Technical Tinting engine turned dash panel
Discussion in 'The Hokey Ass Message Board' started by morepower, Sep 28, 2020.
  1. morepower
    morepower
    from northeast
    Hey gang. I would like to create a translucent aged effect on a new engine-turned dash panel. I have considered tinting clear lacquer or shellac, or some type of paint mix. Then there's the matter of aging. The new panel is plain aluminum with 1/2" swirls. Any suggestions most appreciated. Thanks!
    Dave Mc likes this.
  2. dana barlow
    dana barlow
    from Miami Fla.
    There is some spray can tint for alum rims,but don't remember who made it !
  3. Bob Lowry
    Bob Lowry
    Check out the web...type in "aging aluminum"...you can use Oxi-Clean for patina effect.
    Also lists bronze, gold, black, etc.
  4. morepower
    morepower
    from northeast
    Any of you able to see the photos I posted?
  5. morepower
    morepower
    from northeast
  6. Nope... Getting the red "X"
  7. No photos
    anything that oxidizes aluminum would work.
    What about rubbing paint or soy sauce to give it a tinted rubbed worn aged ’d look ?
  8. lothiandon1940
    lothiandon1940
    ......Yummm, Soy Sauce.:D
    VANDENPLAS likes this.
  9. Bandit Billy
    Bandit Billy
    Bug juice definitely gives a tie a nice aged look and it is permanent I have discovered.
    VANDENPLAS and lothiandon1940 like this.
  10. I'm sprinkling a few br*** pieces on my '50 truck dashboard to contrast with the chrome. In a couple of instances, I rattlecan sprayed candy yellow with rootbeer brown in the low relief for a touch of age/patina. It turns out glossy but I could hit it with flat-clear easy enough if I wanted. The trim around my gauges is one example. They were chrome and I wanted the br*** appearance.
    I bought 3.5 oz cans of 'Spaz Stix' brand. They have a variety of colors. But if you have access to an airbrush, that's even better. you can do vignettes on the edges and/or corners and soften/age that more so with steel wool. Pockmarks are also easy to fake with a drop or two of paint on a toothbrush and running a popcycle stick or fingernail backward on the bristles. When the bristles snap forward again, they flick micro-drops of pigment on the subject piece randomly a few at a time.
    Edit; I don't think I was as clear as I intended. In a nutshell, You can apply a haze or fade and then lightly work it with steel wool to get the effect you want. "Less is more" so transparent colors are softer with a lighter touch than opaque.
    Dave Mc, morepower and VANDENPLAS like this.
  11. morepower
    morepower
    from northeast
    IMAGES NOW POSTED!
    Dave Mc likes this.
  12. morepower
    morepower
    from northeast
    Please check out photos now on main post.
  13. BJR
    BJR
    Hit it with some candy paint, lots of colors, dark to light, depending on how many coats you put on.
  14. morepower
    morepower
    from northeast
    Thanks for sharing this... very helpful!
    The Shift Wizard likes this.
  15. Petejoe
    Petejoe
    from Zoar, Ohio
    Gun blueing.
    It’s an
    Oxidizer.
    Try on a s**** piece and before you get the desired effect.
  16. treb11
    treb11
