Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. 6sally6
    6sally6
    will follow along!
    (I thought you were older!!!!):eek::eek:
    6sally6
    Your reaction upon start-up sez it all! Definately causes a stirring of the man partz, huh?!!
    Outback, chryslerfan55 and J.Ukrop like this.
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Some days I feel older than others haha. It makes me so happy every time I fire it up now!
    Outback and chryslerfan55 like this.
  3. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Yesterday, I was able to secure my 3/4-inch marine grade plywood for the seat base. The people at the lumber yard were very confused and in no way happy to help me. I talked to four different employees before one was able to point me in the right direction. After my positive experience at the steel yard, I was hoping this would be similar. I was wrong. Oh well, I got what I was looking for.
    (The white wood is for my new bedroom shelves I’m building)
    Also, my wheel adaptors from @13clicks showed up. Can’t wait to try them out! [​IMG]
    Dannerr, AHotRod, Woogeroo and 7 others like this.
  4. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Loving the thread and that you are keeping it a cl***ic hot rod. Have you considered keeping the engine stock and just hopping it up? You can get all new speed equipment to make the the same power of a flathead but without all of the frame mods. Don't get me wrong, there is nothing like a flathead, just thinking about $ and space right now.
    Mike
    missysdad1, Stogy and 48fordnut like this.
  5. 48fordnut
    48fordnut
    J, it seems lumberyard people are less tolerant than steel folks. I think you have to be a spe******t at some places.
    Keep going with what you are doing, don't listen to old farts opinions like mine. You are doing well. Bes t wishes.
    Stogy, chryslerfan55 and J.Ukrop like this.
  6. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks Mike. That's the plan as of now. This is going to be a multi-stage project. I'm just in the pre-war hop up phase.
    Stogy likes this.
  7. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Last night I was able to get out in the garage and work on the car. My main project was the seat base, which I'll have more pictures of once it's a little further along. I also managed to spruce up the dash and install the driver's side door. It fits well but is a tight squeeze. I have a feeling once the body is 100% bolted down it should fit better. IMG_0605.jpg
    Looks like somebody shaved the door handles back in the day and brazed the holes shut. Kustom.
    Dannerr, AHotRod, winduptoy and 8 others like this.
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Unfortunately, after some research, I realized that running the steelies with the mechanical brakes probably isn't the best idea seeing how short the rear axle studs are. My revised plan is to save the steelies for when I go A-V8. No harm, no foul. That being said, I'm now on the lookout for '35 Ford wires. I found two locally with original paint that I am going to check out tonight.
    Question for the experts out there: when looking at a '35 Ford wire wheel, is there any trick to tell how straight it is? The seller says they're good, but I'm going to carefully inspect each spoke and lay the wheels on a flat surface to make sure they're usable. Any other suggestions would be much appreciated.
    winduptoy, Just Gary, Stogy and 2 others like this.
  9. Tim
    Tim
    from KCMO
    Put it on a spindle/ hub and a spin it. Watch for run out
    Carter, Woogeroo, Stogy and 2 others like this.
  10. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I planned to do that after I got it home. I'll see if the seller has a dis***embled car and we can potentially test it there.
    Stogy and Tim like this.
  11. catdad49
    catdad49
    This is what the ebony penentrating stain/sealer will look like. I did this to my 66 C10 when I redid the wood the second time. Yes, it was my daily for about 13 yrs. before I got a newer truck. bed 1.JPG
  12. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Update: I got a pair of nice '35 Ford wires locally. It appears as if they are straight without any broken spokes. I purchased them from H.A.M.B.er @Steven Ginsburg, who has a trio of amazing '34 Fords—a chopped five-window, a roadster and a Woody in the works. Now I just need to find two more wheels...and hubcaps...and trim rings. One piece at a time!
    @catdad49, that truck bed looks really nice! That must have been a fun daily!
  13. Sculptive Design Co.
    UGH! Joey, I am so pumped to follow along your build! I feel we have the same outlook toward building hotrods, that is joy. I feel that my build will be in "phases" as yours. Jalopy-isk, A-V8, then full blown hot rod. Keep up the great work. Thanks for taking the time to post your progress.
    chryslerfan55, Stogy and J.Ukrop like this.
  14. Hitchhiker
    Hitchhiker
    I've got wheels up here in Seattle if you need them. I can check runout before I send them.
  15. 282doorUK
    282doorUK
    I'm enjoying this a lot!
    As to the ply floor, maybe take off the sharp edges and corners, then fit it and let it get grubby and scuffed up a bit during the build. A few heel s****es under the stain and seal will add age.
    48fordnut and J.Ukrop like this.
  16. wheeldog57
    wheeldog57
    Joey, you mentioned the door being a tight fit.
    You are right about the body being 100% bolted down, these roadsters require shims sometimes.
