50 Power Wagon Woodie
Discussion in 'The Antiquated' started by mamllc, Aug 6, 2020.
  1. pumpman
    pumpman
    Are you working from wood structural plans? Was there any original pieces used as templates? Your craftsmanship is off the chart! Thank you for the posts.
  2. mamllc
    mamllc
    It had a body on it when I got it but it was not the original one. The only parts in the new body from the old one are the window regulators. The original idea was for me to build an exact copy of an authentic Campbell body, but one small change led to another and at this point it is pretty much a full custom, loosely styled after the Campbell body. Kind of what I call a working prototype. Making it up as I go. Truth is that there are a lot of people out there doing that, just not many of them doing it out of wood.
    Ford52PU, 6inarow, Tim and 1 other person like this.
  3. 210superair
    210superair
    from Michigan
    That's absolutely insane, beautiful work. You're a talented fella...
    lothiandon1940 and das858 like this.
  4. COCONUTS
    COCONUTS
    When I was in Iraq, I saw these trucks that would pass as a woodie, must like the one that you are building. they were pretty big, much bigger than your or a 49 Ford SW. If I can find a picture I will post it. Maybe you should be in the Chris Craft boat business, with your skills and eye for detail
  5. mamllc
    mamllc
    I've built several Mahogany Chris Crafts. My next big project after this truck is going to be a 1937 Gar Wood.
    badgascoupe and Peanut 1959 like this.
  6. mamllc
    mamllc
    Tailgate wood work is about done, still have some hardware to sort out. Finishing up some of the interior trim and panels. Getting down to the small stuff. IMG_4447.JPG IMG_4462.JPG IMG_4466.JPG IMG_4460.JPG IMG_4461.JPG
    Rawrench, Okie Pete, rc57 and 16 others like this.
  7. pumpman
    pumpman
    Awesome just awesome!!!!
    41 GMC K-18 likes this.
  8. BamaMav
    BamaMav
    from Berry, AL
    Beautiful woodwork!
    Where is Concord AL?
    lothiandon1940 likes this.
  9. mamllc
    mamllc
    West of Birmingham, just past Hueytown.
  10. BamaMav
    BamaMav
    from Berry, AL
    I thought I knew AL, but wasn't sure about that. We have a Concord community over here in Fayette county. I'm just west of Jasper about 30 miles in the corner of Fayette county.
  11. khead47
    khead47
    Wo.w ! Simply wow. I can almost smell the sawdust. Your skill rivals Guis, The giant Speedster guy in Brazil.
    lothiandon1940 and 41 GMC K-18 like this.
  12. Peanut 1959
    Peanut 1959
    We assume you meant awesome! [emoji12]
    210superair and 41 GMC K-18 like this.
  13. i.rant
    i.rant
    1. 1940 Ford
    Awesome craftsmanship. Do you make a template for each piece? I’m interested in the process you’re using for design,layout,tooling and final assembly.
    You sir have a gift IMO. Thank you for posting this project..
  14. Tim
    Tim
    from KCMO
    Unbelievable. Wow
  15. deathrowdave
    deathrowdave
    from NKy
    It wasn’t in this league when it was brand new
  16. mamllc
    mamllc
    Thanks. I do make a lot of patterns, but not for every piece. Some pieces are simple enough to make just using measurements, a two dimentional pattern works most of the time, and in extreme cases (like the roof front corners) I make a three dimentional pattern. The design goal for this truck is for it to be recognizable as a Campbell body, even though quite a few changes have been made. It got there in steps, starting with building an exact copy of an original and ending up more like a full custom. I've worked from renderings in the past, but this one is more of a design it on the fly kind of project. Tooling is as simple as I can keep it, no point in building elaborate tooling for one off parts. The assembly process is dictated by the body, and every one is a little different. In this case, the floor will go on first, followed by the quarters as they hold the roof up, then the roof. After that the doors can go on in any order. Smaller parts are installed as they need to be or whenever convenient. Thanks for watching!
  17. mamllc
    mamllc
    I still have a couple panels to veneer and some final fitting before it comes apart for finish sanding and varnish. Gonna get cluttered around here. IMG_4508.JPG IMG_4509.JPG IMG_4510.JPG IMG_4511.JPG
    Rawrench, Okie Pete, rc57 and 10 others like this.
  18. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    amazing work. I had a 48 Dodge Pilot house project but end up selling it as the wood portion was more than I could do and could not afford to have it done professionally. wi
  19. 51504bat
    51504bat
    Found this photo while looking for something else in my files. You've probably seen this photo but here it is in case you haven't. Like everyone else has said your workmanship is beyond amazing. Thanks for the post. pww.JPG
    Rawrench, Okie Pete and Peanut 1959 like this.
  20. Ford52PU
    Ford52PU
    from PA
    Really amazing work. So beautiful true craftmanship, cant wait to see it finished.
  21. rockable
    rockable
    Wow! Subscribed.
  22. RodStRace
    RodStRace
    Told ya!;)
  23. rockable
    rockable
    Thanks! Merry Christmas!
  24. fortynut
    fortynut
    I hope the owner lives close to 'the Orkin Man'! Very nice work. Only wooden you rather be doing something else?
  25. Flatnose
    Flatnose
    A labour of love,I'm sure!beautiful end result.
  26. mamllc
    mamllc
    Sanding, and lots of it.....Worked a few other details in for an occasional break. Installed electric wiper motors, reworked the trans tunnel, installed a new windshield, etc.. But mostly sanding. Not done yet but the end is in sight. Hope to get the floor boards back from the spray booth tomorrow and can finally get to reassembling this thing. Getting the first look at what the colors will be, don't know what the computer will do to them but in person I think they look good. The fabric in the last one is the leather that the seats were done in. IMG_4602.JPG IMG_4603.JPG IMG_4604.JPG IMG_4605.JPG IMG_4609.JPG
  27. fleetside66
    fleetside66
    Absolutely mind boggling!! I my dreams I couldn't even be that precise. You are a true craftsman.
    rockable likes this.
  28. mamllc
    mamllc
    The heavy sanding is finally done, the last batch of parts might even be out of the spray booth by now. Got a start on the assembly, pretty good ways to go yet though. IMG_4632.JPG IMG_4633.JPG IMG_4634.JPG IMG_4641.JPG IMG_4643.JPG IMG_4644.JPG IMG_4646.JPG IMG_4661.JPG
  29. rockable
    rockable
    Wow! I just can't imagine the skill level required to do this build. Outstanding!
  30. oldwagonlover
    oldwagonlover
