Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. junkyardgenius
    junkyardgenius
    from Kernow
    Me? I set fire to my coupe.
    rod1 and Lil32 like this.
  2. Crocodile
    Crocodile
    Drug home some parts cars and parts. Went to a large auction yesterday hoping to score a rough 51 Merc. Lost on that, but got some good stuff cheap... 46 parts car.jpg 56 parts bucket.jpg
  3. RICH B
    RICH B
    Put some paint on the inner fenders, radiator mounts, and front yoke for my '47 today. Even managed to move 'em from the backyard where I sprayed them into the garage to dry without messing anything up.
  4. Bigbassape
    Bigbassape
    Spent the day on my recently acquired 63 olds. Finished rebuilding and reinstalling the wheel cylinders, replaced all the OG brake lines, and mounted my new booster and master cylinder. Now if my brake hoses will arrive I can have brakes! 20201004_165615.jpeg
    Sent from my SM-G988U using The H.A.M.B. mobile app
  5. Almostdone
    Almostdone
    Finally got the hot rod driving after a 2-year build. Giddyup.
  6. gimpyshotrods
    gimpyshotrods
    Today I bought another sheet metal shear, and yet another welding table. The new table will become the general workbench, so my welding table can go back to its stated job duties.
    I also looked at another vertical mill, which I may buy tomorrow, pending the availability of transportation.
    High test 63, rod1, Lil32 and 2 others like this.
  7. blowby
    blowby
    from Nicasio Ca
    Sunday drive
    dsiddons, rod1, mctim64 and 9 others like this.
  8. Blues4U
    Blues4U
    from So Cal
    Did an ignition system tune up on the A pickup on Saturday, plugs, cap, rotor and new cables. I was surprised it was running as well as it was, when I went to pull the cap it was just sitting on top of the distributor, not secured down! I guess I loosened it to move it out of the way when painting the firewall back in the Spring time, and I never locked it back down again. Wow. Not only that, but 3 of the terminals inside the cap were badly corroded. I'm not sure why just 3 out of 8 would be corroded like that, but maybe the cables weren't pushed in far enough into the terminal causing an arc to form which lead to corrosion? I don't know, but with the combination it should've been running much worse than it was, or not at all. I only changed it all as I was trying to dial in the carb's a week or so ago and was still having some idling issues, so I wanted to eliminate any possibility of an ignition problem before tweaking the carbs any more. Well it's running good now! ;)
  9. doyoulikesleds
    doyoulikesleds
    There must be more to this one!
    Lil32 likes this.
  10. Yesterday had the pleasure of giving Neighbor Scott Fisk (Studio 669) and his younguns, plus good bud Charlie (One Armed Bandit) and Anna Decker with their’s, a good Hay Ride Blast in the BNGR. ALMOST too much fun! We’re past leaf peak, but still hangin in. 427808FC-1D0A-404B-842A-386B227EA5B8.jpeg
  11. WTF really
    WTF really
    Well I started cleaning up the firewall. While doing that I kept looking at the dash. It was driving me crazy because it really needs to be painted. So next thing I know I'm cutting the windshield out. 20201005_164855.jpg 20201005_164910.jpg
    ct1932ford, LAROKE and Lil32 like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Deep into getting the other half of garage **** moved into new barn style shed so the other 56 Chevy (red 210 Delray) doesn't have to live outside under a car cover anymore (pain putting on, taking off, repeat!). All this prep so shed could be built, fetching more rack uprights and beams has put V8 swap on the back burner for the Delray. 283 is all done looking pretty on the engine stand with all it's brackets and pulley's, plug wires, exhaust manifolds in check. All good just the same. The 235 is still pushing the old girl around just fine so the 283 swap actually isn't a total must just yet.
    WTF really and lumpy 63 like this.
  13. Mike Miller
    Mike Miller
    Started installing the front clip, not pretty but I can make it work. Saving the left side doors for last.
    ct1932ford, j hansen, Lil32 and 2 others like this.