    Under the cowl and under the B post area behind the door. Starting at the cowl working front to back you will be surprised how much adjustment you have by shimming. Good luck
  17. OldSchoolRodz
    OldSchoolRodz
    from Nor Cal
    I couldn’t turn anything up in a google search of Petaluma CA for;
    Difalco Fabrication
    Defalco fabrication
    Could you verify the name of the shop, or post a link to their website?
    Thx, D
  18. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Keep going young fella.
    J.Ukrop likes this.
  19. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Here is David's website: https://difalcofabrications.bigcartel.com/
    Ben Cross and chryslerfan55 like this.
  20. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I'm sitting here eating my lunch and figured it would be a good time for an update. It was a productive weekend where I directed my attention to some of the louder tasks that are best handled at my old garage. The car will be moved to the new space early next week.
    First and foremost, I focused on the seat base which was actually cut out of a ragged piece of driftwood found at Ocean Beach just south of the Cliff House. IMG_0644.jpg
    Large area washers are used on top and bottom.
    Keeping the seat frame in position with a little help from the front tire.
    As I was working with the garage door open on a foggy San Francisco night, two cyclists rolled up. It was Mark, one of my new roommates, and his girfriend Darragh. They were celebrating an anniversary but wanted to stop by to see the roadster. It was fun to show them what I was working on, have some beers and test out the new seat base.
    The following morning, I tried out the new old floor mat that will still need to be cut to shape. IMG_0653.jpg
  21. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Then I turned my attention to the staining and sealing of all the wood items. I took the Triumph to the hardware store to get my materials.
    The spar urethane is currently drying, but I really like how it's looking. Also, all the hardware has been painted black so it won't stand out too much. The channel around the seat base is now black too, but I'll show that in future photos.
    Sunday I was able to finally remove the running board mounts. They were welded on by a previous owner. I'll completely remove the tops of them—rivets and all—when I have the frame apart for the A-V8 conversion. I have to be pretty careful about doing too much cutting and grinding due to noise reasons. With those gone, it really feels like a highboy now!
    Dannerr, GASSERBOB, AHotRod and 15 others like this.
  22. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Last night, I took an evening drive to Morgan Hill, California, which is about an hour and a half south of SF. Over the weekend, I had seen a Craigslist ad for a roller that had a pair of '35 Ford wire wheels on the front. The ad made one thing clear: he was not going to part the car out, and the extra parts will not be sold individually. Nonetheless, I called and asked him if he had any more early Ford wires elsewhere on his property. Lo and behold, he did.
    It was dark when I arrived at Rick's place in Morgan Hill. He showed me his collection of rare Volkswagens, Volvos and the MG he plans to have as a prop at his daughter's wedding. I learned that he's from New York, and he still has the Model A coupe that he bought while he was in high school. Unfortunately, he gave the body to his son who chopped it and lost interest. With a flashlight in hand, we looked through his stack of wheels and I picked out three of them. They'll need to be sandblasted, but they look pretty good to me. I'll test them for runout before sandblasting them. IMG_0684.jpg
    I brought the yellow one with me to make sure I was getting the right thing!
    Rick had a ton of good parts, and I was able to pick up a headlight switch while I was there. It's a small piece of the puzzle, but I love filling in the blanks. IMG_0688.jpg
    Next up, installing the rear brake rod, seat and floor. Then it'll be making its maiden voyage to the new garage!
    AHotRod, Woogeroo, GordonC and 12 others like this.
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    It was a beautiful fall night in Morgan Hill, with temperatures in the low 70s and the main drag all lit up. I grabbed dinner at Trail Dust BBQ, took it to-go and enjoyed it at a park in the middle of town. It was delicious and the staff was extremely nice. What could be better? I snapped this shot of the nearby Granada Theatre, which was built in 1952 and now serves as a banquet hall.
    JalopyJimbo, GordonC, rpm56 and 2 others like this.
  24. Elcohaulic
    Elcohaulic
    Hows everything down in good old Daly City.. I lived there back in 1976..
    J.Ukrop likes this.
  25. sloppy jalopies
    sloppy jalopies
    flip those running board brackets upside down, bolt them to the garage wall...
    buddy does and they make great shelf supports...
  26. Piewagn
    Piewagn
    There is a service bulletin for the play on those pumps. It involves drilling and tapping the end of the shaft and inserting a screw at the end so it will ride against the surface inside the block. My father showed me that bulletin before he p***ed and I couldn't find the binder a**** his things. Pretty neat though!
    loudbang, J.Ukrop and chryslerfan55 like this.
  27. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    "Three across? Why not!"
    Cripes a 3 way in a Model A ......Get a room :D
    barrnone50 and brEad like this.
  28. patsurf
    patsurf
    or even a coupe.....
  29. wuga
    wuga
    Look at Juliano's seat belt anchors. Even if you don't use them, they certaily expain the washer theory.
    Warren
    48fordnut, J.Ukrop and loudbang like this.
  30. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    It's just fine down there. It's home to the closest accessible In-N-Out, so I definitely make the trip south from time to time. Gotta love the unique architecture of Daly City!
    gimpyshotrods and Elcohaulic like this.
