMO
    Loving this
    Runnin shine, Rickybop and J.Ukrop like this.
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Side Note: Remember when I said I finished my Triumph project so I could finally build the roadster? I'm really excited to share that the bike is featured in the new issue of DicE Magazine. This is the motorcycle equivalent of having your car in Rodder's Journal. I couldn't be more thrilled! IMG_0568.jpg
    I'm trying to apply everything I learned to my latest four-wheeled project. Build thread to that machine on the Antiqued here
  26. 1946caddy
    1946caddy
    from washington
    Grade 8 hardware to secure plywood. :confused:
  27. 48fordnut
    48fordnut
    A bit of overkill for grade 8.
    panhead_pete and J.Ukrop like this.
  28. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Hey, you guys know way better than me. I was under the impression that things like seats should be securely fastened. The seatbelts are connected to the seat frame via Grade 8, so I was just trying to follow suit. If this were your build, what would you use?
    chryslerfan55 and 48fordnut like this.
  29. 48fordnut
    48fordnut
    A collision would likely tear the wood before a bolt would break. You are right use what you think would be adequate. I would use large area washers around the bolt heads whatever grade you use.
    Moondog13, nunattax, Outback and 7 others like this.
  30. Rickybop
    Rickybop
    X2 lol
    "...era correct tap and die set..."
    "You might need more pistons."
    I love this place. :D LOL
    Go, J.
    winduptoy, Outback, Just Gary and 5 others like this.
