Projects Mild custom '51 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by PhilA, Nov 4, 2019.
  1. PhilA
    PhilA
    Tonight, I changed the oil. What came out was rather gray and thin. Put nice new fresh 30W in.
    That made a significant difference. So smooth running now!
    (What a surprise).
    Went to the store in it. Got some strange looks, apparently it's not normal to go grocery shopping in an old car.
    Phil
  2. tubman
    tubman
    I use my '51 Ford club coupe to go grocery shopping all the time. The trunk is HUGE and it's super easy to load and unload (after I get home).
    I have received many more compliments than "strange looks".
  3. PhilA
    PhilA
    Granted, the compliments so far have outweighed the strange looks, which is nice.
    My OT daily that's a bit hit or miss (muscle car) but the Chieftain definitely makes more people smile.
    Phil
    MUNDSTER, loudbang and Chief 64 like this.
  4. PhilA
    PhilA
    Today, I almost completed the list.
    Coolant changed, now 50/50 antifreeze and distilled water
    Manifold and heat riser gaskets replaced
    Fuel pump tightened
    Hard fuel lines replaced. Steel line to carburetor was cracked
    Rubber fuel lines replaced with marine grade fuel pipe
    Air filter gauze oiled and dish filled
    Throttle pump needs looking at
    Phil
    Mtn Goat, Woogeroo, Ford52PU and 4 others like this.
  5. That's a fine looking Poncho, and great job in bringing it back... :D
    Woogeroo, loudbang and PhilA like this.
  6. PhilA
    PhilA
    Just taken it for a quick run out to get pizza.
    Running really nicely now. All the pops and bangs on overrun are gone, so the manifold is sealing.
    Met with general approval.
    Phil
  7. PhilA
    PhilA
    Figured I'd share a quick drive to the milkshake stand and back.
    Couple things need addressing (bands are toast and squeak on uptake until the oil's gotten around but that's an engine-out so it can wait, exhaust needs a couple more supports to stop clunks and bangs underneath as it swings).
    Other than that, pretty happy with a nice old cruiser to go places in.
    Phil
  8. 302GMC
    302GMC
    from Idaho
    The hydro sounds like it has many more miles left in it before needing any work ...
    kidcampbell71, loudbang and PhilA like this.
  9. tubman
    tubman
    Very nice!
  10. PhilA
    PhilA
    I didn't replace the drum bands when I rebuilt the gearbox because they had plenty of depth left. However, I think they're harder than they should be; the gearbox did get very very hot.
    Afterthought: They don't grab, they don't slip, they just squeak a bit. They're on next year's to-do list.
    Phil
  11. loudbang
    Purrs along right nice. Have you tried out the hybrid radio system yet?
    PhilA likes this.
  12. PhilA
    PhilA
    Yup, it plays nicely. It's nice to be able to put period correct music over the radio while you're driving.
    Edit: I didn't put it on for the film because YouTube does audio ****ytics and will pull from service any movie found to have copyright music in the audio track.
    Phil
  13. brEad
    brEad
    What a sweet ride! You’ve done really well on this one.
    PhilA and loudbang like this.
  14. TrailerTrashToo
    TrailerTrashToo
    Sweet ride - well done. I'm impressed that you can clearly hear the click of turn signal flasher.
  15. PhilA
    PhilA
    Thank you. It's been fun so far, and there's no sign of it stopping yet. Still plenty to do!
    Yup, it's not loud, either! The only reason I didn't put a louder one in is the auto-cancel mechanism for the turn signals works properly (you can hear that CLIK CLIK over a I turn the wheel).
    With the window closed the loudest sound in the cabin is the whine of the gearbox when you're moving.
    Phil
    brEad, loudbang and TrailerTrashToo like this.
  16. TrailerTrashToo
    TrailerTrashToo
    The sound of that engine is "ear candy". The early 1950's was a 6 cylinder world for this kid. Used cars for my dad, and new Plymouths and then Dodges as my Grandpa got more prosperous. Then it came to me, my great-grandfather had a 1952 straight 8 Buick. By the late 1950's, they all had V-8 (a very different sound) - except dad, still motoring on with straight 6 motors (less parts to wear out...).
    kidcampbell71, PhilA and loudbang like this.
