Hot Rods Magnesium Wheels
Discussion in 'The Hokey Ass Message Board' started by stanlow69, Sep 28, 2020.
  1. stanlow69
    stanlow69
    Lets discus Magnesium wheels. Pic`s and info wanted. I`ll post a question most won`t know later.
  2. kadillackid
    kadillackid
    All I know is that they are light in weight but heavy on the wallet :D
  3. stanlow69
    stanlow69
    I know you can pick them up with your finger, but how about your pinky finger.
    31hotrodguy likes this.
  4. DDDenny
    They make purdy flames, ask me how I know.
    31hotrodguy and VANDENPLAS like this.
  5. stanlow69
    stanlow69
    That`s the question I was after. How flammable are they. Or how explosive. I was at the drags this past weekend. The subject of A guy with a stack of them piled to the ceiling in his ba*****t, told the fire department to clear a 4 block area around his house in all directions if he were to have a fire. A true fact. The guy died a couple years ago for other reasons. .
  6. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    When magnesium is in its metal form, it burns very easily in air. When the magnesium burns, it reacts with the oxygen to form magnesium oxide. ... When magnesium interacts with water, it will form a hydrogen gas that ignites violently due to the excessive heat and oxygen supply.
    Don't ever look directly at a white magnesium flame.
    It can damage your eyes/ retinas up to and including blinding you.
  7. gimpyshotrods
    gimpyshotrods
    Magnesium, when purchased from someone who insists firmly that is aluminum, when re-sold, can fund 1/3rd of building another car.
  8. Mike VV
    Mike VV
    from SoCal
    You didn't learn that in 8th grade science cl***..!
    Yes, shaved, or magnesium filings will light quickly and burn hard, with little to extinguish the flame.
    A solid piece of magnesium, like a wheel will take much longer to light, but again, will not stop until all of the metal is ash.
    I've also got several sets of Halibrand and American magnesium wheels in both of my garages. One connected to my house, one out back. One set of American 12 spokes in my bed room.
    Thinking about selling some...before I die, and someone throws them in the trash after I'm gone..!
    Mike
  9. X38
    X38
    Yet, it can be welded.
  10. pirate
    pirate
    from Alabama
    Magnesium is approximately 33% lighter then aluminum and approximately 75% lighter then steel. Magnesium is not as hard or strong as aluminum typically having less tensile strength, yield and elongation. Magnesium corrodes very easily forming a gray film. To prevent corrosion Magnesium is often treated with a chemical conversion process such as Dow 7 or Alodine which imparts a dull gold color.
  11. Corn Fed
    Corn Fed
    Don't ever buy a magnesium wheel, because if you do, you will only want more. They are the meth of wheels. Before you know it, you'll be spending your kid's college money just to squirrel more of them away in places your wife will never find. And in your mind you'll justify that it's fine and normal to spend 1000's of dollars on some crusty old wheels that don't even shine.
  12. pirate
    pirate
    from Alabama
    Well I really don’t see the attraction of true magnesium alloy wheels especially for a street car other then something possibly to brag about. They tend to be twice or more the cost of aluminum wheels, are hard to maintain, more susceptible to damage from potholes and other road hazards then aluminum wheels. For street use and straight line acceleration they don’t offer any performance advantages. Now for a race car my answer would change if for no other reason then weight savings. This is especially true for race cars that are used on road courses. The lighter weight then allows for less unsprung weight which allows the suspension to work more efficiently. Just my opinion your mileage may vary.
    stillrunners and dana barlow like this.
  13. When my sibs and I were kids my dad was a mold maker in an investment casting shop. We could get mag shavings anytime we had a hankering for a pyrotechnic show. It was fairly safe to burn on the gravel parking patch away from the house and anything else. You can light shavings with a match and it takes a few seconds to spread to the whole pile while you step back 7 or 8 feet. It can sputter a bit..... especially if you squirt it with a water pistol. :p
    The light weight of mag wheels has a double benefit. It doesn't sap as much horsepower to spin 'em up, and the shocks have greater control not having to fight as big of a "bouncing ball" so the proximity of rubber to pavement is improved. There's also a third benefit of less effort and a potentially quicker tire change, if that's important to you.
  14. Lou kriger
    Lou kriger
    What was the cubic inch of the 6 cylinder GMC engine that we hopped up in the Fifties. 261 or 292?
  15. 57 Fargo
    57 Fargo
    I’ll argue that there is no advantage in a straight line, less weight makes everything faster and less weight to get spinning
  16. Lou kriger
    Lou kriger
    Sorry in wrong forum. Where should I post this question? Moderator please?
  17. Yes, wrong place to ask but 270 or 302
    31hotrodguy and wraymen like this.
  18. Lou kriger
    Lou kriger
    Thank you @Tman.
    harpo1313 and 31hotrodguy like this.
  19. chrysler engineers found out 15 lbs of rotating weight was worth a tenth a of a second. thats very easy to get when compared to aluminum wheels. when polished mag will out shine aluminum any day. some of the coolest wheels were cast in mag only. i have polished mag wheels on my car and i drive it all the time both street and strip. i have never had any damage to them street driving. i use flitz polish on them for a great shine. they offer a sealant to help protect them from corrosion. it works great. when ordering online enter code 3169 at check out to receive a 20 percent discount.
  20. noboD
    noboD
    I had that same experience.
    -Brent- likes this.
  21. Mike VV
    Mike VV
    from SoCal
    Aaamen...
    Mike
  22. GeeRam
    GeeRam
    Which is why they are even more effective on a street car......
    I had a set of magnesium Minilite wheels on one of my cars many years ago, and they made a noticeable difference in street driving due to the reduced unsprung weight.
    I'd love a set of vintage mags for my 32......
    bowie likes this.
  23. loveoftiki
    loveoftiki
    from Livonia,Mi
    E1DCECC0-53B5-402A-880E-7FE4952DA681.jpeg A8FFC54F-1184-4152-9752-9E7F526767BD.jpeg 0710C9D0-3CA5-4963-B858-4E8BC9A53B41.jpeg Saw these last weekend for sale at the Strip...being cool costs....how cool ya wanna be...
  24. 31hotrodguy
    31hotrodguy
    Almost bought these last week for a small fortune but still a good deal. Then I read the fine print. Both the same size but different off set. Adjustments.JPG
    I guess I’ll keep searching! [emoji41]
    -Brent- likes this.
  25. guthriesmith
    guthriesmith
    All I know is that I wish I would have kept the magnesium set of 15x4 5-spokes with a 5 on 5-1/2” pattern I bought about 30 years ago with wide whites for $50 instead of selling them for $100 thinking I made a killing...
  26. Roothawg
    Roothawg
  27. stanlow69
    stanlow69
    Locally a guy had a set. He would pull them out and told you to hold them up with a finger and said they were rare. Winter was coming so he need some money for propane for winter heat. So he listed a matching set of 4 on E bay with a minimum of $2200. So a guy calls him up and asks if he`ll take $15,000. No, but he says he`ll take $18,000. The guy says O K and off to California they went. The numbers are actually a bit higher but can`t recall the exact amount.
  28. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Sure you got your zeros correct ?
    BIG difference between 2,200 hundred dollars and 15 - 18 THOUSAND DOLLARS
  29. stanlow69
    stanlow69
    That`s the story I heard. The reserve wasn`t met yet. And the other guy made the first offer.
  30. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
