Technical Glass Frontend Rescue Thread
Discussion in 'The Hokey Ass Message Board' started by ol55, May 31, 2020.
  1. 1971BB427
    1971BB427
    from Oregon
    Mine looked like this when I test fitted it to my '39 Chevy. Talk about ****py fit!
    I ended up cutting the hood off, and sold the fenders to some **** making a "R" rod. After a lot of work I gotthe hood "bent" to fit my car's cowl and grille.
    bchctybob and ol55 like this.
  2. ol55
    ol55
    from Virginia
    Some great examples here. Was planning on getting the paint off and leaving it. If I can’t do that I need to prep for the next step. Which is; A) Resin and hardener, B) Gelcoat, C) Two part Epoxy or D) something else? Which is beat for this?
  3. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    ONLY resin/hardnener if youre putting matt on. Painting with resin is just making it brittle and not helping anything. Gelcoat could work. Epoxy, if youre doing a repair.
    Id see how it looks, repairs from the inside as needed, add some matt in places if you feel they need more strength. then go at it with heavy build primer
    ol55 likes this.
  4. seb fontana
    seb fontana
    from ct
    Gel coat is best, can go in any direction from there.
    ol55 and bchctybob like this.
  5. With bad cracks like I saw in an early photo, the gl*** fibers are all broken and resin alone is not a strong fix. You have to 'bridge' the backside with FG mat and then V-cut the outside to remove any weak, 'resin fixes'. Then overfill the V with fresh fiber and just enough resin. You will have a ridgeline to grind down but there's no getting around that.
    Like ****o says, "Fiber strong. Resin, no strong".
    Just thinking about it makes me itchy. :confused:
    ol55 and Phil P like this.
  6. ol55
    ol55
    from Virginia
    Taking advice from here I added the nickel brake line tubing to the inner lip then held it in place with bondo. Hopefully it will be strong enough to sit on the ground without collapsing.
    guthriesmith likes this.
  7. guthriesmith
    guthriesmith
    Just saw this thread...or maybe saw it again after a long time. Doing the same thing right now and fixing gl*** the way I have before for Corvettes or even a wheel standing tractor that I built a hood for. I just put this 55 front end back together after it got into a wall. Almost there and just lacking some final bodywork on the outside to make it look like it wasn’t in 10 pieces with some areas missing. Strangely enough, I kind of like fibergl*** work.
    9B1CF780-F4AC-4DFB-8540-93BAF24F6BAC.jpeg A305ED74-672C-4508-A035-3FC21417910C.jpeg 5BCF0EE5-F1D4-40EE-9683-21C1A4E76DDA.jpeg 94590982-0742-4909-8182-830462563F4E.jpeg C42D32A3-4F21-490F-86C7-AD8237092718.jpeg
    ol55, kidcampbell71, HJmaniac and 2 others like this.
  8. chevy57dude
    chevy57dude
    @guthriesmith - The king's men should have let you work on Humpty Dumpty. Great save!
  9. guthriesmith
    guthriesmith
    Thanks! But the time vs. money to buy new likely doesn’t make sense on it. However, sentimental value can change that equation at times. Just glad it could be saved. :)
    ol55, kidcampbell71 and chevy57dude like this.
  10. chevy57dude
    chevy57dude
    That front end is part of the car's racing history. Therefore worth saving, when you factor in that it wasn't junk in the first place. Valid points posted about time, money and the aging of parts. UV light isn't kind to 'gl*** parts. We've all seen ''fuzzy'' pieces that were left outside.
  11. guthriesmith
    guthriesmith
    Exactly. When I saw the story on the car, I knew the front end needed fixed. Car should be racing again soon according to Rusty.
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    Matte/ resin builds more bulk ,less strength. Cloth / resin builds less bulk/ More strength .There's nothing wrong with using polyester resin to fix polyester resin . A skim coat of bondo , then primer , then paint is an acceptable method for repair . metal or wood imbedments can be attached many different products , do some reading on boat forums & suppliers websites , you'll gain some knowledge ..
  13. 31hotrodguy
    31hotrodguy
    ol55 and kidcampbell71 like this.
  14. ol55
    ol55
    from Virginia
    I recognize that front end! Good job! Are you going to sand down and gel coat?
  15. guthriesmith
    guthriesmith
    No sir, I will just skim coat the repaired areas with body filler, then prime it with a good filler primer. I have never worried about gel coating gl*** when I either built parts or repaired them and it has also never caused me any issue. I built the majority of a hood for a marketing tractor at my work about 8 years ago now that we did that way and it has never had any issue at all. If it did, we would see it in black if any color. I have also done multiple repairs on vettes and boats as well the same way. Gl*** really just needs a good seal coat prior to paint to fill any porosity as best I can tell.
    And, thanks!
  16. brigrat
    brigrat
    from Wa.St.
    If using gel coat I hope they have a better formula than in the '70s, couldn't keep the sandpaper from clogging up back than.............................
    ol55 and guthriesmith like this.
  17. guthriesmith
    guthriesmith
    Getting close now. :D I was sure to use my “paint booth” for the primer application. :rolleyes:
    2FF1ED6D-29C1-4720-8A09-F189E53AAA90.jpeg F78ACD41-CB0B-45F1-AC6D-E2354C8A3FB4.jpeg BD39CC49-C4FC-4845-B4D4-75D5DD784F7D.jpeg
    chevy57dude and 427 sleeper like this.
  18. brigrat
    brigrat
    from Wa.St.
    It doesn't look like you needed any advice!
    427 sleeper likes this.
  19. guthriesmith
    guthriesmith
    Lol...I was just showing the rescue of another 55 Chevy fibergl*** front end. The OP was asking about a different one. :D
    brigrat likes this.
  20. ol55
    ol55
    from Virginia
    Yep, not mine but he is moving along!
  21. ol55
    ol55
    from Virginia
    What primer are you using? Looks great.
  22. flatheadgary
    flatheadgary
    from boron,ca
    just an aside. when repairing a crack, the correct way is to sand the crack out and sand down 3 to 4 inches around it on both sides to thin it. apply resin/mat to level it out. just applying resin/mat to one side is just asking for it to crack again. another tip. use tooling resin. doesn't shrink, as it is used in mold making.
  23. guthriesmith
    guthriesmith
    Thanks. I am just using an inexpensive 2K catalyzed filler primer from O'Reilly Auto Parts. I can't remember the brand name, but I have used it on a few other things recently and have been happy with it. I used to solely use Sikkens products and was always happy with them. But, the price of materials is ridiculous anymore, so I am looking for alternatives.
  24. guthriesmith
    guthriesmith
    For anyone wondering the method I used to put it back together, here is a quick explanation.
    I first ground the back about 3” back from every crack, then put the pieces back in place backing it up with packing tape on the outside along the joint. Then, I used strips of cloth and resin along the seems to make it one piece again. I had to put it back together in multiple steps since it wasn’t stable enough to do all at once by any means. Once I had all the joints gl***ed back together, I filled any missing parts by just building up gl*** and backing it up by whatever I could use to make the right shape (2x4’s, or in one place foam that I carved out). Then, I flipped it over and ground the joints on the outside too. Then, I basically did the same on the outside although not as many layers. Anyway, this is what the inside looks like before I try to somewhat hide it to help explain.
  25. flatheadgary
    flatheadgary
    from boron,ca
    you obviously know what your doing. good job.
    HJmaniac and guthriesmith like this.
  26. guthriesmith
    guthriesmith
    Lol...not sure about that, but this method has worked for me so far. Thanks!
    HJmaniac likes this.
