Projects Southeast TN 51 shoebox build.
Discussion in 'Traditional Customs' started by Kage, Nov 6, 2018.
  1. Kage
    Kage
    from Delano, TN
    The 164-tooth flywheel...if I remember correctly
    chryslerfan55, loudbang and dan c like this.
  2. Kage
    Kage
    from Delano, TN
    Here are some old pics I had on my phone from the day I picked up the bellhousing.
    ill be pulling the motor and trans soon and will get a better pic.
    24193680-D985-426C-B278-C476224BCD4B.jpeg F0E9C7B9-11A6-4E50-88E4-A7DCCDC9D346.jpeg D29385A3-C86C-4922-83FB-1EF6695D133A.jpeg
  3. dan c
    dan c
  4. Kage
    Kage
    from Delano, TN
    No work on the car here lately..(because of a back injury) but I did manage to finish redoing the bicycle I picked up at the last swap meet.
    8A58C8A6-458E-4F37-88D9-5AAB4D978AEF.jpeg 46148B73-BA6E-4719-8363-E366A438C90E.jpeg 112DFC38-5E8D-4BA5-BB51-C979F756E0CC.jpeg
  5. Kage
    Kage
    from Delano, TN
    Finished up the trans tunnel today
    I think it turned out pretty well. I still have a couple of small patches to make.
    laid out all my cuts for the chop.
    finished bracing the rear window
    Now the fun really begins. Started by cutting out the rear window.
    BC795D58-43A8-44BC-89A9-EF30F229821A.jpeg D4AE6E01-E6A9-4EB9-B30A-D60D7CC28DE8.jpeg
    Then I cut out the B-pillar
    I set the top back on to get a look at it.
    I’ll start working on the front post alignment this weekend.
  6. Kage
    Kage
    from Delano, TN
    Got a little more work done on the chop. Front post are tacked in place. Rear window is set were I think I want it. And I started working on the B-pillar and door post. Used some tape to get a better idea of the profile. More to come.
    4879F8A6-9553-4A84-8426-4871C2B60D5D.jpeg 4F484399-DCAC-4529-A172-E4241617FC1D.jpeg
  7. Nice profile Kage, I like it
    Sent from my SM-A102U using Tapatalk
  8. Kage
    Kage
    from Delano, TN
    More progress on the chop. Passenger side B-pillar, A-pillar and door window frame are almost finished, and back window corner installed.
    Luckily I have a whole extra donor roof...I cut a section out of its B-pillar to make the curve on the bottom flow better. I will do the same with the top corner of the door frame.
  9. Kage you are making short work out of this chop. Looks great.
  10. brokedownbiker
    brokedownbiker
    Jeez, you're making me feel bad! You've done floors and most of a chop in the time it has taken me to do the passenger side floor in my '51. Of course you know how to weld, that helps a lot, lol. I've got it figured out finally but damn, I'm slow!
  11. Kage
    Kage
    from Delano, TN
  12. Finnrodder
    Finnrodder
    from Finland
    Looks like you have done some serious english wheeling, that sail panel looks good!
  13. loudbang
    Wow if this is not a time lapse type build thread you sure are moving right along. :)
    1947knuck likes this.
  14. Rusty Heaps
    Rusty Heaps
    Hey Kage, I just visited a junkyard near Blaine in Granger County, TN last week looking for GM parts from the '40s and '50s. not much left. A few mid '50s Buicks, but a lot of Fords from '49-'56 and some mopars of the same era along with quite a few desirable cars from the '60s and early 70s.
    Kage and loudbang like this.
  15. Kage
    Kage
    from Delano, TN
    thanks...this is my 1st time wheeling out a large panel. It still needs some work. But it’s getting close
    thanks for the kind words.
    what is the name or address of the yard? I would like to check it out.
