Technical One learns by their mistakes
Discussion in 'The Hokey Ass Message Board' started by blazedogs, Oct 4, 2020.
  1. blazedogs
    blazedogs
    Recessed a firewall 4 inches in a recent car build and it made a nightmare for the steering, brake and gas pedals and wiring locations. Was time and money wasted. It turned out I would not have had to do it from the beginning. I anticipated wrong Poor planning & measuring!! Be careful what you do.. Gene
    Elcohaulic, Jet96, vtx1800 and 6 others like this.
  2. I’ve went to plan B more than once, and beyond that a few times. Don’t beat yourself up. It happens to all of us.
  3. No big deal, keep the recess for another project (can use pieces or the whole thing).
    rbrewer and fauj like this.
  4. Stu D Baker
    Stu D Baker
    from Illinois
    Plan B???? Hell I consistently hover around plan E.
    weps, williebill, ckdesigns and 7 others like this.
  5. Mr48chev
    If you don't make a mistake once in a while you have never actually done anything.
    Try working on a little off topic truck and checking the firing order on line and wiring it and then figuring out that you got your big bang out the exhaust because you had used the wiring diagram for a same brand car with the same size but completely different engine after more research .
    X-cpe, Sandgroper and rbrewer like this.
  6. X38
    X38
    Plan ? It's a 26 step program.
  7. blazedogs
    blazedogs
    Mock up a similar engine block in the location where you want it to sit in the frame. Then measure & study before you start cutting things up daaa
  8. Jalopy Joker
    Jalopy Joker
    hopefully we learn - measure/measure; mock up; temporarily install components, measure more, remove, etc - research/ask questions, etc - keep at it - even the big name builders make major mistakes
    olscrounger and rbrewer like this.
  9. Model A Gomez
    Model A Gomez
    I usually do everything at least twice before I'm happy with it. I've mocked a car completely up, blew it apart to rebuild everything and paint it and then something won't fit. If you're not doing it twice it's probably wrong !
  10. goldmountain
    goldmountain
    I have a Zip's water pump riser on my other car and it works great so I used it to make a jig to build one myself. After finishing it, discovered that a regular water pump centered the fan on the radiator just fine. A lot of work for nothing so I gave it away to a co-worker with a Model A.
    rbrewer, fauj and olscrounger like this.
  11. jetnow1
    jetnow1
    from CT
    Too err is human, the problem is no one forgets when you do. The lessons we learn by actually doing something are permanent, especially those we have to redo. Just think how much you have learned.
    rbrewer likes this.
  12. LAROKE
    LAROKE
    The difference between an expert and a novice is that the novice has not made any mistakes yet.
  13. Petejoe
    Petejoe
    from Zoar, Ohio
    It’s not so much the extra time that lets you down. I kick myself when I have to throw the extra money at it.
    Algoma56 likes this.
  14. alanp561
    alanp561
    On my 27T build, I'm pretty sure I'm somewhere around plan X + 1[emoji6]
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
    williebill and Sandgroper like this.
  15. wicarnut
    wicarnut
    In my Trades, ( Tool & Die Maker, Pattern Maker ) there are no mistakes, engineering improvements as required. The difference between an apprentice and a journeyman, the journeyman knows how to correct his mistakes with engineering improvements. Everybody learns from their experiences, exception is the fool that keeps making the same mistakes over and over, we all know some of these guys.
  16. KenC
    KenC
    That ***le is just not true. And I can prove it. If it was so, I'd be the smartest guy in the world. That's how many mistakes I've made. But, still not smart.
    alanp561 likes this.
  17. ramblin dan
    ramblin dan
    Been there, done that, and bought the T-shirt. My grandfather used to say look twice and shoot once. I'm still working on that one.
    williebill and olscrounger like this.
  18. Measure twice, cut once and learn to weld.
  19. Paul
    Paul
    Editor
    I moved this thread as it's original placement required minor adjustment
    williebill likes this.
  20. X-cpe
    X-cpe
    Many is the time I've come up with a complicated solution, only to have the simple, elegant solution become apparent between half way to all the way to completion of the original.
    Its when you repeat mistakes that you need to ***ess whether that's the type of activity you should be doing.
    Just Gary, Wanderlust and olscrounger like this.
  21. 37slantback
    37slantback
    Thats where all my extra parts and components come from...
  22. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    The stand I take is, this is a hobby ( maybe ). When working, you work for yourself, you be da boss. If there is a mistake made, be a NICE boss, have a session where notes and rules are considered and made. Then post your shenanigans on H. A. M. B.:D
    alanp561 and LAROKE like this.
  23. thintin
    thintin
    Man plans............God laughs.
  24. belair
    belair
    Good judgement comes from experience. Experience comes from bad judgement.
  25. Fortunateson
    Fortunateson
    Perhaps you applied your paint too heavily? LOL
    ramblin dan likes this.
  26. wicarnut
    wicarnut
    Life Is kinda Funny IMO, In my case, When young I thought I knew everything, then I was sure I knew everything, now old can't remember anything. Still having fun, walking/talking/typing and most times making sense at least to me. I think my signature covers it for me.
    LAROKE likes this.
  27. flatheadpete
    flatheadpete
    from Burton, MI
    I bought a part for an O/T project years ago. The instructions said 'Easy as 1-2-3'. I got to part K and damn near set it on fire...on purpose.
  28. MMM1693
    MMM1693
    Over engineered, not mistakes
  29. Illustrious Hector
    Illustrious Hector
    I too recently put a recessed firewall in a Model A closed cab with, in hindsight, some regret. It only challenges us to find a solution in re: seats , pedals etc. One member on here posted "If you fail to plan, you should plan to fail." The objective is fewer trips back to the drawing board.
  30. partsdawg
    partsdawg
    from Minnesota
    Everything I do looks good in my head.
    Sadly, my head to hand coordination ****s.