  14. 2bubbas
    2bubbas
    ct1932ford, j hansen and Lil32 like this.
  15. TA DAD
    TA DAD
    from NC
    Working on my brake lines and I ran out of tubing so it is break time ! studebaker build 004.JPG STUDEBAKER BUILD 001.JPG
    Lil32, j hansen and LAROKE like this.
  16. Drove the Mercury up to Fresburg to visit a friend and check out his old jalopy. :)
    120659659_10224528260181018_908430880978723614_o.jpg 120779946_10224528261941062_6771924393648542987_o.jpg
  17. Mike Miller
    Mike Miller
    Love that Merc. ^^
    RICH B, Lil32 and mctim64 like this.
  18. WTF really
    WTF really
  19. RICH B
    RICH B
    Installed the inner sheet metal, reconditioned the radiator with a coat of BBQ paint and mounted it. Screwed the cowl lace down and as usual Vintique shorted the screws. Started to mount the trunk latch; I had originally mounted it in the lid and it seemed to take forever (along with a bunch of cell phone videos of what was going on in the inside) to get it positioned so the cut out and boxed area I had welded into the lid fit.
    IMAG1529 (Medium).jpg IMAG1530 (Medium).jpg IMG_20201008_154912 (Medium) (2).jpg
  20. 65pacecar
    65pacecar
    from KY, AZ
    treb11, pitalplace, Budget36 and 12 others like this.
  21. jimmy six
    jimmy six
    Time was up for an oil change on our 56 Y. Been converted to spin on filter 7 years ago. Typical 30 minute job after jack up with stands. Never had trouble but the car has PS with all the hoses. I always punch a hole on the filter an let it drain before I start on the pan. 1 hour later, 3 different filter wrench’s, and a 6” pair of Channel locks it was off. Never had this before. Anyway Lucas HR oil and a new Wix is on, no leaks for now after a 30 minute drive. 37D1074D-55BD-46E9-B087-8DA2AB8D5E52.jpeg
    ct1932ford and Lil32 like this.
  22. lowrd
    lowrd
    Post 914, 2bubbas, nice work on the inner fender/firewall brace. Really makes a difference how things handle huh.
  23. Chappy444
    Chappy444
    Did some ***embly and some mock up.
    Got some parts back from CharlieNY. (Highly recommend him for carb and distributor work)
  24. junkyardjeff
    junkyardjeff
    Got the o/d cable on the Merc but still no o/d so it looks like I will check the electrical side,there is a 1977 license in the car so I think its been sitting that long.
  25. Lil32
    Lil32
  26. Zax
    Zax
    Went to the NorthEast Ga Swap Meet this morning. Came back empty handed. Most sellers were packing it up due to rain. But it was nice to get out and talk to other car folks.
    This afternoon got my oil changed and fuel filters replaced on my '40. Then got my CharlieNY freshly rebuilt Holley 94 carb mounted up. The old flathead is purring like a kitten. On track to drive it to Moonshine Fest later this month.
  27. TA DAD
    TA DAD
    from NC
    STUDEBAKER BUILD 003.JPG Drilled the holes to mount my gauges, and pulled a few wires to get a idea on my wiring.
    ct1932ford, LAROKE, Lil32 and 2 others like this.
  28. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    IMG_3348.JPG IMG_3364.JPG IMG_3365.JPG IMG_3375.JPG CrossMembers Saint Louis Hot Rod Hundred Reliability Run, Saturday 10/10/20. Rollin down the road.
  29. Blues4U
    Blues4U
    from So Cal
    Damn! That's frustrating!
    65pacecar likes this.
  30. BLACK STUDE
    BLACK STUDE
    Went a few rounds Saturday at the nostalgia race at Little River dragway. Carb was being a little persnickety in the heat but wide open going down track she was hauling ***. Had a good time. Saw a bunch of people I hadn't seen in a while. Other than the heat it was a fun time with a good turnout. 18902.jpeg IMG_20201010_120823399_HDR.jpg