  16. Rusty Heaps
    Rusty Heaps
    what is the name or address of the yard? I would like to check it out.[/QUOTE]
    I'll have to get back to you on that, we just drive up there. They say they're open Monday thru Saturday. They're located near Blaine, TN. Sonny Reeser used to own it, but he passed away, now his brother Gary runs the place. He's very reasonable on parts prices, perhaps the family made their money on the cars back when they were newer, I believe its Reeser Auto Parts, Just ask the locals in the wide spot in the road known as Blaine. There is a used car lot in town that has some antiquated vehicles and I believe are affiliated with the yard, they can direct you if you have come that far.
    loudbang and Kage like this.
  17. Kage
    Kage
    from Delano, TN
    Not much to report. I did finish fitting the passenger side sale panel. It’s all tack in place. I will tig weld when I go to finish weld it.
    I pushed the car out side...took a couple of pics and then turned it around so I can work on the drivers side.
    my little helper was helping me push the car.
    I think the chop flows pretty well.
    brEad, loudbang and Finnrodder like this.
  18. Jalopy Joker
    Jalopy Joker
    Sleepercooler, dan c and loudbang like this.
  19. the-rodster
    the-rodster
    Looking good!
    Rich
  20. Kage
    Kage
    from Delano, TN
    Not much progress as of late. Currently making templates of the passenger side window opening so I can make sure the drivers side matches perfectly.
  21. Kage
    Kage
    from Delano, TN
    Took a break from working on the chop to work on the drivers fender. Also working on grafting the 52-54 fender flares onto my fender
    B0BD7E3B-DDD1-4450-96CD-C216F7F44177.jpeg 54BDCAAC-FFBF-4586-B084-6A7A1D163A0A.jpeg 430F523F-62E7-42AF-9A54-A050A176B0DE.jpeg 93839CD5-40D1-459F-9F25-29635150F601.jpeg 76C76F16-7B9D-495C-97C6-F4573FC0790E.jpeg 6C31E710-E33A-496F-B261-967D418C05CE.jpeg FC03FF49-C750-413F-94A4-C015E0056F6C.jpeg 6860B3D1-7B70-4030-8E38-19ED1DA2CE34.jpeg
    grf-x, brEad, loudbang and 2 others like this.
  22. Those flares will look great!
  23. Kage
    Kage
    from Delano, TN
    Well...I'm finally back to work on my 51.
    since I last posted I have finished welding on the fender flares and frenched the head lights. 20200409_185618.jpg
    the new headlight rings were to think and gave the car a bug eyed look so I cut about an Inch out of them
    20200409_191237.jpg 20200409_200543.jpg 20200410_192005.jpg 20200410_191945.jpg
    brEad, loudbang and warhorseracing like this.
  24. Kage
    Kage
    from Delano, TN
    I have more pics to post...just waiting for them to upload...got to love slow internet.
    loudbang and 50 Merc Man like this.
  25. Kage
    Kage
    from Delano, TN
    got some parts in.
    new hubcaps for the front, rear air back, shoebox central camber adjustment plates
    Rebel wiring harness
    new radiator
    front dominator bags
    air cleaner from a 58 impala
    I also go my shaved door handle and trunk kit, plus a set of universal suicide door hinges and some bear claw latches. Plus led rear tail lights, some cal custom valve covers, a set of peep mirrors and some fender skirts, along with a few other things
  26. Kage
    Kage
    from Delano, TN
    I've also been building my own bead roller with a 36" throat depth. the body is made from 1/4" plate, the stand is made from 1/8" stainless
    It isn't complete yet. I still have to machine the shaft guides and order the spur gears. And finish weld the stand and add some adjustable foot pegs.
  27. 50 Merc Man
    50 Merc Man
    Gonna be sweet when you’re done bro, [emoji106][emoji106] nice shoebox!!!
  28. Kage
    Kage
    from Delano, TN
    A few shot from when I rolled her outside so I could clean up the garage
    20200517_110739 (1).jpg 20200517_110750.jpg 20200517_110811 (1).jpg 20200517_110829.jpg
    rpent, 40LUV, brEad and 2 others like this.
  29. Travis latour
    Travis latour
    from Putnam CT
    Go man go!
    Kage likes this.
  30. Callmaker
    Callmaker
    Awesome car!!
