Hello. New to the Hamb. Located in upstate NY and have a batch of 60's chevy and gmc trucks. Also have newer ones that are not applicable to your discussions. I just picked up two panel trucks. One is a 1948 GMC 100 hot rod and the other is a 1955 Chevy 3100. Could use help identifying the Ford rear with disc brakes in the GMC and need some parts for housing. The previous owner ran the rear with a bad axle bearing until it ruined the bracket that bolts to tube and holds bearing ***embly. This same bracket incorperates the caliper mounting for disc brakes. I believe this is factory rear disc brakes and may be from a Granada. Have posted pictures of rear end and damaged parts. Any help identifying these is appreciated. Will also need a replacement for ruined bearing bracket shown. Thanks for the help. View attachment 4836008 View attachment 4836009 View attachment 4836010 View attachment 4836011 View attachment 4836013 View attachment 4836014