  17. PhilA
    PhilA
    The Buick 8 has quite a different sound to this, being OHV. Gone is that muted exhaust burble that comes from poor flow and large valve overlap inherent with a side-valve (you know how a side-valve V8 has that almost hissing burble in the exhaust compared to a modern OHV V8), but this one has all the valvegear buried so is a little less clattery from the motor itself.
    I always wanted an inline 8, but it wasn't an engine layout common to the UK, too big, too expensive, too thirsty.
    I'm glad I got this one, it's quite different to drive, though getting used to how fast it sounds like the engine is turning compared to how fast it actually is going aurally is a challenge. It sounds like it needs another gear up by 35!
    Phil
  18. bchctybob
    bchctybob
    Here’s hoping a lot of folks have paid close attention to your adventures with your brake and fuel lines. After so many years the old steel lines can be downright dangerous even though they look somewhat ok on the outside. I found this on one of my cars. The PO updated a lot of stuff but left the old lines. Most just broke at the slightest movement due to rust. I replaced all of mine too.
    Really enjoying your thread Phil.
  19. PhilA
    PhilA
    After the rest of the really high quality work found done on this car by previous keepers, I decided that it just wasn't worth not doing.
  20. PhilA
    PhilA
    Just recieved the correct crank vent tube in the mail, that's going to get a clean up tonight.
    kidcampbell71 and loudbang like this.
  21. PhilA
    PhilA
    Just came out to the garage. It's a warm day and whoooeee, just discovered that the fuel gauge sender weeps. Amazing how little fuel makes so big of a stink.
  22. PhilA
    PhilA
    Crank case ventilation tube arrived today in the mail. Dirty but otherwise in good shape.
    Stuck it in the ultrasonic bath, in gasoline to clean it both inside and outside.
    Cleaned up nicely.
    ... as did the down tube ...
    ...and the clamps.
    It's missing the lower bracket, but that's just a piece of flat bar that clamps onto the lower tube and bolts to the engine.
    Paint is drying now, that can go on tomorrow. Discovered also that there should be a standoff clamp for the exhaust downpipe, to steady it at the engine end. That's missing, too.
    I'm wondering if the garage that did the work just threw it all away...
    Phil
    Woogeroo and loudbang like this.
  23. Copper Top
    Copper Top
    I like your car, I liked the ride, but was disappointed you didn't take us in for a milkshake.
  24. PhilA
    PhilA
    Sadly only the window is open. It's a nice little diner inside.
    Phil
    Copper Top and loudbang like this.
  25. Johnboy34
    Johnboy34
    from Seattle,Wa
    It was a great ride! Cool old ponch!
    We all know how miss Daisy felt now!
    [emoji6][emoji1787][emoji23][emoji41]
    Sent from my SM-G973U using The H.A.M.B. mobile app
  26. PhilA
    PhilA
    On the Driving Miss Daisy front, are there any direct axle swaps? Round here is flat as a pancake and acceleration isn't an issue, but bringing the cruise RPM down a bit would be preferable- it's got oodles of low end torque but I feel a bit uncomfortable pushing it at high RPM for extended periods.
    Phil
  27. 48fordnut
    48fordnut
    39-56 olds and pontiac rear center sections are interchangeable. You should be able to find a 3.00 center section pretty easy. What rpm are you at ?
    If you are talking complete r/e I have no idea.
  28. 302GMC
    302GMC
    from Idaho
    Phil,
    If this will help, '49 - '54 axle codes are stamped on the housing as follows :
    3.08 - ''0''
    3.23 - ''9''
    3.42 - ''8''
    3,64 - ''6''
    3.90 - ''4''
    4.10 - ''3'
    4.30 - ''2''
  29. PhilA
    PhilA
    Whereabouts? I need to clean mine up, the axle looks like it was dug up out of a garden somewhere the amount of mud and junk stuck to it
  30. PhilA
    PhilA
    Either gears or entire ***embly.
    I need to reconnect my tach and check see accurate speed at 1000 rpm.
    I'll do that tonight if I have time.
    loudbang and 48fordnut like this.
