Projects Aussie 32 frame / Model A coupe build.
Discussion in 'Traditional Hot Rods' started by Wardog, Feb 7, 2019.
  1. Wardog
    Wardog
    Thanks @Outback . Yes, it will be hi boy.
    Outback likes this.
  2. brEad
    brEad
    Nice job on the transmission hump. Very discreet.
    Stogy and Wardog like this.
  3. Wardog
    Wardog
    I finished off the trans cover.
    That finished up the bolt in section of the floors.
    C99B884C-7BB8-4DA8-A64B-A770D5C65D34.jpeg C9E4DB5E-2EE9-4EF6-A8BA-31107250B72F.jpeg 6CAED71E-69C4-418C-93CE-BB156E7CF0E1.jpeg 75A9B5E5-AE99-40DB-A57D-95061E42A45E.jpeg
    With a little help. I made all the floor sections. I have just finished lifting the body off again to weld these all in.
  4. brEad
    brEad
    Floors look great! You do some really nice work!
    -Brent-, sloppy jalopies and Stogy like this.
  5. Wardog
    Wardog
    Thank you @brEad Not the best work but I try to do a neat and good quality job.
  6. kadillackid
    kadillackid
    I'm impressed, wish mine looked like that ;)
  7. Nick Agius
    Nick Agius
    Gee Wizz Wardy!
    You have been busy man, Its looking great! Love the Column drop idea to, I know a guy that will find that a great help!
    Hope you and hte family are well
    sloppy jalopies likes this.
  8. 31 Coupe
    31 Coupe
    Love your coupe and the quality work you're doing ....... very well done.
    Will you need to have a collapsible column for rego in VIC, I'm of the opinion that we need them in NSW for full rego.
  9. Wardog
    Wardog
    Hey Nick, thanks for your support mate. I hope I can be a help. We are all well, I hope you are too.
    I noticed you put bobbed fenders on the roadster and I’ve heard about another change on the cards. Bring on the 50’s hey?
  10. Wardog
    Wardog
    Thanks Man. It all depends on your state, your engineers interpretation of the rules and the rego you are going for. Some will p*** a solid steering shaft if the steering box is far enough back from the front of the frame. I’m putting this through as a modified stock frame.
  11. 31 Coupe
    31 Coupe
    Thanks for the reply, my engineer is fixed on me having one and it is probably safer anyway. I'm using a flipped F1 box with a >'48 splined shaft and the collapsible conversion is reasonably easy, especially if you have a machine shop at your disposal.
    Keep up the great work.
    Wardog likes this.
  12. Kim Leonard
    Kim Leonard
    looking good !
    Wardog likes this.
  13. Wardog
    Wardog
    Last week I welded in the floor pans.
    I painted the under side first so there was paint between the mating surfaces. Then I sealed the top and bottom with a brush on seam sealer.
    18267E0C-125C-4EE1-B2AB-12088DA0CFFA.jpeg A20094FC-8C7B-4044-BC27-3A18FD0F156D.jpeg 230351F9-A62A-45DA-B002-A43757CBDC51.jpeg
    Underneath I brushed on a bitumen based undercarriage paint.
    I finished welding the fire wall then cleaned up the welds.
    Then I put some paint on everything.
    F4217F1C-6100-444A-B4EE-780FC50796DE.jpeg 1127816C-C623-450B-894B-A0571C0BF279.jpeg
    Fairlane500, KiWinUS, 35cab and 8 others like this.
  14. brEad
    brEad
    Looking good!
    Wardog likes this.
  15. Elvis100
    Elvis100
    Wardog likes this.
  16. Wardog
    Wardog
    With the 32 column drop sitting in front of the dash I decided to finish it off a bit nicer. I cut and shaped some aluminium D moulding and glued it on with a 2 part epoxy.
    DA5B1FFE-A153-4B8F-8798-96327C88E5B5.jpeg 227DE054-380A-4A0D-BA98-2DC2347238B6.jpeg CF71FFA4-0C79-4794-8852-BA66EDC79CC9.jpeg
    I fitted the body again after finishing the floors and firewall.
    I decided I want to run a rear spreader bar tucked up nice and tight to the body. So I shortened the sections of ch***is rail I had already cut off. Now they are tacked up I guess it’s time to remove the body again to weld them and touch up the frames paint.
  17. Outback
    Outback
    from NE Vic, Oz
    Nice work! It's looking great, making good progress too!
  18. Wardog
    Wardog
  19. Wardog
    Wardog
    I’ve had a lot of small jobs I’ve been working on at once lately. Today I finished the accelerator pedal and linkage. I used a right hand drive 32 pedal, I shortened the rod 2” and mounted it inside the firewall then made a linkage to the rear carb out of stainless rod.
    4DB5698D-E17A-41BB-A51C-FB9483FAF788.jpeg 60805AE5-0E06-4D75-8872-9A97F0BA9A2A.jpeg 0CE6A42A-C45F-4352-BDD0-4D226A5330F7.jpeg
    The other job I finished today was the rear spreader bar. I messed around for a long time with placement but I’m happy to have it up close just to fill the void Model A’s seem to have at the rear of the body.
    F4E1FB4E-34E0-4078-95FD-D8A4E6DD16F6.jpeg F6F1F2A0-6C2F-4FE1-BCC1-4BEB5E3B3A0B.jpeg
  20. Wardog
    Wardog
    I set up the seat using the stock seat base on a hinged flat mount. The back rest is the same hinged mount and some 2” medium density foam. I unpicked the trim from the stock backrest and covered the foam with it.
    I set up some safety belts. I bent my shifter to clear the dash and installed my Lucky Burton shift knob.
    So I pulled the body off and finished the step down at the rear of the ch***is.
    I’ll touch up the paint on the frame and get the body back on.
  21. Outback
    Outback
    from NE Vic, Oz
    Nice work mate!
    Stogy likes this.
  22. 55zephyr
    55zephyr
    There's some nice work going on here. Looking great.
    Good luck, stay safe, Ron.
    Stogy likes this.
  23. Wardog
    Wardog
    Thanks for the encouragement guys.
    Stogy likes this.
  24. brEad
    brEad
    I really like your spreader bar mounting solution. Did you consider putting just a tiny bit of curve in the bar to follow the body?
    Stogy likes this.
  25. Wardog
    Wardog
    @brEad i did consider it for a bit. But every time I go to do something like that I tell myself that wouldn’t of happened in the 40’s. I had the same thoughts with the floors. Had I not been trying to keep an early style I would of bead rolled stepped panels in the floor panels.
    brEad and Outback like this.
  26. brEad
    brEad
    Gotcha, that makes sense. Thanks for the response.
  27. Wardog
    Wardog
    I didn’t realise but it’s just over a year since I painted the frame. During the week I touched up some paint and on the weekend I gave it a wash. I took the opportunity to get some photos before installing the body for hopefully the last time. After putting the body on I took a few more photos.
    61E17668-0789-4D2B-AF80-5EA42D48A2F6.jpeg 2987427E-C662-4F30-9F9F-364E84B727B3.jpeg A420EB7C-0530-483D-8EB0-63A7068358FF.jpeg 10680E2E-2493-4BD9-A48C-9D78D514145B.jpeg 34ADB5BB-BDFF-4630-BF02-9DA5271FF312.jpeg
  28. Outback
    Outback
    from NE Vic, Oz
    So good mate, must be a great feeling to get to that milestone!
  29. Wardog
    Wardog
    It sure is mate. I’m getting a radiator made now and i’m just trying to keep moving forward.
  30. Aaron D.
    Aaron D.
    What a shame to cover up that great looking frame, but then again it sure looks great with the body on:cool:
