Hot Rods having a crack at a 36 coupe...build thread
Discussion in 'The Hokey Ass Message Board' started by wandi harry, Jan 15, 2015.
  1. wandi harry
    wandi harry
    I thought it was about time to try and contribute a bit to the hamb so here it goes.
    I am sure it will not be anything that has not been done before but it is a learning curve for me.
    I brought my coupe as a partially done project a couple of years ago. Progress is slow and will continue to be so as my shed time is limited. I will post bits and pieces that I believe may be of interest and try not to go over what has been over a hundred times before.
    The coupe has been through a few hands and without going into it to much some of the chassis work in particular is fucked up. But by the time l am finished l am aiming for it to be a safe and reliable ride.
  2. AVater
    AVater
    1. Connecticut HAMB'ers
    Just curious here--will you be keeping the transverse spring with the 9" axle?
  3. Jalopy Joker
    Jalopy Joker
    Cool project - most of us can appreciate slow progress, as long as there is progress.
  4. wandi harry
    wandi harry
    yep, thats the plan traverse spring ( 8 inch diff)
  5. wandi harry
    wandi harry
    So finally have a little progress to show
    I like the idea of a removable trans tunnel , here is my version
    Six pieces bent around logs and tweaked with a big hammer then zapped together
    Turned out ok , still need to clean it up a bit
    kidcampbell71 and Stogy like this.
  6. wandi harry
    wandi harry
    Also picked up a 39 pedal assy
    Brought unseen and it turned out to be flogged within an inch of its life
    Shaft worn through the bushes and into the cast assy
    Of course the shaft itself is useless but l recently purchased a Micky mouse mill and a lathe so l can deal with that.
    This will be my first project with them
    I needed to bore out the pedal to get it round again so the bush will fit well.
    Cleaned up the edges while l was at it
    Stogy likes this.
  7. Nice project.
    What's with the Studebaker?
    Stovebolt likes this.
  8. mrquickwhip
    mrquickwhip
  9. wandi harry
    wandi harry
    I am baby sitting the studie for a mate while his shed gets built.
    lothiandon1940 likes this.
  10. Model T1
    Model T1
    Keep at it! Love those 36 coupes.
  11. wandi harry
    wandi harry
    Finally posting back on the hamb with a bit of an update
    Was happy with how the 39 pedal assembly came up but have decided to go back to running the original assy which l have modified to work well with the clutch brake set up l have
    Stogy and kidcampbell71 like this.
  12. wandi harry
    wandi harry
    To use the 36 pedal assy I needed to spin the brake shaft so that it pushed through the brake pedal first
    and then through the pedal bracket assy . To make sure the shaft stayed where it was meant to
    I tapped one end of the shaft and put in a stud (pinned it as well) and will use a castellated nut and
    split pin to make sure it all stays together.
    Stogy and reagen like this.
  13. wandi harry
    wandi harry
    For the clutch side of things I needed to get the actuating motion pushing rearward rather than the original
    forward motion as l was going with hydraulic set up.
    To do this l cut of the original lever set up of the end of the clutch shaft.
    I then raided the scrap heap and grabbed an old ride on mower spindle which I was hoarding for reasons unknown
    and machined down the large splined blade retaining washer and the splined spindle shaft itself.
    013de43596ffa49ca7d41cc596a10e15dc77ebcad6.jpg 01318b890df7770cb9e22abdb249bbca72dd271160.jpg
  14. wandi harry
    wandi harry
    I made a pretty basic lever ( mock it up to make sure you have the right sort of ratio to actuate the slave cylinder properly) and welded this to the turned down splined washer.
    I fitted the old splined spindle shaft to the clutch shaft. (tapped and threaded)
    She was right to go
    The beauty of this is it gives plenty of scope for clutch adjustment and getting the clutch and brake pedal
    at equal heights 0192127f2ea6e61121edbea496a9ce14f02ea6189d.jpg 018fb9196486d307a9a9090e928de046ea35e314ff.jpg 010c3f5683c9b4b3e95cc4610b3874901643fc41c7.jpg
    reagen, kidcampbell71 and Stogy like this.
  15. Nice lathe work; creative too!
    Stogy likes this.
  16. wandi harry
    wandi harry
    Well looks like l have been pretty slack in updating my build thread.
    Progress is happening but slow.
    I had a go at spraying the firewall myself, it turned out ok but the reality of being a complete novice painter and the stuff ups I managed to create just on the firewall made me realise the car deserves a better paint job than what I can manage.
    So its in the hands of a good local fella getting some paint on.
    I welded some wire on the doors to close the gaps jumping about to minimise heat issues,
    IMG_5317.JPG IMG_5331.JPG IMG_5329.JPG IMG_5320.JPG H]
    TagMan, reagen, Stogy and 5 others like this.
  17. Looking grand mate. Very well done. Enjoy
    Cheers
    Tony
    Stogy, lothiandon1940 and wandi harry like this.
  18. tub1
    tub1
    from tasmania
    Looking good harry
  19. choptop40
    choptop40
    looks great..love them 36 fords
  20. wandi harry
    wandi harry
    Long time between posts but getting closer
    Screwed up the wheel backspace, looks great but will not work
    Car is back from the painter, really nice job.
    Starting wiring and and panel assembly
    36 ROKIT, mvee33, reagen and 3 others like this.
  21. wandi harry
    wandi harry
    I have found most of my time with the wiring is actually trying to work out which wires in what loom and the best way to run them
  22. Looks great. Love the color...........Don.
    wandi harry, kidcampbell71 and Stogy like this.
  23. brady1929
    brady1929
    Looking good.
    Stogy and wandi harry like this.
  24. tub1
    tub1
    from tasmania
    Harry I'm loving the colour you have nailed it , I've been looking at that colour on some late model shit heap from China thinking mmm I think I need another old ford so I can paint it that colour
  25. 1940 coupe
    1940 coupe
    from nj
    cool looks great
  26. Colorbond colours are a good source.
    Stogy likes this.
  27. wandi harry
    wandi harry
    The colour is a recent ford colour
    Stogy, 35cab, reagen and 1 other person like this.
  28. wandi harry
    wandi harry
    starting to reassemble door glass and window felts.
    Just a tip , the little screws that come with the kit need to be thrown to the shit house.
    Grab some Phillip’s head screws with a bit more length, much more user friendly
    Stogy likes this.
  29. wandi harry
    wandi harry
    So I had her moving under her own power until l bent a clutch linkage which l had manufactured.
    All part of ironing out the bugs before l have to get it inspected for registration 4671E710-5FF3-4AA0-AECB-53FC2F5A5F33.jpeg
    harpo1313, Stogy, nor6304 and 4 others like this.
  30. ^^^^^^^^^ Great pic, love the shed. ^^^^^^^^^^
    Stogy, KiWinUS and wandi harry like this.
