Technical BBC new camshaft failure (long story)
Discussion in 'The Hokey Ass Message Board' started by justpassinthru, Sep 23, 2020.
  1. Roothawg
    Roothawg
    Man, that ****s Jason.
    Thats does it, I converting everything to an LS.
    Well, maybe not......
    lumpy 63 and Blues4U like this.
  2. landseaandair
    landseaandair
    from phoenix
    New Summit lifters. On the limiter quite a few times but only for a few seconds. Engine is apart now but springs were never in coil bind. Also intake lift was .022" less and lobes on both sides just as bad.
  3. Nailhead Jason
    Nailhead Jason
    I wish it was a press in stud. But they are screw in studs.
  4. Nailhead Jason
    Nailhead Jason
    upon further inspection of old photos. The head do have press in studs. Maybe I’m good!!
  5. landseaandair
    landseaandair
    from phoenix
    Remembered I keep bags of paperwork and box tops from parts for projects. Found the swap meet Erson cam accessory kit I used # E811011, springs # E915005., 110 @ 1.750", 252 @ 1.225", .525" max lift?
  6. Elcohaulic
    Elcohaulic
    I've had studs pull out on Pontiac heads and it acts just like a lobe went bad.. Make sure its not the stud but I hope it is!!
    scrap metal 48 and Blues4U like this.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    Seems most can failures we hear about are Chevy motors , I know there's folks using Chrysler , ford , olds ,caddy , Buick etc. Motors on here , are they experiencing the same difficulties ??
  8. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Yes, but probably at much lower HP levels............
    2OLD2FAST, lumpy 63 and Blues4U like this.
  9. olscrounger
    olscrounger
    Hope it's just a stud pulling out--Have seen quite a few do that years ago-quick fix-drove back down and pinned. Put a lot of 097 cams or copies in early 283's and 327's with no issues over the years-3 in the last two years in 327's-had good luck with Elgin
    Used to pin the stud too years ago.
    dirty old man and Elcohaulic like this.
  10. scrap metal 48
    scrap metal 48
    Probably happens more with Chevys because MOST people run CHEVYS!!!!!!
  11. Elcohaulic
    Elcohaulic
    Pontiacs are going through the same thing. Don't even put a Comp XE Series cam next to a Pontiac block it will grind itself away.. Crowers seem to work well in Pontiacs..
    2afbs likes this.
  12. dirty old man
    dirty old man
    If the stud has pulled out some it should be up higher than the others across the top. Lay a straightedge across them and you should be able to tell if the loose one stands up above the rest.
  13. wolfman wooly
    wolfman wooly
    from TEXAS
